Question about Air Intake Hose Ssangyong Rodius 2 7xdi Hump Bellow 3 25-3 5 Inch Od
HI I HAVE AN ACTYON SPORT THIS VEHICLE CUT OFF WHILE DRIVEING .Iran a diagnostic and it picked up transponder error the key light is flashing but this van does not have a transponder key plse help
  • 787 Answers
If I'm understanding you correctly, you're saying you DO NOT have the master key that came with the vehicle, I will assume you're using the secondary or the valet key for the car. On most vehicles if you've lost the master key and now the "Transponder" is flashing, you're kind of out of luck. If it's like other vehicles, your TRANSPONDER is the vehicle IMMOBILIZER. Means the car won't usually even crank over. You can try to have it towed to the dealer and have them re-enable it (turn off the transponder) or they may have to replace the whole ECU, Transponder and a new master key in order to get your vehicle going again.
Posted on Nov 21, 2013
I recently changed ignition switch to pt cruiser one of the new keys for the switch work & one work but car alarm light blink and the car cuts off
You need to have the original key close to the ignition so the transponder will pick it up. The easy answer would be go to your local dealer and have a new key cut with the right transponder to the new lock cylinder.
Nov 24, 2015 | Cars & Trucks
1998 Chrysler Sebring entry system keep it from starting. The light on tge dash flashes indicating it isn't getting a signal fron the key. I remove the trim under the dash, around instrument panel and...
sounds like the battery in your key is dead or something like that. Call a Home Depot near you and see if they can cut you a key for your vehicle (have year make model and vin number handy) if your vehicle has security/ immobilizer then you MUST make sure that hope depot cuts you the correct key with the built in transponder. This COULD be your problem, it is my educated diagnosis without having seen or scanned the car. Im here if you need help. Good luck!!
-Tim
Mar 26, 2015 | 1998 Chrysler Sebring
How toprogramm car key toyota matrix
  • 1 First you will need to purchase a blank Toyota transponder key. You can do this from the dealership, a locksmith, or an online source such as eBay. Once you have the key, take the blank key and the master key to a locksmith that he or she can duplicate the key. This will be much cheaper than the dealership.
  • 2 Now that you have the newly cut key and the master key, you can program the Toyota transponder key. Sit in the driver's side of the Toyota vehicle. Press and release the brake and gas pedal simultaneously.
  • 3 Insert the master transponder key. Do not turn it. Push and release the gas pedal 5 times within at least 15 seconds of inserting the master key.
  • 4 Press and release the brake pedal 6 times within 20 seconds of completing step 3, then remove the master transponder key.
  • 5 Insert the newly cut transponder key into the ignition, but do not turn. Press the gas pedal once.
  • 6 Wait up to 2 minutes or whenever the security light on the dashboard turns off. Once the light goes off, remove the new transponder key and press the brake pedal once. The new transponder key should now be programmed. Test the key by attempting to start the engine. If the engine does not start, repeat the steps above.
  • Mar 02, 2015 | 2010 Toyota Matrix
    Why does My 2013 ssang yong actyon sport pick up need a blower motor?
    To deliver heat into the area you drive from... That and cool air, defrost for the windows so you can see where you are going... That's why.
    Nov 01, 2014 | Cars & Trucks
    How do I program a transponder key for Mazda6
    You will have to take the vehicle to a Mazda agent and ask them to program a transponder key for your car. Every key is specially programmed for a particular vehicle according to its VIN number.
    Oct 21, 2014 | 2009 Mazda MAZDA6
    Alarm wont set 2008 jeep commander
    the car came with 2 RKE FOBs
    are both dead.?
    alway have 3 FOB if not you can not reprogram a new one. self.
    can cost you $300 for more to tow your car to the dealer if the 1 fob dies. never run one fob. or bad happens.
    put in a new battery in the FOB for door issues
    the transponder part does not use the battery .
    the transponder must be good, or the car would never run.
    the jeep cuts fuel after 2 seconds if the transponder fails.
    Apr 20, 2014 | 2008 Jeep Commander Sport
    My truck will not start due to the key not working in my ford pick-up. how much does it cost to fix it?
    Does the key turn in the lock cylinder? What year is the truck? Did you get the key cut at some random key place, or was it Vin cut at the dealership? There are a lot of variables that need to be eliminated before anyone could even come close to answering this question.
    Oct 21, 2009 | Code-Alarm Code Alarm Transponder
    Transponder key issue
    Try disconnect battery for 30 minutes. Sounds like new key not synced with computer. Might need reprogram.
    Jul 10, 2009 | 2001 Toyota Highlander
    Ford fiesta transponder problem
    I have a 2002 fiesta and recently it has been stopping on eac failure and then the imobiliser light keeps flashing and the car wont start not even turn over ha any one got a solution for this?
    Thanks llinos
    Nov 01, 2008 | Code-Alarm Code Alarm Transponder
    Air Intake Hose Ssangyong Rodius 2 7xdi Hump Bellow 3 25-3 5 Inch Od Logo
    104 people viewed this question
    Top Magnum Tuning Vehicle Parts & Accessories Experts
    mekanik84
     Robert
    Robert
    Level 1 Expert
    xkikbxr
    Are you a Magnum Tuning Vehicle Part and Accessory Expert? Answer questions, earn points and help others
