Question about Motorsports
Turn signal cannot get left turn signal to work when i turn on my headlights in 88 chevy van, checked sockets for corrosion and replaced bulbs, also dash lights come on in the day when i hit the brakes, no daytime running lights
    Scholar:
  • 130 Answers
Reach up from the outside under the rear drivers side the wires you will see go through a opening in the panel .the wires break here every time the opening rubs through the insulation it corrodes and stopps working . fixxed this problem probley 30 times .
Posted on Nov 21, 2013
2 Suggested Answers
  • 4 Answers
SOURCE: Turn signals
My car is more modern 04 but I had a similar problem. Solution to mine was replacing ur turn/tail lights. Check the actual plug it could have corroded terminals. For whatever reason it was causing the indicator to dim so much it stopped working when Lights were turned on.
Posted on Nov 18, 2013
Tail lights not working
ck fuse for rear taillights tis under the dash lower left of steering wheel. or if you still have the manual look in there under fuses.
also look for a bad ground but i doubt that.. if it's both rear out.
fast flashing well here's a chart with all sorts of info.
Problem What To Do Turn signals light, but do not flash Replace the flasher No turn signals light on either side Check the fuse. Replace if defective.
Check the flasher by substitution.
Check for open circuit, short circuit or poor ground. Both turn signals on one side don't work Check for bad bulbs.
Check for bad ground In both housings. One turn signal light on one side doesn't work Check and/or replace bulb.
Check for corrosion in socket. Clean contacts.
Check for poor ground at socket. Turn signal flashes too fast or too slow Check any bulb on the side flashing too fast. A heavy-duty bulb is probably installed In place of a regular bulb
Check the bulb flashing too slow. A standard bulb was probably installed in place of a heavy-duty bulb
Check for loose connections or corrosion at the bulb socket Indicator lights don't work in either direction Check If the turn signals are working
Check the dash indicator lights
Check the flasher by substitution One Indicator light doesn't light On systems with 1 dash indicator:
- See if the lights work on the same side. Often the filaments have been reversed In systems combining stoplights with taillights and turn signals
- Check the flasher by substitution On systems with 2 Indicators:
- Check the bulbs on the same side
- Check the indicator light bulb
hope this helps. may want to print for future reference. :)
hope this helps.
Dec 31, 2017 | GMC Suburban Cars & Trucks
Right front side turn signal does not work replaced all bulbs and checked fuses headlight flashers work when hazards are on front to back except driverside turn signal ,in dash right stays solid left
I don't believe it would be a bad ground for just one light. It could be a wire, a socket connector, or the bulb socket itself. See if the wire has power at the socket when signaling left, with key on. If there is power, probably a bad socket or connector. If no power, check for power coming from flasher-the wire going to front left, or driver's side. If you have power from the flasher, but nothing at the socket, the wire has probably broken.
Good luck.
Feb 06, 2013 | Cars & Trucks
The left front turn signal is not working
Fast flashing occurs when one bulb in the circuit has failed. If the back turn signal bulb is flashing, then a front bulb has failed. Try replacing any remaining burned out bulbs (there may be more than one at the front and/or the back - if the right side is ok, check that side of the vehicle for locations reference). Be aware that the problem can also be one or more bad turn light bulb socket connections - in some cases, dielectric grease may have been added inside the sockets to inhibit corrosion. This is not usually a problem, but to be sure, make sure they are clean and free of corrosion.
Dec 25, 2017 | 2001 Chevrolet Cavalier
2008 Chevy Cobalt front right turn signal is not working. Back right signal blinks fast. Left signals work just fine. I tried replacing the bulb and it did not work. Do I need to replace the...
No - headlight ok.
The reason that the Right turn signal blinks fast is that there is half the normal load (resistance)
on the right side, since the Right front turn signal isn't working.
Since you replaced the Right front turn signal bulb, your problem lies in the bulb socket or
the wiring to the socket.
(1) try cleaning out the socket - there's probably a contact problem in the socket. You
may need to squeeze the contacts together to provide good contact to the socket contact.
(2) if contacts inside the socket are ok, try back-probing the socket - to make sure that the
socket is getting 12V DC to light the bulb. Replacing a bulb socket is easy, and commonly done.
Any auto parts dtore should be able to sell you a new socket - its just a matter of cutting out the
old one, and then splicing in the new one. Most shops will use small wire nuts, buried under several
wraps of E-tape (electrical tape).
(3) if bulb AND socket ok, you have the worst problem known to man - a wiring fault. In this case,
you'll want to run a new wire from the flasher module (under the dashboard) to the turn signal.
Jul 29, 2011 | 2008 Chevrolet Cobalt
Turn signal doesn't work when headlights on
It sound like you have a grounding problem, does the headlight on the left seem dimmer than the right? Check the ground wires and the light sockets for corrosion.
Mar 27, 2010 | 2003 Chevrolet Venture Passanger
Left turn signal quit working. 1969 chevy pickup-
sounds like you have a bad flasher which is usually located near the steering column under the dash. check for ground on front left bulb. may have to replace light socket if ground is good.please leave comment.
Mar 20, 2010 | 1983 Chevrolet K1500
1992 chevy s10 no brake lights or turn signals
Check the front and rear (although probably the rear) turn signal bulb socket for corrosion and/or water intrusion. If you find corrosion attempt to clean (but you will probably have to replace the socket and bulb). For water intrusion you will probably have to replace the break lamp assembly.
Aug 02, 2009 | 1992 Chevrolet S-10
Left side turn signal
it sounds like a bad ground. check all grounds for tightness and corrosion
Aug 11, 2008 | 2003 Pontiac Montana
2003 volkswagon beetle tdi diesel engine
Could be corrosion in bulb socket.. Take out bulbs and check inside socket for rust.. Take sandpaper and insert and twist right side bulb sockets, Good Luck
Jun 25, 2008 | 2003 Volkswagen Beetle TDI
Motorsports Logo
112 people viewed this question
Top Motorsports Experts
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Steve P
Steve P
Are you a Motorsport Expert? Answer questions, earn points and help others
