Question about Konica Minolta magicolor 2300DL Laser Printer
We have this color printer at a location and they have just changed out the drum in the printer. After talking to them they stated that it now says that it is full. Is there a reset on the printer that they can do to clear out the error so it will operate normally. As of right now it is not working right.
  • Asquared Nov 12, 2007
    Just replaced the Drum, and my printer is not printing color copies correctly. It looks spotty....Help? Have plemty of color ink and the printer is showing 100% full for Drum.
  • jeff78704 Feb 15, 2008
    I have same problem, but with ink It says "replace black ink". I do it, and it continues to say "replace black ink."
  • Konica Minolta Master
  • 705 Answers
What is "FULL"? I fyou mean the drum, then you want the display to show that the drum is full - this is correct for when a drum has been changed.
Maybe you mean the toner bottle is full. If so, emptying it will resolve the issue.
Posted on Oct 13, 2007
SOURCE:
LaserJet Pro 200 M251nw - My color printer keeps printing every page with colored bands. Below is what I have done to troubleshoot this printer: a hard reset, printed a cleaning page.
Are you using genuine HP cartridges? The generics have always given me trouble & I don't even bother anymore, no matter how good the deal seems.
Oct 24, 2016 | HP Color LaserJet Pro 200 M251nw
Need to reset Drum
open the hood then go to menu and go to rest drum , it will accept it now , nice talking to you
Dec 13, 2012 | Brother MFC-9320CW Color Laser Printer -...
Since i install a new drum, i have smudges on my copies how do i fix
    Sir/Madam
    If you have Brother Printer print quality problems, Then I suggest You clean the Your Brother printer drum unit as follows:
    Small Spots on the printed pages:
    If your printed document has any small white or colored spots, follow the steps below.
    1.Open the manual feed slot cover.
    2. Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
    3.Using both hands, put one blank sheet of paper in the manual feed slot until the front edge of the paper touches the paper feed roller. Wait until the machine automatically feeds the paper. When you feel the machine pull in the paper, let go.
    Note
    • Make sure that the paper is straight and in the correct position on the manual feed slot. If it is not, the paper may not be fed properly, resulting in a skewed printout or a paper jam.
    • Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
    • Do not put paper in the manual feed slot before the printer is in the Ready state. An error may occur and the printer will stop printing.
    4.Make sure that the printer is in the Ready state. Press + or - to choose "Color Correction". Press OK.
    5.Press + or - to choose "Drum Cleaning".
    6.Press Go. The printer will pull in the piece of paper and start cleaning the drum unit.
    7.When the printer has finished cleaning, "Completed" appears on the LCD.
    Press Cancel so that the printer returns to the Ready state.
    8.Repeat steps 3 to 7 two more times using a new blank sheet of paper each time. Upon completion, please discard the used paper. If the print problem still remains, please go to the Step 9.
    Large spots on the printed pages:
    Hint If your printed page has colored spots at 94mm (3.7 in) intervals, please follow the step below.
    1. 9.Turn off the printer power switch.
    10. Fully open the top cover by lifting up on the handle (1).
    11. See the print sample to identify the color causing the problem. The color of the spots is the color of the drum you should clean. For example, if the spots are cyan, you should clean the drum for cyan. Take out the drum unit and toner cartridge assembly of the color causing the problem.
    Caution
    • We recommend that you place the drum unit and toner cartridge assembly on a clean, flat surface with a sheet of disposable paper or cloth underneath it in case you accidentally spill or scatter toner.
    • To prevent damage to the printer from static electricity, DO NOT touch the electrodes shown in the illustration.
    12.Push down the green-labeled lock lever (1) and take the toner cartridge out of the drum unit.
    Caution
    1. Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
13.Put the print sample in front of the drum unit, and find the exact position of the poor print.
14.Turn the drum unit gear by hand while looking at the surface of the OPC drum (1).
15.When you have found the mark on the drum that matches the print sample, wipe the surface of the OPC drum with a dry cotton swab until the dust or glue on the surface comes off.
DO NOT clean the surface of the photosensitive drum with a sharp object.
Note Make sure that you put in the toner cartridge properly or it may separate from the drum unit.
17.Slide each drum unit and toner cartridge assembly into the printer. Make sure that you match the toner cartridge color to the same color label on the printer.
C- Cyan, M- magenta, Y- Yellow, K- Black
18.Close the top cover of the printer.
19.Turn the printer power switch back on.
If your question was not answered, please check...
Clean the drum unit Brother
Or
If You still need Brother Printer Help I suggest You follow Us On for :
Brother Printer Support
Nov 07, 2012 | Brother Dr420 Black Drum Unit Cartridge
Brother HL-4040CDN Laser Color Printer Printing Quality Issues
Hey Robb, Laster printers don't have print heads dummy, that is for inkjets. Just close your mouth if you don't know anything.
Dec 03, 2011 | Brother HL Office Equipment & Supplies
Ghost image towards bottom of page. Does this indicate my drum should be changed out?
Hey
if its a standard black toner printer your drum will need changing its probably not the photo drum itself but the cleaning wire that is attached to the drum unit is dirty...but there is no way to fix this but to replace the drum module..
If its a color toner it's the same thing the "drum" needs to be changed but in a color toner printer it's actually called a transfer film.
hope this helps,ben
Jan 04, 2011 | Dell 3010cn Laser Printer
We have recently bought a second hand OKI C5200 Colour Laser Printer and even though the black and white print seems to be great the clour is coming out with coloured streaks, what would you recommend?
One or more of the drums may be defective. Swap the black with another color and print a document. If that color printed the charectors ok, then continue the test with the other drums each taking a turn in the Black drum position until you find the bad drum.
Oct 08, 2009 | OKI C5200n Laser Printer
How do I change the drum in a ir2880 copier? I cannot locate the drum units
open front door lower large blue handle below the toners there is a cover with a latch on it move the latch the door will open the drums are behind that cover
Oct 06, 2009 | Canon imageRUNNER iR C2880 Color Copier
I need to know what buttons to hold down on a riso 390U in order to get a different color ink to print in a drum
That's almost correct. Risos have two kinds of drums: black and color. The black drums have to stay black. If you want to print color you need to a) buy the appropriate color drum or, b) change the color in a color drum you already have. If you change from, say, blue to red, you're going to have purple for a little while. It's not a really efficient way to get things done.
Oct 05, 2009 | Riso RZ390 Duplicator
Minolta CF910 Copier
CF910 is Minolta first generation color copier, does any color like green or blue color have the same problem, there will not be any error message to change image units. only toner. The machine has only one drum, and each color gets a chance to place its color on the drum. Paper is held by the big plastic drum next to the drum. You should think about having a service technician come out and look at it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 30, 2009 | Konica Minolta DiALTA CF910 Copier
Konica Minolta magicolor 2300DL Laser Printer Logo
208 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
