Question about City Bus Simulator 2010 York - Windows
Screen is not available - City Bus Simulator 2010 York - Windows
I have a amazon fire hd 8 how can i chang the pic. on the lock screen please help
Select a lock screen scene or personal photo to display on the lock screen of your Fire phone.
  1. From Settings, tap Lock Screen, and then tap Select a lock screen scene.
  2. Swipe down through the available scenes, and then tap to preview the lock screen. Alternatively, tap Your Photo to select a personal photo to display.
  3. Tap the checkmark to set the lock screen or the X to cancel.
By default, your phone will rotate through all of the available lock screen scenes daily. To turn this feature off, tap Off next to Rotate Scene Daily at the top of the screen or select a specific scene.
Note: When the battery is low on your Fire phone, Dynamic Perspective lock screen scenes will stop reacting to your movements to conserve battery life. From time-to-time, we will add additional lock screen scenes to your Fire phone when they're available.
Dec 27, 2016 | Amazon Tablets & eReaders
Samsung Digimax D73. Are replacement screens available?
Yes they are available but this is not a home fix, very delicate unit. needs shop repair.
Nov 23, 2012 | Samsung Digimax D73 Digital Camera
Can u repair a cracked screen
LCD screen is nothing but TFT screen (Thin Film Transistors). It is array of transistors. Cracked screen cannot be repaired even a small crack. It can be replaced only provided if available in the market. Mostly it is available with the manufacturer.
-sonsunny
Jul 10, 2011 | Televison & Video
Electronics are good. The LCD screen is very burnt in. Are replacement screens available?
replacement screens are available but very expensive. a better solution might be to sell the electronics and buy a new monitor
Feb 25, 2011 | Computers & Internet
It says i need to adjust the screen settings but when I do it still doesnt work
Sounds like you lost your video driver .. when the happens you go into a default setting that is usually low resolution. If you can access your manufacturers web site no doubt they have an updated driver available
Feb 22, 2011 | Computers & Internet
Screen is going black on my zenith l17w36 tv
are you able to see the boot screen if yes then try to reinstall os, otherwise if boot screen is not available try to clean your pc, RAM etc , then fix them back. Hope it should be available.
Mar 06, 2010 | Televison & Video
My screen is cracked need to be replaced
Your set has 3 screens:
FA812 SuperShield is no longer available
23837472 Lenticular lens is no longer available
23837450 Fresnal lens is also not available.
Check with some of your local TV shops. You may find a non-working TV with good screens for sale.
Good luck
Aug 10, 2009 | Toshiba TP50G50 50" Rear Projection...
Mitsubishi Model # is WD-62531 cracked screen!
HI, there are no replacement screens available for this model unfortunately. Sorry for the bad news there...
Apr 20, 2009 | Mitsubishi WD-62531 Projection Television
43A10 43in
Yes, the screen can be replaced. The screen is comprised of 3 screens. The Fresnal Screen (inner screen), Lenticular Screen (middle screen), and the Protective Screen (outer screen). Please see below for links to these items.
Need all 3 to complete screen assembly.The only screen that is still available is the innermost screen, which is probably not the 1 you need. You will only be able to find the middle (lenticular) and outer (protective) screens from a distributor that has them in stock as no one will be able to order them from the manufacturer.
  1. Fresnal Screen
  2. Lenticular Screen (no longer available)
  3. Protective Screen (no longer available)
Apr 02, 2008 | Toshiba 43A10 43" Rear Projection...
City Bus Simulator 2010 York - Windows Logo
26 people viewed this question
Top City Video Game Consoles & Games Experts
NOEL
NOEL
EnergeeUK
Level 1 Expert
richie46
Are you a City Video Game Console and Game Expert? Answer questions, earn points and help others
