Question about Microsoft Windows Vista Home Premium for PC
Windows Vista Home Premium update error Code 643
Everytime I try to update Security Update for Microsoft .NET Framework 4 on XP, Server 2003, Vista, Server 2008 x86 (KB2861188) it fails with error code 643.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 72 Answers
You will find a solution here:
(you can change language by changing "/en" to your language code!)
http://support.microsoft.com/kb/976982/en
Posted on Nov 22, 2013
3 Suggested Answers
LASITHA-VEGA
  • 428 Answers
SOURCE: error problem while downloading updates
1. Before doing anything else, write down the .NET Framework versions which
are already installed:
How to determine which versions of the .NET Framework are installed and
whether service packs have been applied
http://support.microsoft.com/kb/318785
2. Now see Resolution Method 2 in http://support.microsoft.com/kb/923100
(ignore the title). After running the appropriate/needed tool, (re)install
all .NET Framework versions manually using the download links on the page.
Posted on May 28, 2010
cross123
  • 383 Answers
SOURCE: Error code 643
Try this for starters:
http://support.microsoft.com/kb/923100/
Basically, it involves un-installing .NET Framework Version 1.1 Service pack
1.
Then download and use (Run as Administrator) the Windows Installer CleanUp
Utility, and remove all references to .NET Framework Version 1.1 Service
pack 1 (only!).
Then reinstall .NET Framework Version 1.1 Service pack 1:
http://www.microsoft.com/downloads/detai…
Then run Windows Update again, to install KB929729.
Posted on Jun 25, 2010
Testimonial: "Thanks"
Need someone to install Microsoft .net framework 4
thanks for reporting this issue, please answer the following and try the method after that:
1. What version of NET FRAMEWORK are you trying to install, the 4.0 or the 4.5?
2. With what browser are you trying to do that?
The possible solution:
http://support.microsoft.com/mats/program_install_and_uninstall/
Download the file and then run the Fix it, select the file and install it.
Feb 12, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Windows update failed
You version is no longer supported, time to upgrade
Apr 04, 2017 | Office Equipment & Supplies
Error code 643
1.
pack 1 (only!).
Jun 25, 2010 | Microsoft Windows Vista Home Premium with...
Error problem while downloading updates
May 28, 2010 | Microsoft Windows Vista Ultimate Edition
Windows up date will not install error code 663
This is an error having to do with the .NET framework. You probably have version 2.0.
2. Now see Resolution Method 2 in...
When you try to install an update for the .NET Framework 1.0, 1.1, 2.0, 3.0,
or 3.5, you may receive Windows Update error code "0x643" or Windows
Installer error code "1603" (ignore the title, if need be)
After running the appropriate/needed tool, (re)install all .NET Framework
versions manually using the download links on the page then run Windows
Update manually to install security updates for same.
NB: KB923100 references this page:
http://blogs.msdn.com/astebner/archive/2006/05/30/611355.aspx. Please read
ALL of it as well as the related page
http://blogs.msdn.com/astebner/pages/8904493.aspx before using the .NET
Framework Cleanup Tool.
Or see the "How to obtain help" section of
http://support.microsoft.com/kb/953297
Nov 04, 2009 | Office Equipment & Supplies
Vista error codes 643 and 646
the error codes that you have mention is related to windows update of Microsoft .net framework.
To troubleshoot this issue, I suggest we first perform these steps:
Step 1: Download Microsoft Windows Installer CleanUp utility
1. Visit:
http://download.microsoft.com/downlo...BD/msicuu2.exe
2. Save the file to your computer.
3. Right click "msicuu2.exe", click "Run as administrator" and follow the
wizard to install this tool on your computer.
Step 2: Remove .NET Framework
1. Click Start ->All Programs->Windows Installer Clean Up, click Allow.
2. See if you can find .Net Framework software. If so, remove them.
After that, please restart the computer and perform the following
suggestions to reinstall .NET framework 1.1 and the updates for it.
Step 3: Install .NET Framework 1.1 Redistributable Package and related updates
1. Please download the Microsoft .NET Framework Version 1.1 Redistributable
Package from the following link and save it to the C drive (C:\)
1) Microsoft .NET Framework Version 1.1 Redistributable Package
http://download.microsoft.com/downlo...6/dotnetfx.exe
2) Microsoft .NET Framework 1.1 Service Pack 1
http://download.microsoft.com/downlo...867460-X86.exe
3) Security Update for Microsoft .NET Framework, Version 1.1 Service Pack 1
(KB928366)
http://www.download.windowsupdate.co...d81a178b15.exe
4) .NET Framework 1.1 Service Pack 1 SYSTEM.WEB.DLL and MSCOREE.DLL Security
Update for Windows Vista (KB929729)
http://download.microsoft.com/downlo...929729-X86.exe
Please follow the steps above and if still problem persist please lets us know
Regards,
Om
Oct 20, 2009 | Computers & Internet
Hpqselsk.exe clr error 8004005 & cant open hp director
Its also known as .net framework. Its a software which few applications use for support like chat applications. Below is the system requirement for .net framework to work properly If your system does not fall under the category then you shall uninstall it.
  • upported Operating Systems: Windows 2000; Windows Server 2003 Service Pack 1 for Itanium-based Systems; Windows Server 2003 x64 editions; Windows Server 2008 Datacenter; Windows Server 2008 Enterprise; Windows Server 2008 for Itanium-based Systems; Windows Server 2008 Standard; Windows Vista Business; Windows Vista Enterprise; Windows Vista Home Basic; Windows Vista Home Premium; Windows Vista Starter; Windows Vista Ultimate; Windows XP; Windows XP Professional x64 Edition
Jul 26, 2009 | Office Equipment & Supplies
.Net Framework 1.1 sp1 Install Fails
You need to uninstall and install the latest version of .net frame work
You can download it from www.microsoft.com/downloads
Apr 15, 2009 | Microsoft Windows Vista Home Premium with...
Unable to check for updates with Windows Vista Home Premiun, SP1, 32 bits, error code 80244019 for Windiws Update and 0x80244019 for Windows Defender, last update instaled Jan/01/09
I've been having the same error when I try to run Windows update on a Vista Ultimate machine setup for use with our SBS 2003 server running ISA 2004.
The Solution that I found is this.
When you setup Vista for use with a domain it creates the following regkey with a subkey etc ( policy ) that sets Vista to look for a WSUS server.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate]
"WUServer"="http://serversbs"
"WUStatusServer"="http://serversbs"
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU]
"NoAutoUpdate"=dword:00000000
"AUOptions"=dword:00000004
"ScheduledInstallDay"=dword:00000000
"ScheduledInstallTime"=dword:00000003
"NoAutoRebootWithLoggedOnUsers"=dword:00000001
"RescheduleWaitTime"=dword:00000001
"UseWUServer"=dword:00000001
When I deleted this key and rebooted my PC windows update was working.
Hope this was somehow usefull
source: http://www.vistax64.com/vista-general/3421-windows-update-error-code-80244019-a.html
Good luck
Feb 23, 2009 | Microsoft Windows Vista Home Premium with...
Microsoft Windows Vista Home Premium for PC Logo
123 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
