Question about Electrolux ICON 30 in. Double Wall Oven
Once oven temp is reached the heating element turns off and doesn't maintain temperature
I set temperature at 350. Once the temperature reaches 350 the heating element shuts off and doesn't maintain the correct temperature. Drops 20 degrees in 15 minutes.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
If it is an electronic timer temp controller you might want to check it
Posted on Nov 22, 2013
  • 189 Answers
SOURCE: oven tempeture lower than setting by 100 degrees
Hey-  Let's fix this thing.  Several things can affect indicated/actual temperature.  The temp probe should test ok across it's lead wires at around 1100ohms. The computer usually shows a fault if the circuit is open, but won't show a code if it hasn't failed completely.  The next suspect is the igniter for the oven burner.  These can become weak with age, affecting gas flow to burner. Testing igniter is not really possible when it comes on and the part is usually replaced.  The regulator is next in line, occasionally causing variable flow to burner.  As you can see, quite a bit to consider.  On site diagnostics is usually required, but this gives you a start.  Installation instructions are available for all parts.     Please acknowledge this post if my info and time spent helps you.  Have more info if needed.  Thanks- Ed
Posted on Mar 26, 2010
hotuna
  • 288 Answers
SOURCE: Oven Switching Off
I have a few questions. Does the oven reach the set temperature? How do you get it to go back on? and if you do not set the time do you have the same problem?
Posted on Dec 06, 2007
  • 60 Answers
SOURCE: eod6630 does not heat to temp
Try and locate the thermostat, check no wires have come off from there. Your old element may have been ok, you may have a faulty stat or a loose wire on one of the connections.
Posted on Dec 07, 2009
  • 523 Answers
SOURCE: My Electrolux EOB5610 fan oven will not heat up.
replace t stat
Posted on May 06, 2010
barkencoa
  • 3463 Answers
SOURCE: My oven does not heat to the correct temperature.
The thermostat is the cause of the problem, normally the the only cure is to replace the oven thermostat,completely, or alternatively, compensate by setting a lower temperature when cooking.
this will work o/k if it is always the same variation in temperature across the range .
Posted on Dec 25, 2010
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
My oven won't reach the appropriate temperature
It is a problem with neither of the two it is the sensor reads the oven temp and shuts off the heating element when it is reached, it is called the thermal probe or thermostat.
Jan 19, 2012 | Whirlpool Ovens
When set to bake eg: 350 degrees the audio alarm will indicate it's reached temp but the oven is 50- 75 degrees lower. Must wait another 15 min for it to reach the proper temp. Have tried to adjust the off...
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
Jun 14, 2010 | Ovens
Intermittent tripping of circuit as oven just reaches temp
Sounds like the oven element is cracked and absorbing moisture when the oven cools down thus causing it to trip. Should buy a new element. there are hundreds of suppliers on the internet.
Jun 09, 2009 | Neff B1691 Single circotherm super...
GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Mar 14, 2009 | Ovens
Gas oven won't maintain temp. It turns off after reaching temperature set.
Hi ya mate sorry to hear your having problems with you oven,
The problem wiht your oven seems to ba a faliure of the fsd/ffd, it seems to me that this device is not completey gone but is faulty.
This device is used as a safety feature on gas ovens and is there to turn the gas off to the oven when the flame has failed.
The way it works is that the intial small flame heats up the the phile at the end of the cappliary tube which is connected to a valave which realses the gas to the oven..
what you need is to have it change
hope this helps
washdoctor
cheers
Aug 28, 2008 | Ovens
NEFF Oven Model B1430NOGB/02 Oven Temp not heating above @50 degrees
probably the element. to save wasting money, check continuity with a multimeter
Jun 25, 2008 | GE Profile JT912 Electric Single Oven
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Whirlpool built-in single oven AKZ451/IX/01
If this is an older oven, check to see if it has a control knob or switch labeled "manual and "hold". Make sure it's set for manual. The hold setting maintains temp at about 140 degrees.
If not the case, is this gas or electric?
Nov 11, 2007 | Ovens
Electrolux ICON 30 in. Double Wall Oven Logo
507 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
