Question about Bosch Dishwashers
SPI4465/06 how to connect the thermostat?
I am wiring a Honeywell wifi unit and I used a separate 24v transformer and connected to the c and rc terminal. My system is ac and heat and uses both and rc and rh wire. I wired the rc to the r ter
A thermostat is a switch. It connects 24vac from one terminal to another depending on the request. The 24vac comes from a transformer, usually located in the furnace and connects to the R terminal. Since you are using RH and RC without a jumper between it means there are two transformers, one in the furnace for heating (RH) and one in the air conditioner condenser used for cooling (RC).
Your old thermostat was probably mechanical and did not have a C (24vac common) terminal. Your new thermostat requires power to operate therefore needs a wire connected to a C terminal. I would get rid of the transformer you added and look for an unused wire in the bunch at the thermostat. If it's there connect it to C on the thermostat and to C on the furnace. Remove any jumper from R to RC or from RH to RC depending on your thermostat and connect wires same as the old thermostat.
Jul 04, 2014 | Heating & Cooling
Where is the thermostat on a 1995 buick regal?
the upper radiator hose is connected to the thermostat. the thermostat is inside the shell that connects the shell to the hose. the upper radiator hose is the big black hose. the BIG one. thermostat connects to the engine on top or on the side ish.
Jul 31, 2013 | Honeywell Programmable Thermostat Heater
How do I connect the two thermostat wires from a Honeywell R8184G4009 to a programable thermostat. My old thermostat is not marked.
On the Protectorelay Oil Burner Control R8184G4009, you connect the two thermostat wires @ "T" and the other "T". On the ACE Smart Temp Universal programable therostat, connect one wire to "Rh" and the other wire to " "W". Be careful if you are using this thermostat for A/C. In that case, make sure there is no jumper between "Rh" to "Rc".
Feb 02, 2013 | Honeywell Protectorelay Oil Burner Control...
Dpsr483ea1ww how to replace thermostat
  • Unplug the dryer's power cord from the wall connection. You will be working around the dryer's wiring, which can be dangerous if the power is connected.
  • 2
    Remove the rear cover of the dryer. Most dryers have four screws, one at each corner. Flathead screwdrivers will work for most models, but some require Phillips-head screwdrivers.
  • 3
    Locate the thermostat. The thermostat is circular or oval with a wire connection on each side. Remove the screws keeping the wires connected to the thermostat. Set them aside--you will be reusing them to install the new thermostat.
  • 4
    Disconnect the thermostat from the wires, then unscrew the thermostat from its mounting bracket. The thermostat will easily pull away from the wires once you have removed the screws. Discard the old thermostat.
  • 5
    Install the new thermostat on the mounting bracket. Be sure to tighten the screw enough to keep it secured. Connect the wiring to the thermostat and reinstall the screws to hold the wiring in place.
Jan 13, 2012 | GE Dryers
How to wire condenser and air handler to the t-stat
Assuming this is a standard unit the thermostat connections you will use: Y, R, G, W and possibly C.
Run two conductor thermostat wire to the condenser. The condenser will have two wires to connect. Connect the two conductors to the condenser wires and run them in to the air handler.
At the air handler, connect the two condenser wires to: Y (yellow) and C
Run 4 or 5 conductor thermostat wire from the air handler to the thermostat. At the thermostat, connect the yellow wire to Y, the white wire to W, the green wire to g, and the red wire to r.
At the air handler, connect the thermostat wires: White to w1, yellow to Y, green to G, and red to R
*Y will now be connected to the thermostat and the condenser
*If you have 5 conductor wire to the thermostat, connect the last wire (which is probably blue) to C
At the air handler, connect the last wire (blue) to C. This will enable you to have 24 volts at the thermostat in case the thermostat actually requires 24 volts to operate it.
R=hot
G=fan
Y=cool
W=heat
May 19, 2011 | Heating & Cooling
I have a 2000 taurus can you show me how do I change the thermostat on my car
3.0L OHV Engine
Fig. Exploded view of the water hose connection and the thermostat assembly - 3.0L OHV engines (click over pic for zoom)
  1. Drain the coolant until the level of the coolant is below the level of the thermostat.
  2. Disconnect the upper radiator hose from the water hose connection.
  3. Unfasten the three water inlet connection retaining bolts and remove the water hose connection.
  4. Remove the gasket and thermostat from the water hose connection. Discard the gasket.
To install:
  1. Clean the water inlet connection mating surfaces.
    NOTE The jiggle valve on the thermostat must be in the up position.
  2. Place the thermostat in the water hose connection making sure the thermostat jiggle valve is facing up.
  3. Install the new gasket and place the water hose connection assembly into position.
  4. Install the water hose connection assembly retainers and tighten them to 89-124 inch lbs. (10-14 Nm).
  5. Connect the upper radiator hose to the water hose connection.
  6. Fill the engine with coolant, start the engine and check for leaks.
  7. Stop the engine and top off the coolant recovery reservoir as necessary.
3.0L DOHC Engine
Fig. Exploded view of the water inlet connection and the thermostat assembly-3.0L DOHC engines (click over pic for zoom)
  2. Raise the vehicle and support it with jackstands.
  3. Disconnect the lower radiator hose from the water inlet connection.
  4. Unfasten the two water inlet connection retaining bolts and remove the water inlet connection.
  5. Remove the O-ring seal and thermostat from the water inlet connection. Inspect the O-ring for damage and replace as necessary.
To install:
  2. Install the O-ring, thermostat and the water inlet connection. Refer to the accompanying illustration If you can-t remember how the O-ring and thermostat are positioned.
  3. Install the water inlet connection assembly retainers and tighten them to 71-106 inch lbs. (8-12 Nm).
  4. Connect the lower radiator hose to the water inlet connection.
  5. Fill the engine with coolant, start the engine and check for leaks.
  6. Stop the engine and top off the coolant recovery reservoir as necessary.
Good luck (remember to rate this answer).
Apr 27, 2011 | 2000 Ford Taurus
Where is the thermostat on a 2002 sable?
Try this:
3.0L DOHC Engine
To install:
3.0L OHV Engine
To install:
    Fig. Exploded view of the water hose connection and the thermostat assembly-3.0L OHV engines
    Fig. Remove the upper radiator hose from the water outlet
    Fig. Remove the water outlet retaining bolts and . . .
    Fig. . . . remove the outlet from the engine
    Fig. Remove the thermostat from the water outlet
    Fig. Inspect the water outlet connection for cracks or damage
    Fig. Thoroughly clean the mating surfaces of the water outlet and . . .
    Fig. . . . the engine before installing a new gasket
    Fig. The jiggle valve must be in the up (12 o-clock) position after installation into the water outlet
Jan 19, 2011 | 2001 Mercury Sable
I am replacing an old Lennox thermostat with a new Lux DMH110 digital thermostat. My furnace(oil) has only two wires on the thermostat(heat only). I connected the wires according to directions of new...
Make sure on the furnace that you have the same colored wires connected at the thermostat to R and W. Check for good connections at both locations. You can always test to make sure the unit fires by crossing the two wires together. If the unit fires, you have a bad thermostat.
Feb 17, 2010 | Honeywell Programmable Thermostat Heater
I have a honeywell thermostat model # th5220d1003-0636 & need to know what connections to make for gas forced air heat.
This is a Focus Pro 2 heat,2 cool thermostat. If you are connecting this to a single stage(1 heat) residential furnace then your connections are: At the thermostat the R and Rc therminals are internally connected so you can connect your R terminal wire from the furnace to the R terminal at the thermostat(this is your 24 volt supply for both heating and cooling. The W or W1 wire (heating) from your furnace you connect to the W1 terminal at the thermostat. The W2 wire from your furnace(if your furnace is a 2 stage furnace) you connect to the W2 terminal at the thermostat. The G wire from your furnace(indoor fan) you connect to the G terminal at the thermostat. The Y1 wire(cooling) from your furnace you connect to the Y1 terminal at the thermostat. The C wire(common or neutral) from the furnace you connect to the C terminal at the thermostat.
Nov 14, 2009 | Honeywell Programmable Thermostat Heater
How do i change a thermostat??
buy the correct thermostat and thermostat gasket for your car, then locate the upper radiator hose. Where the upper hose connects to the engine there should be a two bolt hose connection/ thermostat housing ( could be 3 or 4 bolt, but most are 2) these bolts should be removed and then gently lift the hose and hose connection/thermostat housing exposing the old thermostat. note the position then replace the new thermostat just as the old was installed.
Oct 27, 2009 | 1996 Ford Contour
Dishwashers Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
