Question about Toshiba Televison & Video
Ok. I have the Toshiba Model No. 57HM167 and I keep getting an Error saying that the LAMP DOOR IS OPEN, but I believe its the sensor that tells it that its closed has gone bad. How can I bypass this sensor?
4 Suggested Answers
SOURCE: series of 3 blinking lights. manual says lamp door
After I unplug and then plug tv to reset I get a solid standby light,then when I push the power button I get a green light that blinks 6 times then it blinks red 6 times and then red 6 times continuosly with a slight delay between the 6 blinks of red.
Posted on Oct 21, 2009
ladywinn
  • 5138 Answers
SOURCE: Mits WD52631 model- television turns itself off
Lamp door senser maybe defective.
Posted on Dec 15, 2009
welcomejee
  • 10594 Answers
SOURCE: I believe the blue lamp in my 57H81 is going bad.
You need to replace convergence out chips in your Toshiba 57H81 tv by qualified tech because 3-D look picture in rear projection tv shows some thing wrong with convergence output chips.
Your tv model number shows it is rear projection tv that use 3 tubes to make color picture on front screen where as dlp tv use one lamp as back light source to present picture at front screen that is generated in light engine.
Posted on Mar 25, 2010
How do i determine if my ballast board or capacitor is bad in my toshiba hd tv model no 57HM167?
The chances of the ballast failing are small on this model. Count how many times the Yellow light flashes before it pauses. Then google 57HM167 and the amount of blinks. ie " 57HM167 Yellow light flashes 3 times" That will tell you what you need to know. You can also post it here and we can help. I suspect you have a stuck fan(the fans are monitored to see if they are spinning. If not, they will not allow the TV to start up). Or you have the cover for the lamp not installed all the way. There is a switch that the lamp cover activates and the the TV will not turn on without it secured.
Apr 02, 2015 | Toshiba Televison & Video
Tv is say lamp door open
Remove the lamp door and inspect the door switch. You probobly didn't get the door seated correctly.
Mar 21, 2013 | Toshiba 65HM167 65" Projection Television
TOSHIBA E-STUDIO 352 ERRO E550
It might be due to sensor faulty. Perform following input test.
Registration sensor 03-[FAX]ON/[2]/[A]
Upper drawer feed sensor 03-[FAX]OFF/[6]/[E]
Exit area Jam access cover Exit sensor 03-[FAX]ON/[2]/[B]
May 22, 2012 | Toshiba e-STUDIO 352 Black and White...
Toshiba TheaterWide 57HM167 Won't Turn On After Bulb Replacement
There is a ballast which drives the lamp--a hint would be to try to be in a position if possible to see if lamp ignites at all or even for a moment.
The ballasts do fail but rarely----it develops about 12,000 plus to the lamp and is much like spark plug wires as far as rf.
Some checks would have to be made and then the ballast priced--google the model number with ballast after it to get and idea.
No cut and dried solution here--several possible causes.
Mar 16, 2012 | Televison & Video
I have a toshiba 57h94 and when i turn on the tv i can hear a clicking sound, but no picture comes on. also, you can still hear a fan blowing.
You may want to check and see if the lamp is bad. On the left lower side there is a lamp door.
there is usually a knob screw or a phillips screw that keeps it in place. Open the door, remove the retaining screws for the lamp and pull the lamp out. Most of the time it is shattered and easy to tell it is bad. There is a part number on the lamp housing. If you can not find one local to you call
1800-631-3811. This the Toshiba customer service line and you can order one from them. I would expect to pay around 175.00 and 200.00 for the lamp.
I hope this helps,
skyassoc
Dec 09, 2010 | Toshiba 57H94 57" Rear Projection HDTV
The volume has stopped working on my Toshiba 57HM167. How can I fix this?
FIRST OFF ALL CHECK THERE SOUND DRIVER IF OK THEN INFECTED SOME VIRUS......OK
Mar 06, 2010 | Toshiba 57HM167 57" HDTV
Loud pop sound now no picture or sound error message and flashing red light
Very likely the bulb has gone they have had some issues with bulbs going quite frequently on this model, bulb I believe is about £100 and an easy job on this model
Nov 27, 2009 | Toshiba 57HM167 57" HDTV
Toshiba 52HM84 DLP TV with new bulb but the lights keep blinking
They exact way the lights blink are telling you what the failure is. If the tv is firing the lamp and the lamp is bad, you will hear a buzz sound for about 1 second. The tv tries 8 times before it gives up and spits out the lamp error. Check the user manual for led diagnostics. If you put in a new lamp but still have issues, you've likely got a bad ballast (most common on this model) or colorwheel (less common). Both are part of the optical block (light engine) and I don't believe they're available as individual components from toshiba.
Nov 28, 2008 | Toshiba 52HM95 52" HDTV Projection...
ERROR CODE
I believe that that "CH" code means that one of the doors is not fully closed. Not sure because I haven't worked on a Sharp in a couple of years. It's easy enough to check though. Let me know if that helped.
Sep 28, 2007 | Sharp AL 1631 Copier
Televison & Video Logo
21 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
