Question about LG HBS-700 Bluetooth Headset
Headset is on but there is no sound - LG HBS-700 Bluetooth Headset
  • 787 Answers
You don't say what you're trying to use them with. If it's your cell phone then maybe it's not compatible with it or maybe you have to go into the settings on your phone and manually configure it. Did you sync it with whatever it is you're trying to use it with? Did you charge the unit? Remember it is a wireless unit so it has to seek and find a compatible unit or it will not work.
Posted on Nov 21, 2013
How do I get rid of the static sound in my 4PR908?
There causes varies from types of headset to another. In respect of a wireless headset, the static sound is caused by interference. Whereas in a cord headset, a loose wire somewhere in your headset or cord is responsible for the static sound or crackle. It might also emanate from the mic in respect of a one calling, or from the ear-piece.
The solution with a wireless headset is to move away from any device e.g computer which might have cause the static sound. Resetting the wireless headset is also a solution measure.
In the case of a cord headset; Get the cord wiggled at the plug and at the headset; and then move the mic to locate the loose connection. Where the problem occurs, loop the wire, taping it down at the point. soldering the affected wire is best than taping.
Finally, if the static sound persist;which it should not after all the treatments; check on the volume of the device. Reduction of the device volume can go a long way to bringing the longed solution. Similar problem occured with my headset;and was solved via the same recommended possibility.
Jan 30, 2015 | Wireless Gear 4PR908 Bluetooth v2.0 EDR...
Replacing sound board?
Check and replace the socket to headset in the TV. It is faulty. Not the audio output board.
Sep 14, 2013 | LG 47LE8500 47" 1080p LED TV with 240 Hz...
How do i fix the volume because i do not have sound? my tv has no volume/sound. tried turning the tv up and down but still no sound
1 - hi
2 - check the jack for headset
- if you heard any sound with headset = your speakers are burned
3 - if you always use this jack for head set its maybe got problem = when push or pull the headset jack if you hear any sound from speakers your headset socket should change
4 - if you didnt hear any sound from both (speaker and headset) it means your ampilifire should repair
May 23, 2010 | Emerson CR202EM9 TV
Sound
the potential cause for this is that if you load up IE or FF with the headset plugged in, IE/FF will load up the sound via the USB, but if you remove the headset, IE/FF is still trying to relay your sound though the USB and not the speakers. This is not a design flaw with the headset but rather with windows. This happens to me with every program that uses sound. And also to note that even though you plug the headset back in, it has a good chance of loading onto a different address then what was used by IE/FF initially. You can see how this works also by leaving your headset plugged in, with IE or FF open (so that the sound is through the headset) then go into your control panel > sound options, and under the playback tab select your speakers rather then the headset. you will see that you lose your sound until you restart IE/FF.
May 20, 2009 | Logitech ClearChat Pro USB Headset
No sounds when plugged in headset
check for the ports in which u r plugging the headset & connect it into the headset port.....thats is the only way but if u r still not getting the sound then try connecting the headset to some other computer & if it also doesnt work there then the headset must has gone bad....
Apr 26, 2009 | Dell Inspiron 6000 Notebook
Logitech Microphone Not working
Hi, I have a skype approved logitech headset. I can hear sound, but I cannot record sound or communicate on it. I cannot even find the headset as option as Preffered Device in Sound and Multimedia. I am using Windowsxp
z. Please help.
Feb 21, 2008 | Logitech (980174) Headset
No sound from my Logitech headset when on SKYPE
Maybe you need to select which Audio device you are using within Skype. It the Settings under Audio you should be able to select the default audio device that Skype talks to. If you set it to the USB headset, it might work properly.
Nov 10, 2007 | Logitech 250 Headset
LG HBS-700 Bluetooth Headset Logo
132 people viewed this question
Top LG Radio Communications Experts
TO Lady
Computer Repairing
Computer Repairing
Michael Vincent Cruz
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
