Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
GE Smartwate filtration GX1S15CBL rev 2 can't get to the replacement filter to change it
Can't open the filter housing to change the filter
2 Suggested Answers
h2oservices
  • 306 Answers
SOURCE: GE Heavy Duty Household Filtration System
It sounds like there is quite a bit of sediment in the water. The filter you are using may be a very fine micron 5-10. Try using a 30-50 micron filter.
RJ
Posted on May 17, 2011
After city changed water meter the water is not consistently hot.
There are two things to check. First, check the inlet water filter on the heater. The changing of the meter may have introduced debris in the line and partially clogged the filter, causing flow issues that affect turn-on/turn-off of the unit. Also, the new meter may have changed the water pressure/flow rate into the house, If the filter is not the problem, have the inlet water pressure/flow rate checked. If it is too low, there may be some adjustment that can be made, or the city may have to replace the meter with a different unit.
Dec 01, 2015 | Eemax EX280T2T Series 3 Whole House...
Lux TX500e thermostat
go to honeywell it,s a house hole name
Nov 07, 2013 | Lux Tx500 Series Smart Temp Electronic...
We also installed the water filter GXWH40L. We never had any issues and have gone through probably five replacement filters. We recently changed the filter and have horrible water pressure. We changed it...
If you have GATE valves on either side of the filter make sure the have opened all the way. They can become unscrewed and although it seems like it opened they gate can be almost closed. If the outside spigots are on hard water try the pressure there.
Water filters for pre-filter housings come in different micron ratings. They can be anywhere from .5 micron on up to 100 micron. The smaller the number the finer particulates it filters out and the faster it will plug up. Generally most filters used for residential households are 5 micron to 50 micron rating and the most common used are 10,30 or 50 micron. Try a 30 or 50 micron filter to see if it helps. But remember the larger the micron rating the more particulates pass through.
If there is a lot of sediment coming the well and building up in the bottom of the pre-filtet housing you may want to flush the well or consider having the well inspected by a well company. You could have a pinhole in the drop pipe that is letting sand in.
Run one of the outside spigots in to a clean white bucket, let the pump cycle several times and inspect for sediment in bucket, let it settle for about 20 minutes to see if excess sediment is coming from well. Have your water tested to see if the water chemistry has changed also.
RJ
Dec 07, 2010 | General Electric GE SmartWater Household...
Canisters on my ge smart water filtration system gxsv10c model are stuck tight. How do i get them open
Make sure the water is turned off to system. Open the faucet to system to drain any water and keep the faucet turned on to keep pressure off filter housings.
1.Use the wrench to take housings off.
2. If they still won't budge take a small 2x4 block of wood and hammer, set the block of wood on the RIB for the housing and tap with hammer.
3. Change the o-rings in both housings, lubricate with silicone lube and lubricate the threads on housings with silicone also.
3. Rinse housings with small amount of bleach and clean thoroughly.
4. Replace filters and housings.
5. IMPORTANT: Only tighten housings by hand. NEVER tighten housings with wrench.
RJ
Nov 10, 2010 | General Electric GE SmartWater Household...
I have a whole house water filter that uses a 30 micron FXHSC filter. the last two filters have come apart and sent fiber through the water lines in the house
I would shop around for a different water filter supplier...there is no reason ofr that happening unless you are not changing the filters regularly...like once a month...
most filters are a standard size and it should be easy to get them somewhere else...
heatman101
Aug 13, 2010 | General Electric GE SmartWater Household...
The red pressure relief button on my GE Smartwater GXWH35F whole house water filter system doesn't seem to be relieving pressure. As a result I cannot turn the filter cartridge in order to replace the...
To replace the filter cartridge. Do the following;
1. Assuming that you have a pump in your water filter
system, shut it off.
2 Close the intake valve before your filter system.
3.To relieve the pressure, open the faucet after your
filter system. Any of your faucet for that matter.
4.Once the pressure is relieved, you can of course
replace the the filter cartridge.
Nov 26, 2009 | General Electric GE SmartWater Household...
I was changing my filter in the ge filtration system, and it says to turn off the water and press the red button. Then it says to unscrew the filter take the old one out and clean the filtrstion system...
The red button is a pressure relieve valve. If the system is leaking from the valve, try pushing the valve up from the underside of the cap where the valve is located. If this does not work the housing needs to be replaced. You do not have to replace this with a name brand like GE. All you need to do is make sure the housing that you are purchasing is the same size.
Example of Replacement Filter Housing: http://www.freshwatersystems.com/c-107-filter-housings.aspx
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Apr 27, 2009 | General Electric GE SmartWater Household...
Slow water flow from GE SmartWater under sink water filter.
I solved the problem! The system's manifold (the plastic base you put the filter in) has small black conical shape button. When you tight the filter in, one of the two small triangle-shaped cams (located close to the filter's central hole) pushes the manifold's button, and this opens the water flow. The problem is that the cams are too low and do not push the button all the way in. Take a pliers and squeeze (not too much!) the cams, so they will raise a little: it will be enough to push the button to open the flow completely.
Mar 11, 2009 | General Electric GE SmartWater Household...
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
Top General Electric Water Heaters Experts
paulcarew
Donni Steen
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
