Dlp tv wont start up/ switches off
My two year old LG Electronics RE-44SZ20RD dlp tv ,when turning on sometimes (getting more common) when I try to turn it on out goes the red standby light and then has to be either unplugged and plugged back in or turn it off/on at the switch on the front of the tv THEN it will start up and work fine all day with a perfect pic. This has happened twice in a row for my wife! Any ideas?
  • cwyn Nov 06, 2007
    When I try to switch my two and a half year old (out of warranty) LG on it will just "click" itself off, sometimes with a whir or squeak noise as the fan kicks in. BUT after two or three attempts it fires up and stays on completely fine. This has gone on for a few months now, is there anything I can do to repair this?
    P.S. It was repaired last year (under warranty) for a cracked reflector thingy, I think that's the technical name for it, that caused a visable line across the top of the screen.
    Please help.
  • cwyn Nov 06, 2007
    Please help.
  • 372 Answers
Hi.
This model of LG set does suffer badly with dry joints (these are soldered joints that have oxidised or cracked)
Its not A job that I would recomend you tackle you may need specialised soldering gear when working on smd type ICS.
Try & find repair shop that does free estimates.
If A repair shop states they will repair in the home offer to take it in to them as this is very difficult to repair in the home & you will end up paying more for them to come out then take it away.
Posted on Oct 10, 2007
SOURCE:
My 50” Samsung DLP (model HLN5065W1X) has 2 issues: 1. picture sometimes does not come on When starting up, the warm up lamp is on. Should take less than 30 seconds to come on. Sometimes takes minutes,...
It is a common problem for the Samsung DLP HDTV, the problem is that the color wheel is going to go bad. The only way to fix it is to replace the defective color wheel.
Jun 01, 2017 | Samsung PCJ522R 52" Rear Projection...
I HAVE A DLP SAMSUNG 52" T.V. IT TURNS OFF BY ITSELF EVERY THIRTY MINUTES. CAN YOU TELL ME WHAT THE PROBLEM IS?
Has it been getting loader lately? (fan noise)
if so check link it could be the common fault described below
Samsung Color Wheel
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Nov 24, 2009 | Samsung DLP HL-P5663W 56" TV
LG DLP TV Won't Start Up
After the bulb replacement, the lamp hour should be retested. If you replace the bulb, and after the lamp hour reset to new bulb; and after that you replace it with old bulb, it won't work. In most cases, the lamp ballast too have to be replaced with a new bulb, and it is a good practice too. If the TV refuses to start up, there are many reasons for that. It will be best to contact any experienced service technician; I suggest. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 05, 2017 | LG Televison & Video
LG DLP Suspected Faulty Bulb... how to be sure?
First pull back off turn TV on watch Fan behind lamp more then likely it is going bad Fixed LG 9months ago and it was the Fan.If Fan Stops turning Lamp will not light.
Aug 06, 2009 | LG Televison & Video
Picture getting darker over the years
It could be your Light Engine. However, I would first check a few things:
1. Make sure your Low Power/Lamp settings are adjusted so that they meet your brightness needs.
2. Make sure you used a Mitsubishi original lamp, as generics get chewed through fast and hard.
3. Try another lamp; sometimes you can get a bad one in the bunch.
All those things don't work, consider a Light Engine ($400 + for parts; $300+ for labor)
Mar 11, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Samsung dlp HL56A65 turns off and on by itself
It looks power board problem.
You need to get service from Samsung.
Mar 04, 2009 | Samsung DLP HL-P5663W 56" TV
Viore DLP TV
The lamp is most likely over heating. Check the fan in the lamp assembly compartment. Its located in the rear of the tv... try removing the lamp compartment and replacing the fan.
A quick fix is to put a small 7-10 inch box fan with its back flush to the lamp
compartment's vent - this will draw the heat out.
Sep 10, 2008 | LG 42LC2D 42 in. LCD HDTV
Zenith DLP-Projection tv 42"
Try this solution which I found on Fixya
This solution is for the zenith 56" DLP. Unplug the tv, either from the wall socket or the TV. While the TV is unplugged hold the power button on the TV for 40 seconds. This lets the excessive power drain from the TV. If this does not work call 1-800-243-0000. This is the number for their help line. This is the fix the tech gave me and it worked right away. Hope this helps and have a great day.
Zenith dlp projection model z52sz80 turns off randomly
Further advice here. If the bulb is over a year old it is suspect.
LG DLP TV wont power up Red indicator lightjust blinks when
and where I got all this information frlom
zenith dlp projection tv blinking red light Google Search
Jan 09, 2018 | Zenith Televison & Video
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
Ekse
