Question about Gigabyte GA-8I845GV Motherboard
My motherboard slow boot and always need disc to boot .
My current O/S is Windows XP Pro SP3 . When the motherboard boot , (if no CD in cd rom ) It says please select disk boot and press enter. when I press enter the screen will black forever . Any help please
Looks like your computer can't find an Operating System in your hard disk. May be the hard disk is dead. You should check hard disk connection cables, and if they're working, we'd have to assume that the hard disk should be replaced.
Posted on Nov 21, 2013
Testimonial: "If I put the windows xp disc into drive and the drive read disc I have to eject disc before it go to windows xp setup . and the bios read hard drive and I can use the computer ."
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: system is no boot neither with cd-rom nor hard disk
Hi, Based of your post/description and assuming not hardware problem, you may have to set up the priority boot device in the BIOS to CD. This will tell your mb to look for a boot medium from the cd first. This is normally in the Advance Setup/1st Boot Device. Of course soon as installed, you have to boot from the HD next time. Good luck and kind regards.
Posted on Aug 14, 2007
jepito
  • 216 Answers
SOURCE: Cannot update from XP Home SP1 to SP2 or SP3
start out with a xp home disc that has sp3 already Intragated on the disc - windows xp home SP3
Posted on Sep 03, 2009
mpcheeseman1
  • 1400 Answers
SOURCE: cmos checksum erroe defaults loaded
press del to enter setup.then choose default bios setup. then save and exit.pc will restart.
Posted on Nov 22, 2011
Install windows xp pro cd with sp3
press f12 on boot to select what you boot from. Also, make sure the CD is actually bootable.
May 20, 2013 | Microsoft Windows XP Professional With...
Windows xp cd with sp3 installation
In BIOS change the boot order such that CD/DVD comes first. You will also need to make sure your hard drive runs in IDE mode since Windows XP doesn't support sata drives by default. FYI XP is going end of life early 2014.
May 20, 2013 | Microsoft Windows XP Home Edition
Bootmgr is missing
Take one bootable windows cd rom , insert the cd rom in cd rom drive, restart your Laptop , go to bios setup and select boot from cd rom after then save and exit . your Laptop will boot from cd rom . it will take some time , when you will see action prompt , select R ( if your bootable windows cd rom is SP2 ) , select D ( if your bootable windows cd rom is SP3) . if you select R you will be prompt repair consoul , format C:\ then instal windows SP2 . if you select D , you will be prompt delite partition , delite partition C:\ after then select C to creat partition and install windows SP3. either of one windows install like that and problem will be solved. n.b. if you don,t have cd rom drive pls collect USB cd rom drive.
Jul 30, 2012 | Dell Latitude D620 Laptop (Latitude-C620)...
SLOW BOOT UP??????????????
ummm
boot from xp sp2 cd
choose the repaire console by pressing (r)
when you reach the command prombt you can check your hard drive by writing the command
c:\windows\chkdsk/p wait until finish checking your hard
then write exit and try to start windows
Jan 02, 2010 | EPoX EP-8KRA2+ Motherboard
Hi I have a Toshiba Tecra M2 laptop with Windows XP Pro SP3. My CD-RW/DVD-ROM/CD-ROM drive is not working. When I try to burn a disc, it says no recorder, or no disc in drive. Also, Windows doesn't seem to...
>> it says IDE #1 error when it boots up.
IDE #0 is your disk-drive.
IDE #1 is your CD/DVD drive.
So, take your computer to a qualified technician, to first check that the connectors (power, data) from the motherboard to the CD/DVD drive are good, and then, if necessary, to remove & replace the "dead" drive.
Oct 27, 2009 | Toshiba Tecra M2 Notebook
Sep 03, 2009 | Gigabyte GA-K8VM800M Motherboard
Xp recovery
You need to download all the drivers installer files from manufacturer website first, and also all the software you want to install automatically with Windows. Then you build a Windows Xp boot CD with all the software setup embedded.
See the links below:
Build an XP-SP2 Recovery Disc - Solutions by PC Magazine
Geek Repair: Create Your Own Ultimate Recovery CD :
Bart's way to create bootable CD-Roms
Slipstream a Windows XP SP2 Recovery CD
Build your own XP SP3 Recovery Disk -
Build an XP SP3 Recovery Disc
Apr 18, 2009 | Microsoft Computers & Internet
Motherboard will not boot from Hard Drive
Go into your BIOS with the appropriate key (printed on the screen when you first turn the PC on).
Look around the various menus for a "boot order" or something to that effect.
I'd usually set it for CDROM then HDD... but as long as the hard disk is actually in the list before anything else with a bootable disc in it, you should be fine!
Aug 22, 2008 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Cd rom message "no emulation" when booting the windows xp installer
when i install my windows xp professional i get a message prompting BOOT TO ATAPI CD-ROM: "NO EMULATION".... how can i fix this?Pls help me on this
Jun 07, 2008 | ASUS P4SP-MX Motherboard
Boot cd-rom type:cd-rom/non-emulation booting
No, it's because Microsoft changed the way boot CDs work with SP2. You need an old CD (Windows XP SP1). I had the same problem here, notebook without floppy, it won't boot from the newer XP version CDs (SP2 or SP3) - but an old SP1 CD works!
(Those were all original Microsoft CDs, and the SP2 / SP3 CDs boot just fine on several other PCs I tested. It's just that some old hardware has a problem with the boot mode used on newer Windows CDs.)
Sep 20, 2007 | Computers & Internet
Gigabyte GA-8I845GV Motherboard Logo
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
