Question about Canon Office Equipment & Supplies
Mg 5350 6502
Greetings, I have a big problem when I fill the ink in the cartridge and put it in my printer Wrote Error 6502. Online, I've tried a hundred variations of the resetting, etc. but so far has not managed to enable the printer. Please advise me what to do! Maybe is the problem only in non-original cartridges or chip. Thanks for the response!!!
  • 794 Answers
Solution 1:
  • Unplug the printer.
  • Remove the faulty Cartridge
  • Plug in the printer and press and hold power button
  • Keep it held down. Press Resume twice, and this should reset the fault.
Solution 2:
  • The last cartridge installed may be faulty.
  • Install a new cartridge
Solution 3:
  • When error is indicated, turn power switch off so green light is extinguished.
  • Hold down resume button and hold down power button so both are held down at same time
  • When green light comes on, continue holding down power button and let resume button go, then press resume button twice.
  • Let power button go.
  • Press resume button four times, power button should be released before doing this.
  • Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on.
Posted on Nov 22, 2013
SOURCE: replacing NON Manufactored ink cartridges in EPSON PHOTOS STYLUS R380
I had the same problem, was tired of Spending $100 / refill - so I tried a set of Generics that were "Guaranteed" to work - well - they didn't. Apparently Epson changes the programming on the ROM on the actual ink cartridge - and if you buy an older generic cartridge it will not work if you have a newer printer - as the ROM coding is incorrect.
I do however, have a solution - that I found works. Continuous Ink Systems. I went to Super Jet USA (www.superjetusa.com) - and purchased their continuous ink system. I think it was 60 bux and it comes with 100ml of ink in each color + 18 ml in each continuous cartridge (so 118ml in total for each color) (Regular cartridges only have 18 ml). So the equivelant of just over 6 refills... Normally - 6 sets of Epson (rip off super high price make someone rich) cartridges would cost me roughly $720.00 with taxes and what not.
This system Cost me 60 bux + shipping.
Now I am not a mathamatician, a numerologist, or anyone who things long division is fun (thats just sick) - but I dont think it takes a genius to see this is one TERRIFIC deal.
And yes - The system works PERFECTLY in my Epson R380 Printer - first try - no fuss - no muss - Extremely happy I tried this solution
NOTE: I do not work for, or am in any association with Superjetusa - I just think when you find a company that is good to deal with, delivers what they promise, and gives you a good price - then you should tell the world.
Posted on Feb 05, 2008
SOURCE: 8250 HP INK EXPIRED MESSAGE
I had same problem, and i solved it.
I opened my hp 8250 and removed it`s battery. It is located on left side of the printer, on the main board. You need to remove plastic covers , and then remove 3 screws holding board. You can move board just enough to get damn battery out of there. Now it works perfect!
I can send you some piccs if you need help.
Regards
Sasa
Posted on Nov 02, 2008
  • 295 Answers
SOURCE: I Filled Kodak ESP5 Ink Cartridge, but error remains
Try to reseat the cartridge 2-3 times. probably the carrtidge is defective. call kodak @ 1800 421 6699 and they will replace the cartridge for you free of cost.
Posted on Sep 21, 2009
  • 191 Answers
SOURCE: Reset Canon printer chip
you can override ink check status and manually reset it in drivers options
Posted on Sep 22, 2009
pineworks
  • 4041 Answers
SOURCE: E,5 error in Canon MP190 printer after adding ink
Hi there ok
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 07, 2010
No ink catridges on cannon mg 5420
It could be your ink cartridges are not compatible. Are you using ink from cannon?
Sep 12, 2014 | Office Equipment & Supplies
After printer said ink cartridge was empty I removed it & found it was not-I put it back in printer & now getting error message that the cartridge is used & needs to be replaced. How can I
your only option it to replace it with a new one . printer mfg's have chipped the cartridges and they can not be reused.unless the chip is recoded as new .
Aug 16, 2017 | Ricoh Aficio GX3050N Printer
How do I reset Canon MG 4170 ink level
I have not used your particular model of printer or these specific cartridges, but the UK versions of these cartridges cannot have the ink level estimate reset. However it is not necessary to do so to continue using these cartridges.
Instead when the cartridge believes it is empty the printer will ask for a prompt from you in order to continue printing (usually in a rather lengthy message). We made a short video on the subject:
Jun 08, 2012 | Canon PIXMA Office Equipment & Supplies
Error code 16
Hi there .the error e1.6 on Canon Multifuntionals ( MP, MG , MX ) is :
DESCRIPTION:
Ink has run out.
SOLUTION:
Replace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress and you want to continue printing, press the Stop/Reset button for at least 5 seconds with the ink cartridge installed.
Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing.
The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
I hope this information will help you
Dec 22, 2011 | Canon Office Equipment & Supplies
Hello I have a Lexmark X4650 printer. I was printing earlier this morning and then suddenly, the printer stopped working and gave the error message that left cartridge is incorrect (I haven't...
Good job in re-seating the cartridges into the printer. Try to insert a different known working cartridge to determine if your other cartridge has gone bad.
Jul 24, 2011 | Lexmark X4650 InkJet Printer
MP140 can't recognise the black cartridge that I've just installed. Error code 4 - any ideas? I've tried the manual - nothing, and not much luck online - Thanks
Error code 4 normally indicates that there is no unk, and the solution is by installing a genuine cartridge, Try to use Black PG40 remanufactured Canon printer ink cartridge. This cartridge is a high capacity cartridge which has been filled with 23ml of ink compared with the 16ml (Black) that you get with the originals. Compatible with: Canon Pixma MP140. if this error still occur it is better that you try the following procedure below:-
When you insert a refilled ink cartridge into your Pixma MP140 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won’t get the warnings again because the ink levels won’t be monitored by the printer.
Thanks
Oct 12, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Hp photosmart d7200 erro Oxc18a0001
Filling your cartridge with non-HP ink won't cause an error. There are basically two reasons for ink system failure, The cartridge is no good or the ink system has failed. Some of these machines can be reset. But, try replacing cartridge first.
Jul 16, 2009 | HP Photosmart D7460 Printer
Cartridge error
How I solved this problem was, I took out the color cartridge (which seem to be the one giving the error message) and worked only with the black ink (and chose print black and white )
My color ink cartridge had been refilled at Walgreens. The Black ink cartridge is an original Lexmark
Oct 22, 2007 | Lexmark X3480 InkJet Printer
61 people viewed this question
old marine
old marine
