Question about New Balance Exercise & Fitness
I picked up a NEW Balance 9.0e will not power up or add resistance
Power cord or control panel will not work, any suggestions?
    Top Expert:
  • New Balance Master
  • 12,223 Answers
Please see the vidieo and fix it. GOD BLESS YOU
http://www.youtube.com/watch?v=N6Yg5S0WML8
Posted on Nov 22, 2013
Dear Sir, I have Unplugged the power,cleaned the freezer, plugged back the power, now control panel flashing 33 E and non of the buttons is functioning. How to fix it Thanks
What brand and model washer do you have? The E33 error could be a problem with the low-water level pressure switch. On some Zanussi washers, the problem could be at the control circuit board. You'll need to check the wiring (resistance). A visual inspection might reveal soot or another sign of a failed component.
Please add a comment with more information to get specific diagnostic and part suggestions.
Apr 25, 2015 | Washing Machines
Tip
Whirlpool Dryer Various Test Procedures - Part 1
TEST #1 Supply Connections
This test should only be done after confirming proper voltage at the outlet.
1. Unplug dryer or disconnect power.
2. Remove the cover plate from the back of the dryer.
3. Check that the power cord is firmly connected to the dryer’s wire harness.
4. Access the machine control electronics without disconnecting any wiring to the control board.
5. With an ohmmeter, check for continuity between the neutral (N) terminal of the plug and P8-3 (white wire) on the machine control board. If there is continuity, go to step 6. If there is no continuity, disconnect the white wire of the harness from the power cord. Test the continuity of the power cord neutral wire . If an open circuit is found,
replace the power cord. Otherwise, go to step 6.
6. In a similar way, check the continuity between the L1 terminal of the plug and P9- 2 (black wire) on the control board. If there is continuity, go to step 8. If there is no continuity, check the continuity of the power cord for power cord’s L1 wire. If an open circuit is found, replace the power cord. Otherwise, go to step 7.
7. Replace the main harness.
8. Visually check that the P5 connector is inserted all the way into the machine control electronics.
9. Visually check that the user interface assembly is properly inserted into the front console.
10. If both visual checks pass, replace the user interface assembly.
11. Plug in dryer or reconnect power.
12. Perform the Console Buttons and Indicators Diagnostic test to verify repair.
13. If indicators still do not light, the machine control electronics has failed: Unplug dryer or disconnect power.
Replace the machine control electronics. Plug in dryer or reconnect power. Perform the Console Buttons and Indicators Diagnostic test to verify repair.
TEST #2 Machine Control Power Check
This test is used to determine if power is present at the machine control electronics.
NOTE: The drum light is controlled by the machine control on all models.
2. Open the door.If the drum light illuminates, then power is present at the machine control, and it is functional. Go to TEST #6. If the drum light fails to illuminate, do not assume the machine control electronics needs replacement. Several conditions may cause the drum light not to illuminate, including a bad bulb. If the drum light does not illuminate, go to TEST #1.
TEST #3 Drive Motor Circuit
This test will check the wiring to the motor and the motor itself. The following items are part of this motor system:
Harness/connection Belt/belt switch Drive motor Centrifugal switch Door switch Machine control electronics
2. Access the machine control electronics and measure the resistance across P8-4 and P9-1.
If resistance across P8-4 and P9-1 is in the range of 1 to 6 ohms, replace the machine control electronics.
Otherwise, go to step 3.
3. Check the wiring and components in the path between these measurement points by referring to the appropriate wiring diagram and strip circuit in Section 7.
4. Check the belt switch and drive motor. Access the belt switch and drive motor by removing the front panel/drum assembly. Slowly remove the drum belt from the spring-loaded belt switch tension pulley, gently letting the belt pulley down.
5. Remove the white connector from the drive motor switch.
6. Check for the resistance values of the motor’s Main and Start winding coils. NOTE: Main and Start winding coils must be checked at the motor.WINDING RESISTANCE ω CONTACT POINTS OF MEASUREMENT
MAIN 1.4–2.6 Blue wire in back at pin 4 and bare copper wire on pin 5 of black drive motor switch
START 1.4–2.8 Blue wire in back at pin 4 and bare copper wire on pin 3 of black drive motor switch. If the resistance at the motor is correct, there is an open circuit between the motor and machine control electronics.
Check for failed belt switch. If the Start winding resistance is much greater than 4 ohms, replace the motor.
7. Check the belt switch by measuring resistance between the two blue wires while pushing up the belt switch tension pulley.If the resistance reading goes from infinity to a few ohms as pulley arm closes the switch, belt switch is OK. If not, replace the belt switch. If belt switch is OK and there is still an open circuit, check and repair the wiring harness.
8. Door switch problems can be uncovered in the Door Switch Diagnostic Test; however, if this was not done, the following can be done without applying power to the dryer. Connect an ohmmeter across P8-3 (neutral, white wire) and P8-4 (door, tan wire).With the door properly closed, the ohmmeter should indicate a closed circuit
(0–2 ohms). If not, replace the door switch assembly.
on Apr 11, 2009 | Whirlpool LER4634J Electric Dryer
I need to find a replacement power cord for this tv, any suggestions? I can't find it
you don't say what has happened to existing cord or what is wrong with cord. Have you tried to get a replacement cord at a tv repair shop?
Nov 24, 2012 | Televison & Video
Our washing machine does not work at all. No power. Replaced timer and still nothing. We have model number 3XWTW5705SWO. Could it be the in line fuse?
I would suggest getting/obtaining a schematic diagram, your washing machine may incorporate a out of balance switch, or your water level censor switch ether on of thees can cause your fault, most likely your fault is the water level censor, it is the disk shape unit with the plastic hose connected to it at the bottom and wire connections to the top.
Apr 26, 2012 | Whirlpool Washing Machines
After replacing our 3 prong cord with a 4 prong cord, it no longer works. Have we fried the control panel?
First, go back and check the power cord configuration. There is a difference between how a 3 and 4 prong power cord is connected. Copy and paste the following link to your browser:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you connected the power cord wrong, you may have simply blown the thermal fuse. This is a small plastic looking component (usually white in color) with two wires attached to it. Its located on the air blower housing inside the dryer.
If the model number is correct, you can access the thermal fuse by following these steps:
1. Remove the lower toe panel directly below the door, by locating the screws under the bottom front edge. You can gain better access to the screws by propping up the two front feet of the dryer (a 2 x 4 works well for this).
2. With the screws removed, the panel will drop down, then come off.
The thermal fuse should be located on the air blower housing directly below the drum in the front. A resistance check should read something close to zero ohms (short) if good. If you have no continuity, the fuse is blown.
NOTE: Make sure you have the dryer UNPLUGGED and the wires disconnected from the fuse, when taking resistance checks.
If you have questions, or need further assistance, please post back and let me know. I hope this helps you.
Aug 05, 2010 | Whirlpool GEW9250 Electric Dryer
Missing power cord Balance 2019 model F 192 input 15v 4a 3 prong
what type of plug is on the monitor???
if it is not a regular AC plug, then it need a tramsformer and a vendor plug.
Oct 05, 2008 | Televison & Video
Lost the power cable
If this is a non standard type of power cord that cannot be localy purchased, look up the manufacture name using Google or Yahoo. Find their support page, and enquire about how to order a new cable.
Jerry G.
May 25, 2008 | Balance CM2019 19" LCD Monitor
I have a balance laptop model 557s
ok..pull the battery first, and try it with only the power cord..
the battery MAY need to go through a charge/discharge/recharge cycle..
this will tell us.
Feb 28, 2008 | Balance CN6555 Notebook
Power cord not working
If your power cord plugs in to the back of the monitor, then you can find one just about anywhere that computer stuff is sold, like Radio Shack and Wal-Mart. You might be able to be able to get one free from a locally owned computer repair place as they most likely have extras lying around. Doesn't hurt to call and tell them you need one. If you have to buy one, they aren't expensive, usually 5 or $10. Please let me know how it turns out!
Dec 29, 2006 | Balance CM2017 17" Monitor
Exercise & Fitness Logo
60 people viewed this question
Top New Balance Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Howard
Howard
Are you a New Balance Exercise and Fitnes Expert? Answer questions, earn points and help others
