Question about Sewing Machines
Bobbin size for American Home Believe Model AH600
Can I only use the small bobbins supplied and if so where can I get further supplies
The bobbins depend on your machine make & model. Use the bobbins that came with your machine. Not sure what you mean by "small" bobbins. There are quite a few bobbin sizes but bobbins are usually specific to your machine. Singer #15 bobbins are common and readily available at most sewing shops but definitely will not work on all machines. Some bobbins are only a millimeter difference in size but will most likely cause problems with your machine. Just because they may fit in your machine, doesn't mean you will get the best result, if not broken, tangled thread, etc. Sometimes, those bobbins will get stuck in the bobbin case making it difficult to remove. If you want to order more accessories, search for:
Make Model accessories
Mar 12, 2018 | Sewing Machines
I have a New Home 622 sewing machine. Can I use a double needle in it ? Thanks.
Most machines can use a twin needle as long as the presser foot and needleplate have a wide opening to allow the needle to penetrate without restriction. However, I believe sewing machines whose bobbins load on the side (as opposed to front-loading bobbins) and the needle faces the side of the machine would not be able to accommodate a twin needle. (Am unable to locate a picture or any information regarding your particular model.)
Jan 15, 2017 | New Home Sewing Machines
"bobbin size
Consult your owner's manual to find out what bobbin to use in your machine. There are many bobbins available, some will actually fit in your machine, but they may be a slight bit different size that will negatively affect your machine's operation. If you don't know which bobbin to buy, take the machine's manufacturer name and model to a sewing shop and ask if they can sell you the bobbin for your machine. Better yet, find a local dealer who supports your particular machine's manufacturer. You may even find the appropriate bobbin online by searching:
Manufacturer + Model + the word "bobbin"
Dec 30, 2015 | Sewing Machines
Need Bobbin size for Janome Jemsilver model 662
There are three sizes (classes) of bobbin that most machines use. If you have the old bobbin and can measure it this link will help you determine which class you need.
What Size Bobbin
Jul 19, 2014 | Janome Sewing Machines
What size bobbins for model 3600?
Hello
There are many bobbin styles which still measure as you have indicated, however they do not "fit" correctly resulting in poor to no stitching.
Your local reputable sewing machine retailer will be able to provide the correct bobbins for your sewing machine 'make' and 'model'.
Happy stitching.
Jun 12, 2014 | Husqvarna Sewing Machines
Bobbin size for American Home Believe Model AH600?
check with a1sewingmachines.com and see if they can help you with the bobbins.
Nov 21, 2013 | Sewing Machines
Won't sew! Loads of top thread bundles up around bobbin casing.
First... make sure you are threading it correctly. It MUST be threaded with the foot up.
Do a test seam. Make sure you put the presser foot DOWN when you sew.
Make sure you grasp and hold the bobbin and top threads as you begin the seam. (this is good practice for any seamstress on any machine.
If you still get loops, tighten top tension.
Also check the bobbin case for burrs. drag a finger nail along edges to feel for it catching. If you find one take a small bit of extra fine sand paper and file it off.
Good luck
Nov 12, 2012 | Sewing Machines
What size needle does the singer merrit 8734 use
here is a free downloadable manual from singer,here's the link
http://www.singerco.com/uploads/download/672_8734-8834.pdf
in the manual in the accessories it tells about the needles,
on page 7, I believe,, general sewing singer size 2020,,
& knits, stretch, elastic size 2045
plastic bobbins
Aug 30, 2012 | Singer Merritt 8734
On my old Singer 834, the bobbin thread puts out
Are you sure the bobbin thread is in the case correct. it also as tension support.Or is the bobbin thread right . When you make your bobbins that also should have tension.
Aug 15, 2009 | Singer Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
