Question about Kyocera Copystar CS-5035 Copier
Getting the message please clean slit glass - Kyocera Copystar CS-5035 Copier
Why does adf cause line in center of printed documents?
Does this happen when when you place a document on the big glass? when you use the doc feeder you are using the small slit glass clean the slit glass if the problem goes away when using the big glass or when you print, then you know the bottom part of the machine is doing ok and its the scanner section which is the big glass area and the slit glass. you may have to to look at the glass at different angles to see the mark.
Jan 21, 2016 | Epson WorkForce WF-3620 Wireless Color...
When I use the scanner, an unsightly thin black line appears on the right side every page. How do I get rid of that black line? Please help! Thanks.
Clean the adf scanner glass (the slit of glass on the left side). All it takes is one spot to cause a vertical line through page
Nov 16, 2015 | Canon PIXMA MX310 All-In-One Printer
I am getting a black line on scanned documents of my HP Officejet 6310 All-in-One Thanks
It would require you to open scanner and clean scanning head unfortunately.
Aug 02, 2015 | HP Office Equipment & Supplies
Black line vertical while scan and photocopy a document
You need to clean the glass with alcohol or a good cleaner. There is toner or something on the glass where the line is occurring.
Feb 20, 2015 | Samsung SCX Office Equipment & Supplies
There are lines appears in the paper if i took the photo from feeder ricoh 2045
Does this happen when copying off of the glass? No? Clean the slit glass on the left. Still does it? Turn off the copier, remove the slit glass and the original glass. Gently slide the mirror carriage to the right. Carefully wipe the mirrors with a microfiber cloth and with a can air blow around the exposure lamp area. Reassemble and test. The most common problem is gunk on that slit glass which is easily remedied using a microfiber cloth.
Nov 20, 2014 | Ricoh Office Equipment & Supplies
How to fix Error code C-8104 KonicaMinolta
The small (slit) glass that is to the left of the big glass under the document feeder, there is motor that moves the slit glass there might be a staple or something preventing that motor to move the glass as documents go bye trying to keep the glass clean. Reset in service mode. will prevent use of the document feeder, Might have a bad cable to that unit.
Jun 15, 2014 | Konica Minolta Bizhub C452 Color Copier,...
Black cq when using document feeder
clean the slit glass its the small maybe two inch wide glass to the left of the main glass clean it good use windex or alcohol that will get rid of you problem have a great day
Apr 18, 2014 | Kyocera KM-1505 Copier
Clean slit glass
the slit glass is dirty. clean it. see if there is a secondary slit glass (depends on the adf). you can turn off the message in service mode.
Apr 17, 2013 | Kyocera Task Alfa / Copystar 400ci / 500ci...
Sends blank fax
Dirty scan glass
Clean slit of glass extremly well, it is a small slit rectangler section of glass before copy glass on the scanner.
Glue, Liquid paper are common finds on the glass in this area, While you have the lid up, clean white reference area (on lid directly on top of scan glass when lid is closed)
Feb 04, 2008 | Brother MFC-8440 All-In-One Laser Printer
Black Line printing on copies
Just clean the glass top of the scanner and the slit of glass on the left hand side of the scanner.
Dec 04, 2006 | Canon PIXMA MP780 All-In-One InkJet...
Kyocera Copystar CS-5035 Copier Logo
19 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
