Question about QuietLine WD-9900 Front Load Washer / Dryer
Quietline dryer does not work!
Well that is about it - the dryer does not come on at all. First, it cut off in the middle of a drying cycle, tried it the next time and it worked, then it hasn't worked in 1 year. Please help!
  • 3 Answers
Re: Quietline dryer does not work!
Thor washer/dryer is either the same company or at least has parts. Go to their website and check for a number for support. You'll probably have to leave a message but they call back and the person can tell you what part you need and give you their parts dept or set up a service call...
Posted on Jan 30, 2008
If you're gonna get a new washing machine, its best not to consider a washer dryer as they tend to have a lower and shorter life span. Best thing is, if you really have to get a washer dryer, or a washing machine, try bosch. They really are the best
Posted on Oct 09, 2007
0 characters
3 Points
WD 9900 does not dry
Most all dryers, including combo washer/dryers, have an electric wire coil for a heating element.
I suspect yours has given up ( they usually break in two, stopping the electrical flow). You should need to have the element replaced.
Going to need to take the whole machine apart to fix this.
Be blessed.
Apr 17, 2013 | QuietLine WD-9900 Front Load Washer /...
Pump stops working during drying cycle
yes you are right it is the problem of dryer pump you have to check that pump and if neccesary replace it.
Thank you
Dec 07, 2007 | Supra SW5L30D Front Load Washer / Dryer
Where can I purchase spare parts for the Thor QuietLine WD-9900.
Type WD9900 into the search field and it will bring up the available parts.
Jan 10, 2011 | QuietLine WD-9900 Front Load Washer /...
I have a quietline washer/dryer how do I winterize it
there should be a panel on the front
open that you should have acess to the pump
open the pump and allow all water to drain
turn the water off at the isolators
hope this helps
Oct 28, 2009 | QuietLine WD-9900 Front Load Washer /...
Hotpoint BDW 12 wont hold on a spin or dry cycle
Dear sheridan pet,
A lot of TIMERS just get to much gunk in them!
With the OLD TIMERS you could open it up and spray it with a can of electrical cleaner (same as they sell for computers) and a lot of the time it would fix the problem!
This may also work on your circuit boards in a new appliance just be sure to read and follow the directions carefully!
I recommend Radio Shack for advice & purchase!
Cost about $10.
I'd open it up and if nothing else obvious look broke I'd buy a can of cleaner and give it a try!
Good Luck!
Hope This Will FixYa!!!! Please Rate Me!!!
Feb 03, 2009 | QuietLine WD-9900 Front Load Washer /...
Hotpoint BWD129 1200 spin - unwanted drying cycles
This is more a workaround than a solution. When you choose the washing programme (say "D") and push the on/off button, two lights will flash, the "door locked" and the "drying" one. Now turn the "drying programme" button until the "drying" light stops flashing (in my case, this is true when I set the drying programme to 40°C). Then start the washing mashine.
Seems like the function of the drying programme button has shifted against the settings written on the button...don't ask me why! Of course, no guarantee but works for me. Please let me know if it does for you.
Oct 13, 2008 | QuietLine WD-9900 Front Load Washer /...
Misplaced faucet adaptor
They're odd ball since they're metric on the washer side. Best bet would be to google Thor washers. They sell quietline parts.
Also, if there is a cheaper alternative source... their tech support guy doesn't mind suggesting it. He sent me to auto parts store for a main belt for mine... worked fine...
Aug 17, 2007 | QuietLine WD-9900 Front Load Washer /...
Dryer Function
Usually your local sears guy will come look at any brand of appliance, for about 60 dollars. thats just to find the problem.
Jul 31, 2007 | QuietLine WD-9900 Front Load Washer /...
QuietLine WD-9900 Front Load Washer / Dryer Logo
336 people viewed this question
Top QuietLine Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a QuietLine Washing Machine Expert? Answer questions, earn points and help others
