Question about Kyocera FS1370DN Laser Printer
Kyocera 1370 dn keep telling me to add paper even went the trail is full of paper
    Problem Solver:
  • 21 Answers
Try to re-install its driver
Posted on Nov 21, 2013
3 Suggested Answers
  • 62 Answers
SOURCE: call for service error 7410:0112053 on Kyocera FS3900 DN
most likely the drum popped out.
open the left side cover and remove the waste toner bottle..seated just above the waste toner bottle..press on the drum unit that sits above it..you will here it pop back into place .. if you hear it snap back it simply power off than back on printer....
if the drum is seated correctly.. than you need to replace the drum unit
Posted on Jan 16, 2010
Testimonial: "This worked, thanks!!!"
  • 62 Answers
SOURCE: Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
Posted on Jul 07, 2010
Keep receiving message on printer screen to clean machine but no instructions how to do this. Please can you help.
exact message wording will be helpful...
check first all paper path, check especially on the rollers if no paper scraps are left on them or on the mechanism.
go to this site, select your model and download service manual, it will contain detailed procedures:
http://usa.kyoceradocumentsolutions.com/americas/jsp/Kyocera/productdetails.jsp?pid=19757
hope this will help you - do not forget to vote... :-)
Apr 08, 2015 | Kyocera Mita Ecosys FS-C5400DN - 37PPM...
How do you drain holding tanks 1 and 2 on a trail runner 39qbbh
Are you asking because monitor panel says full still? Not uncommon for paper or other debris to hang on probes inside tank and cause panel to read improperly. Close valve, add some water and then pull valve and listen for flow. If that water flows through ok, your likely empty.
Jan 05, 2015 | Heartland 2013 Trail Runner TR 39 QBBH
Even though cassette is loaded it keeps saying "add paper in cassette" and will not print
theres a sensor where the casset meets the back of the machine if it dosnt get triggered it wont see any you can trick it and it will always see paper just keep it stocked of paper
May 30, 2014 | Kyocera FS-2000D Laser Printer
Paper cassette not being detected as full
There is a limit switch that detects when the paper is up.Check it to see if it moves freely.
Apr 16, 2014 | Kyocera FS-4000DN Laser Printer
Kyocera km-2050 print mode error
Print Mode Error is Chenglish for a problem with printing. Press the Print key at the left side of the panel, then the display should tell you to add paper etc
Dec 31, 2013 | Kyocera Mita KM-2550 All-In-One Laser...
The & symbol is on the screen - does this mean the copier needs toner?
i am having toshiba 1370 printing is not clear words are repeatin in paper tell solution
Jan 30, 2013 | Toshiba 1370 Black and White Copier
"add paper cassette"
Turn the printer off. Pull the paper cassette out and push down the green tab down to see if there is any paper jam inside. put the cassette back in and turn the printer on. Worked on my kyocera FS - 1370 DN.
Mar 16, 2012 | Kyocera FS-2000D Laser Printer
Jun 03, 2010 | Kyocera FS- 4000DTN Laser Printer
Error code C70000
Hello, the code 7000 refers to the toner motor, but if you check my blog and there I have the full service manual. I hope you let me serve a Comment
http://tiototos.blogspot.com/ press click
Mar 16, 2010 | Kyocera FS-4000DN Laser Printer
Kyocera FS1370DN Laser Printer Logo
83 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
