Question about Tools & Hardware - Others
Battery pack charger black decker 5100235 02 - Tools & Hardware - Others
  • 20 Answers
SOURCE: My Black and Decker Firestorm 24 volt charger is not working
change batteries, your charger should indicate wheather you battery is good or noot on the pause inbetween blinks.
Posted on Aug 15, 2009
  • 4 Answers
SOURCE: Describe your Black & Decker Black
If it is not 2 years old, it is covered under warranty: http://www.blackanddecker.com/CustomerCenter/Warranty.aspx
Posted on Nov 17, 2009
  • 6 Answers
SOURCE: Black and Decker battery charger does not work.
Black & decker chargers and bulbs for the light are JUNK..Don't waste your money on their products.I have 2 chargers for the 24 volt batts-1 is only 2 months old-It blew the fuse {soldered to the circuit board} I'm putting in a fuse holder but don't know the amp of the fuse-I'm starting with a 1 amp slo-blo and going up until it works or goes up in smoke..I had loads of problems with this B&D 3 piece set---It's only 1 year old..Total waste of money..
Posted on Nov 04, 2010
  • 4 Answers
SOURCE: The charger for my Black
For the price a Dewalt costs, you can buy a few reconditioned cheap cordless drills and keep them all charged up. You will always have a standby. You can also check the pawn shops. With times like they are many people are getting rid of good stuff. You can find a great deat but always use a trustworthy pawn shop and get a receipt with the serial number on it. Theives like pawn shops, too.
Happy Hunting!
Posted on Dec 30, 2010
  • 10 Answers
SOURCE: my 24 volt black an
Batterys have a life span associated with them. Typically about 2 years depending on how often you use them and your charging habits. The newer batteries(in the past 4 years) do not have memory, but since it is a black and decker and it is low cost item they may have used an older technology. I am assuming you have checked the obvious such as the charger does work. Battery is inserted properly. An easy task to try would be to buy a new battery and make sure you discharge it before you charge. Run your drill till it stops. Then charge it to see if the charger is working. If not, then you have a charger problem. If so, there may be fuse inside that can be replaced or something simple like a solder joint broke.
Hope that helps
Posted on Jan 23, 2011
I have a black and Decker battery charger that blinks on and off red when I put the lithium battery pack on to charge. What does this mean?
Flashing red light means replace battery
http://www.manualslib.com/manual/16299/Black-And-Decker-5147851-00.html
Apr 18, 2016 | Drills
How to fix a 24 volt black and decker battery charger
You need to post MORE information like what is it doing or not doing and how you use this charger then we can eliminate operator trouble and focus on the charger.
Jun 17, 2014 | Black & Decker Black And Decker FS24C...
My Black and Decker Drill and Hand Saw have brand new battery pack and brand new charger to BE SURE battery is fully charged but still don't work
it is probably the brushes on the motors are wore out or stuck and not making contact. pretty much junk unless you feel confident enough to attempt repair.
Dec 11, 2013 | Black & Decker Black and Decker 18V...
I am in Canada and I cannot get a Black & Decker 36V charger which is LCS36. The B & D 36V battery looks identical to the Dewalt 36V battery but I cannot be positive. Do you know if the B & D LBXR36...
What I do know is that some NiCd 12V Black decker batteries that look similar to the dewalt ones they are charged by the dewalt charger.
But there are 12V Nicd black and decker batteries that they can not be charged due to an extra plastic edge that does not allow to be charged by the dewalt charger.
Now if you do have the dewalt lithium 36V charger and if the black and decker battery is a 36V lithium one and can not be charged due to a plastic edge then I would recommend to risk to destroy the plastic edge in order the black and decker battery to be charged.
Sep 25, 2013 | Dewalt Black & Decker / DC9360 36V Battery
Is it my Black and Decker PS185 18 Volt Battery Charger #418352-03 or my ps145 power pack
You need a volt meter, They are cheap and it will come in handy down the road. The volt meter will tell you if your charger is the problem or the battery has went to battery heaven.
Feb 14, 2013 | Black & Decker Black And Decker PS185 18...
The charger for my Black and Decker PS130 power pack batteries just quit on me. Apparently, other folks have had the same problem so I don't want to replace it. I subsequently bought a Dewalt DW9118 but...
Happy Hunting!
Dec 09, 2010 | Black & Decker Black And Decker 12 Volt...
Versapak battery will not hold charge
If it is an old battery (3 plus years) it probably needs to be replaced. The other failure point is the charger. That can be checked with a volt meter. should be about 4 volts for each battery in the system. 1 battery 4 v, 2 batteries 8 v. Depending on the system it maybe either ac or dc. Try both with your volt metter.
Amazon seems to have the least expensive replacements.
Search for Black & Decker VP143 Versapak Gold Twin Pack.
Jun 19, 2010 | Black & Decker 3.6 Volt VersaPakĀ® Battery...
Aug 13, 2009 | Black & Decker Black And Decker FS24C...
Black & Decker 24 volt battery will not hold a
Click on the link below and you will find replacments
You need to work out if the cost of two batteries is cheaper than a deal on a new drill pack
http://www.svcvacuum.com/black_and_decker/black_and_decker_battery.htm
Jun 01, 2009 | Black & Decker Black And Decker FS24C...
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
