Question about Saws
Must remove arbor housing form pin connecting ito to the cradle
The teeth are broken on the arbor housing part#30420 necessitating replacement. The arbor housing is essentially frozen to the pin that connects it to the cradle. The housing can be moved with great effort and a 24in pip wrench. I have tried over the last week several things after removing the retaining clip. I used PB penetrating oil several times. I tried tapping it out in both directions with essentially no success. I tried heating it twice and tapping it out. I cannot attach a gear puller because there is essentially no space between the arbor and the cradle. Other than cutting it off with a torch have you got any suggestions on how to remove from the pin.
    Sergeant:
    Champion:
  • 266 Answers
If you can post some pictures, I think I can help you. If you removed the pin there should be nothing holding it from moving. if it is threaded on, try to turn it in the opposite direction than it turns to work in. could you also post the make and model number so I can locate a guide.
Posted on Nov 21, 2013
2 Suggested Answers
al_kupchella
  • 843 Answers
SOURCE: My saw problem has to do with changeing the blade.
The nut is binding on the arbor because the threads are buggered up or clogged with something. It could be the nut (which is probably brass and soft) or the arbor (which is steel). If it got a little cross threaded, the damage will be on the nut. It might be the arbor if the arbor took a whack. Once you have it apart you should be able to see it - although the damage might be pretty small. You aren't likely to have a tap and die to run through the threads, but you can probably fix it with a little rotary tool (like a dremel) using a small disc. If it is the arbor you can use a triangular file. Or you can buy a new nut. I hope this helps.
Posted on May 17, 2010
I need to change the sawblade on my mod.# 7740A B&D radial arm saw, but brake button is frozen. What is the best way to unstick it?
the brake for most saws, routers, etc, is a sprung pin that fits into a slot directly on the arbor. Most times, sawdust and debris gets it stuck. Sometimes, the pin gets worn and rounded and cannot find purchase to stop the blade/bit from turning. I have used spray contact cleaner to unclog the jam up. otherwise, you have to do a little disassembly to get to the pin to unstick/replace the brake assembly. use a scrap piece of wood between the teeth and guard as a wedge to stop the blade so that you can turn the arbor nut.
Jun 22, 2015 | Saws
I have a peg perego gaucho grande and used the kids wheel overhaul kit two months ago and just today removed the pin for the high low function ... Now my gaucho does this choppy sound when in low spee
sounds like you have some broken teeth in one or both of your gear boxes, see which side the sound is coming from, and you can either open the gearbox and remove the broken teeth or just buy a replacement gearbox
Sep 13, 2014 | Peg Perego Gaucho Superpower
How to remove arbor bolt to change blade
Best thing to do is to just rest the blade teeth against a peice of scrap wood, and use the allen key/spanner to undo the bolt. As the bolt undoes in the direction of the cut, the blade teeth should dig in and stop it turning. If the blade lock isn't working anymore, it could mean that it has broken inside, so be careful, incase there is a bit of loose metal in the gearbox, it will be quite catastrophic if it gets caught in the gears.
Jul 18, 2014 | Bosch 7 - 1/4" Skilsaw Circular Saw
How do you tell if the gear box is bad in a 315218050 table saw.
Its probably not designed to be stripped and serviced, especially if parts are pressed together. These do not normally have gearboxes so you are trying to service the motor itself. If the motor does not have small panels to allow you to change the motor brushes, it is not meant to be serviced, and you should replace the motor. These saws sell used on ebay for $60.
Dec 21, 2013 | Tools & Hardware - Others
Rear door latch is broke
I had to do this, too... Mine cost me $70 at the local dealer (they even got it in the same stock paint color). Tip: buy a few of the inexpensive replacement plastic pins for your inner panel when you buy the handle housing, as they tend to break easily. You can pop the old pins by sticking a narrow straight screwdriver or a butterknife under the panel near them and twisting... once it's off, the screws for the old handle housing are fairly easy to spot (just remember where the housing bolts on from the exterior are located). Now that those are off, realize that the thing is probably hanging from your trunk by the wires connecting the license plate lights and the handle, itself They can be removed from the old, broken housing with a phillips #2 (normal size) screwdriver, and then the wires have a quick-disconnect so that you can pop the lights and the handle off w/o cutting the wires. Pop them off, slide the wires through your new handle housing, and screw them back on. then slide the handle housing into position (lining up the screws that are molded into the housing with the adjacent holes). You'll have to kind of hold it in place as you raise the trunk hatch to full open position, but once it's up, gravity is your friend. Use the screws that were holding the parts from the broken housing to re-affix the new one, and you're done.
Feb 29, 2012 | 2006 Scion xB
WENT TO BUY A DW713, AND NOBODY KNEW THE CORRECT PROCEDURE ON HOW TO CHANGE THE BLADE
sjacquesjr-
I own the dw713 - it a good saw.
To change the blade, first unplug the saw. Bring the blade guard all the way up. When you do you should see a black star drive bolt on the left side of the blade housing, toward the front. This bolt must be loosened far enough to allow the guard to rotate up far enough to expose the bolt holding the blade to the arbor. With the guard out of the way, press in the arbor lock on the motor housing (its a black or gray button) while slowly turning the blade. You should feel the arbor lock engage and the blade no longer turn. The rest of the steps you have to do while holding this button in...an extra set of hands would help about now. Using the wrench that comes with the saw (its mounted at the back, near the dust port), unscrew the arbor bolt. The arbor bolt is reverse threaded to match the blade rotation, so it will be counter-intuitive when screwing/unscrewing this bolt. To unscrew, push the wrench away from you. To replace the blade, just reverse these steps. When putting on a new blade, don't forget to orient the blade teeth in the direction of rotation. Happy cutting!
If this has been helpful, please take a moment to give me four thumbs up.
Regards,
DIYpro
May 05, 2011 | Garden
My saw problem has to do with changeing the blade. I'm useing a thin kirf blade. When I change the blade I have to put a wrench on the arbor next to the pulley to keep the arbor shaft from turning when I...
May 17, 2010 | Craftsman 10" Table Saw
How to change the saw blade
Adjustments
LARGEHEXWRENCH
TO REPLACeTHE BLADE
See Figures 43 - 45.
 Unplug the saw.
 Lower the saw blade, raise the blade guard, and remove the throat plate.
 Make sure the bevel locking lever is securely pushed to the left. Raise the saw blade to its full height by turning the height/bevel adjusting handwheel clockwise.
 Using the smaller hex wrench, insert the flat open end into the flats on the arbor shaft.
 Insert the closed end of the larger hex wrench over the hex nut. Holding both wrenches firmly, pull the larger wrench forward to the front of the machine. Make sure the blade nut is securely tightened. Do not overtighten.
Check all clearances for free blade rotation. See To Set the Scale to the Blade. In cutting operations, the scale will be set to the side of the blade where the cut will be measured and made.
To replace the blade with an accessory blade, follow the instructions provided with the accessory.
To install a standard blade:
 Place the new blade on the arbor shaft (the teeth must point down toward the front of the saw to work properly).
 Place the blade washer and the blade nut over the blade arbor. Be sure the dome side of the blade washer faces out from the blade and that all items are snug against the arbor housing. Tighten securely.
SMALLHEXWRENCH
Fig. 43
Blade
Bladewasher
arbor shaft
Bladenut
Fig. 44
BLADEGUARD
THROATPLATE
spreader
BLADE
Fig. 4535
ADJUSTMENTS
 Rotate the blade by hand to make sure it turns freely.
 Lower the saw blade and reinstall the throat plate.
NOTE: Securely tighten throat plate screws. Do not allow the throat plate to bow up above the table surface.
Sep 18, 2009 | Saws
Radio works in the car cradle but not in the house cradle.
I posted on this myself looking for solutions, and then discovered the solution myself. The base pin connectors at the bottom of the receiver apparently become loose, and in order to make a good connection you need to push/pull the top of the receiver forward to achieve a connection. I first developed this problem in the home cradle, and used the car cradle in the house, then had the same problem with the car cradel. I fix it by jamming something between the receiver and car cradel at the top to force and hold it forward). In the home base, I pull it forward at the top, and prop it that way with something heavy behind it. No one ever posted on how to take the unit apart and actually fix the loose connection.
Jan 13, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
Hobart p660
There are 2 set screws.Make sure their both out,if for some reason there is only 1 set screw these are your options.Heat the shaft and remaining pin with a mapp torch (you can buy them at home depot,lowes for $40 bucks),heat it up really good then get a punch and try to knock out the pin,option 2---if you cant get the pin out then youll have to replace the shaft and if thats the case you should also clean out the planetary and replace the bearings and seals.If the hole in the shaft is oblongated or worn you should probably replace the shaft because the dough hook will rock the pin back and forth breaking the pin.Also look inside the hook and make sure thatI its not worn out where the pin sets.IF you see thee hook or shaft pinhole worn you will break the pin again if you are able to replace the pin.I work for hobart and service mixers regulary,if you need part numbers or advise let me know.
Nov 27, 2007 | Hobart P660 Stand Mixer
Saws Logo
54 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
