Question about AO Smith 1 1/2 HP 115/230V 56C Replacement Motor
Wiring spec for 327P111 A.O. Smith motor - AO Smith 1 1/2 HP 115/230V 56C Replacement Motor
2 Suggested Answers
john224
  • 1378 Answers
SOURCE: I HAVE AO SMITH MOTOR BL6414 HOW DO I WIRER IT UP
The BL6414 motor is shaded pole and does not require a capacitor.
Posted on Jul 12, 2009
Wiring diagram for century pool pump motor model b977
check on side of motor should show low and high voltage wiring if not email AO smith
Apr 13, 2013 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
A.o. smith f48g56a76 wiring diagram
loo kon side of motor for 115 volt wiring they normally come wired for 220 volt
Dec 02, 2012 | AO Smith A O Smith Motors Century 1hp 115v...
Need to know what wire goes to were..on a smith & jones modle 67841 compresser motor..p1 p2 t2 t3 t4 t5 t8..to what wire black white green
Hey guys, this motor is reversible. I have it wired to turn clockwise(according to diagram),
green to ground;
L1 (black) to P1;
L2 (white) to T2-T4-T8;
P2-T3-T5 together .
When I plug it in, the motor turns counter clockwise and the on/off switch does not work. How do I fix?
Oct 27, 2012 | AO Smith A O Smith Motors Centurion 1.5hp...
Im replacing a 2 speed Hayward motor with a AO smith 1 speed motor. I need to no how to wire the 1 speed
to wire a single speed motor you use only the black, white and green wire. there is usually a wiring diagram on the side of the motor to show how this is done.
no wiring diagram then put the black wire on the L1 or H1 post and the white wire to the common and of course the green to ground
Aug 21, 2011 | AO Smith A O Smith Motors Century 1hp 115v...
I have a 1hp 3450 RPM single speed AO Smith motor on my pool pump and it just quit. My question is can I replace it with a two speed motor? If so I'm sure I will need some type of controler to change the...
Some motors have two speeds listed on the spec plate, study the wiring diagram on the plate to see if the speed is set by the way you wire it.(which leads you twist together at the motor)Good luck
Nov 22, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
I have a Trane XE1200 condensor for which I bought a replacement fan motor, same specs as the original G.E. motor. The original G.E. motor was wired to a dual capacitor, which is also wired to the...
OK, locate the terminals on the capacitor marked "HERM"(Compressor lead), "FAN", and "COM".(common)
HERM and COM remian as they are.
The wire going to "FAN" (usually brown) will be placed on either terminal of the new capacitor. (This is the ((usually brown)) wire comming off of the fan motor.) An additional wire needs to be run from the other terminal of the new capacitor to the "COM" on the old capacior.
What you are doing is bypassing the fan side of the old capacitor but still using the compressor side of the old Cap.
The fan should have a wiring diagram on it to help identify the wires if there is no brown wire. The other two wires will be identified on the wiring diagram as well, but one typically goes to the contactor and the other to the board.
Sep 07, 2009 | Heating & Cooling
Jul 12, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
Wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Jun 17, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
AO Smith 1 1/2 HP 115/230V 56C Replacement Motor Logo
150 people viewed this question
Top AO Smith Plumbing Experts
David Baisa
Lawrence Oravetz
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
