Question about Turbo Air Refrigerators
Draws too much amps and trips the breaker - Turbo Air Refrigerators
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
There must be a short if it does not trip immediately than it could be a shorted compressor you will need to find where the short is
Posted on Nov 23, 2013
Compressor trip breaker
I hope you have a transfer switch box and not plugging into the washing machine outlet. The breaker switch may be not rated high enough. Check the manual.
Oct 14, 2017 | Heating & Cooling
Trips breaker once in awhile.Not consistent. Replaced elements, contactors, wash motor. Still trips once in awhile.
check for a bad connection, if there is a bad connection it could draw more amperage then it should.
Jun 25, 2015 | Hobart C44a Commercial Dishwasher
60 breaker wil. Trip on what overload amps
No exact answer since breakers are not fast-acting.
For example, a short draw of 65+ amps might not trip the breaker... but amp draw cannot exceed the 60 amp rating for very long before the breaker will trip.
http://waterheatertimer.org/How-to-install-a-subpanel.html
Gene
h
Aug 10, 2014 | Electrical Supplies
Trips circuit breaker
Copy following link:
http://waterheatertimer.org/Troubleshoot-household-electricity.html
http://waterheatertimer.org/Color-codewire.html
Add a comment March 2013 and describe what device is tripping breaker.
Breakers trip when they sense overheating.
This can be caused by too large amp draw, undersized breaker, bad breaker, bad wiring, damaged wires, loose wires, wires are too long, electrical device that is shorted or draws too many amps for the breaker and wire rating.
Mar 08, 2013 | Electrical Supplies
Breaker trips after bout 5 minutes
Breakers trip because of heat.
When heat from wire exceeds breaker rating, it trips.
Something is causing heat on the wire, wire is too small for the amp draw, there is short circuit, or breaker is bad.
Replace breaker and/or test wire.
Put amp-meter on wire and read amp draw through wire.
Amps cause heat. That's why high voltage lines from power station are high-volt-low-amp so there is no heat loss with long distance transmission, until transformer at home converts electricity to lower volts and high working amps with enough power to run electrical devices.
Same is true for AC and DC circuits.
If amp reading on wire exceeds rating on breaker for length of time, then breaker will trip.
The fact that the breaker lets current (amps) to flow for a period of time before tripping is because the breaker is probably rated for slow-acting, or it takes a while for amp draw to heat the wire.
Following image shows amp-meter that clips over wire to get amp reading.
http://waterheatertimer.org/pdf/Which-is-best-gas-water-heater.pdf
Oct 31, 2012 | Electrical Supplies
Breaker keeps tripping on outside air conditioner unit
The compressor is probably drawing to many amps. Breaker could be weak also.. Need to check the amp draw on the compressor.
If the breaker is hot when it blows, the compressor is probably going bad.
Jul 27, 2010 | Ruud Central System Air Conditioner
Rooftop RV Air Conditioner: replaced capacitor on dometic 59516-531 steal trip...
You need to borrow a clamp on style amp gauge, and check amp draw on black wire in box where hydro wires connect. (PLEASE, be careful, and if not experienced in this type of test, don't try it, due to likelihood of getting a shock. ) If it's the compressor kicking in that's causing the breaker to trip, and capacitor is good, then it's usually a problem with either low incoming (supply) 110-120 AC voltage, which will cause high amperage draw, or compressor on it's way out causing high amp draw. If it's only drawing 15-18 amps, and your tripping a 20 amp breaker, then breaker is getting weak.
May 18, 2010 | Dometic Rooftop RV Air Conditioner
Siemens Main Breaker 125 Amp gets warm and trips
sounds like a loose connection ,or possibly a weak main breaker.
Jul 14, 2009 | Siemens /ITE 100Amp 2-pole molded circuit...
Circuit breaker overheating on rooftop ac after
Possible overcharge or bad breaker. You need to check the amp draw for the unit. If you draw under full load amps and trips breaker breaker is bad.Rus
Jul 13, 2009 | Dometic Rooftop RV Air Conditioner
A/c is drawing 20 amps and keeps tripping breaker after running
If the fan is running and the compressor is getting hot and tripping off you may have a failed capacitor.
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
Refrigerators Logo
59 people viewed this question
Top Turbo Air Refrigerators Experts
Dennis Boxerman
ray gallant
John Tripp
John Tripp
Are you a Turbo Air Refrigerator Expert? Answer questions, earn points and help others
