Question about Lanier 7313 7213 6713 6613 Copier Drum & Blade Kit
Lanier 7313 error code c7 - Lanier 7313 7213 6713 6613 Copier Drum & Blade Kit
5 Suggested Answers
  • 1294 Answers
SOURCE: wrench (repair)light is on. It's a Lanier 7313.
Set the maintenance counter:perform test command 72.Press C - interrupt key - 0 - interrupt key - 7 - 2 - PSW.The currently set maintenance cycle code is displayed and the ready lamp lights up.After the ready lamp lights up anter the set code corresponding to the maintenance cycle mode.0 = 10000 sheets ; 1= 15000 sheets ;2=30000 sheets.See the toner full detection part and remove the wastw box,change it.Perfor the test command 14.This command used to cancel troubles other then U1 and U2.After cancellation of trouble the test command is also cancelled automatically,also used to cancel toner full detection the maintenance lamp blinking.
Posted on Sep 26, 2009
  • 1294 Answers
SOURCE: How do you enter simulation mode and the code when
Press C00C or C interupt key 0 interupt key and 41 for developer counter display 42 for developer counter clear 46 for exposure level adjustment 72 for maintenance preset counter setting 25 for automatic developer adjustment. 40 for developer preset counter display.
Posted on Nov 10, 2009
cartridgecon
SOURCE: How do I reolace the toner in a lanier 7313
It was very easy. I just had not seen the machine when I posted the question. Thanks
Posted on Jan 09, 2010
  • 903 Answers
SOURCE: The copies on our Lanier/7313
Zebra striping is typically caused by a bad development clutch. Most likely, the developer and the development clutch will need to be replaced, but the 7313 is so old you may have trouble finding parts, or finding a technician to work on the machine.
Posted on Dec 31, 2010
Lanier 5635 error code displaying a SC320
sc320 on the Lanier 5635 is a laser unit error code. Often if you power cycle the machine (turn it off with the orange power switch on the left side of the copier, wait a few seconds, then turn it back on) the code will clear and the copier will resume normal operation. If the error code comes back or doesn't clear, you'll probably need to replace either the entire laser assembly or the polygon mirror motor inside the laser unit. These are best done by a professional -- contact your local Lanier service company if the problem persists.
Oct 15, 2010 | Lanier 5222/27 Laser Printer
The copies on our Lanier/7313 come out zebra stripped. The copies appear to copy better if we change the copy darkness to a lighter color.
Sep 21, 2010 | Lanier 1205 Copier
How do I reolace the toner in a lanier 7313 copier.
Jan 07, 2010 | Lanier 1205 Copier
How do you enter simulation mode and the code when you replace developer on lanier 7313.
Nov 10, 2009 | Lanier Office Equipment & Supplies
Wrench (repair)light is on. It's a Lanier 7313.
Sep 23, 2009 | Lanier Office Equipment & Supplies
Lanier Model #7320 Copier SN 826255. Has a wrench
Press "clear/stop" and "8" at the same time. An error code will be displayed in the copy quantity window as long as those two button are held down. What is the error code? Each code is specific to different areas of the copier. I will be more than happy to assist you in resolving.
I have a Lanier 7313 Copier which doesn't copy properly. Even with a new ink cartridge, the copies come out faded. Any ideas on what I can do?
This machine goes through developer pretty quickly. Sounds to me like it needs new developer and possibly a drum (and drum blade).
Aug 24, 2009 | Office Equipment & Supplies
Error code SC302
From the Ricoh-Lanier Error Code Sheet:
SC302: Charge Corona Output Error 3 - Grid Voltage error - Charger Roller Current Leak.
I would suggest replacing first the charge roller and if that doesnt fix it, the HIgh Voltage Supply Board.
Mar 19, 2009 | Lanier 5222/27 Laser Printer
Lanier copier 7313 AG
The clutches arnt too bad putting them in however... I own this model as a home copier but parts are hard to come by and to get a tech that knows how to repair is harder.
Sep 18, 2008 | Lanier 1205 Copier
LANIER COPIER 7313
I guess by your fault description that there is a blank gap before the printing starts? The only way to cure this problem is to replace the registration clutch as it is turning on too late and not releasing the paper quick enough. Also check that the paper tray dial is displaying the correct paper size and position.
Thanks Jason
Aug 15, 2008 | Office Equipment & Supplies
Lanier 7313 7213 6713 6613 Copier Drum & Blade Kit Logo
77 people viewed this question
Top Lanier Office Equipment & Supplies Experts
George Mclaughlin
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
