Question about Whirlpool Dishwashers
How to unblock the waste pump on a Bauknecht dishwasher?
Bauknecht GSX 4756w when I switch it on and set the dial to the wash setting, I close the door and it sounds as though it is about to start but after 30 secs just starts beeping. When I open it the cycle...
My dishwasher will not start: Most common d/w power is 120 volts, check for 120 volts with a volt meter at the main power harness where it enters into the dishwasher, you will have to remove the lower access panels to get to the power box. Dishwashers also have at least one and most newer dishwashers have two door switches that must be checked. You will find then behind the console at the door latch area. Each manufacture has different designs but this is a picture of what some of the newer dishwasher switches look like.
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
  25. Stainless Steel Cleaning
  26. Strange grinding noises and not washing properly
  27. The dishwasher doors falls down
  28. White filming on the glasses
pls do rate the solution
thanks.
regards.
fixya expert team
Sep 03, 2008 | Bauknecht Dishwashers
My Bauknecht GSF 6550 dishwasher is stuck with error F4. Whar does it mean ? What can I do?
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect. The error indication can be a short in the circuit, check the heater circuit and the pump motor.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
Thank You for using Fixya
Sep 03, 2011 | Bauknecht 24 in. GSF8984 Free-standing...
Hello everybody, I hope that you gona a give me some tips for repairing my dishwasher mashine. A few days ago, the error F2 appears on my dishwasher machine (Baucknecht GSI 5894) I checked the pump for...
Possible the inlet valve has given up and is not allowing water in.
Also possible there is a slight leak enough to shut the water off (safety feature) - Check underneath for a float mechanism and any water there.
Aug 20, 2010 | Bauknecht Dishwashers
Water not draining
Set the controls to off then power off at the mains for 30 mins and then power mains back on and run a drain program or a full wash program. If the water won’t drain away then the most likely problems are the door interlock switch is faulty, the drain water motor is faulty, there is a blockage in the drain outlet pipe or filter – this will need unblocking, there is a blockage in the water pump – this will need to be unblocked, the controller board is faulty – but this generally shows an error code. First turn off the mains power to the dishwasher then check the internal filter and screen and clean it thoroughly. Then check the waste water hose and any outlet valve and make sure that it is unblocked and free of any obstruction or waste material. If you have access to the water pump you can check that it is free of obstruction and is able to turn and that none of the impeller vanes have been damaged. Then if all this is OK then try turning on the mains power and running a hot wash cleaning cycle to flush out any remaining sludge / debris.
Oct 01, 2009 | Frigidaire Dishwashers
Bauknecht GF7199 F7 light has come on
F7 error indicates a fault with the water flow meter .
Check the sump filter at the bottom of the dishwasher, then close the door and turn on the power. then hold the start button with the + and - buttons under the LCD display, until the drain pump starts. This should then reset the dishwasher.
Hope this helps .
Mar 06, 2009 | Bauknecht Dishwashers
What does F7 Means?
The F7 means that the drain filter is blocked or your water pressure is low. Check and clean filters. Good luck !
Apr 25, 2007 | Bauknecht 24 in. GSF8984 Free-standing...
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
