Question about Science & Laboratory
HOT AND COLD NOT MIXING PROPERLY 73716-AA - Science & Laboratory
3 Suggested Answers
  • 10 Answers
SOURCE: the cold water comes out slow
you need a water valve sounds like you may have hard water and the valve has clogged try switching the hoses on the rear of the washer and see if that corrects your problem
Posted on Jan 07, 2010
  • 767 Answers
SOURCE: Possible Mixing valve Problem
I would pull the lines off the back and check the inlet filter on the hot and cold sides of the water inlet and clean the screen style filter. If you just use cold is the water cold if the cold water valve was bad then you would get no cold wate when set to cold.
Posted on Jan 20, 2010
The hot and cold are reversed on our single handle shower (no tub faucet -- shower only)
Hot on left.
Cold on right.
Some single handle faucets have bleed-over where both hot and cold enter mixing valve each time handle is turned on, even when faucet calls for just cold or just hot.
Otherwise maybe a do-it-yourself plumber got pipes backwards... or maybe the tub used to be on other side of wall, and tub was moved during remodeling but pipes were not changed.
To fix problem:
First of all, turn off shower faucet. Turn on Hot at sink and put ear against shower faucet listening for sound of water flowing through the mixing valve.
If mixing valve is working fine, you need to open wall and investigate more.
For example if you have access door, reach in and feel which pipe is hot.
Pipes might need to be reversed if problem comes up in home inspection, otherwise the problem will not harm anything.
Feb 19, 2011 | Price Pfister Plumbing
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
Hello, Hot to very warm water comes out of the regular COLD water faucets throughout the house for about 45 seconds whenever the COLD water faucets are opened. I suspect that the thermostatic...
Yes the mixing valves do wear and give out........I had to put a micron filter in the input line to the hot water tank and solved the promlem for around 8 tears now. knock on wood....Hope this helps.
Aug 12, 2010 | Home
2000 lincoln ls ac is blowing hot air on pass side
On the central console is the A/C module. Inside A/C module are driver's side & passenger's side air flaps for mixing hot & cold air and directed air flows towards driver's side & passenger's side according to driver commands. The passenger's side flap for mixing hot & cold air according to driver commands is bad. Flaps are actuated by electrical step by step motors. Could be damaged the flap actuator (motor), the flap mechanism (blocked in "HOT" air position), and / or electrical supply wires. You must access the passenger's side flap for mixing hot & cold air, and see what happens when you command cold air to the driver's side: flap mechanism, flap actuator, supply wires, ... Repair & replace bad pieces and test the A/C system.
Aug 12, 2010 | 2000 Lincoln LS
Temperature too hot on bristan art deco mixer shower even on lowest temperature setting.
if the water is that hot then lower [adjust] the temp of your hot water heater -if need to adjust the shower you can adjust the mixing by removing the handle and on the valve stem are the adjusting clips the red [hot] and blue [cold]plastic clips can move them around to adjust the mixing of hot and cold water
Jul 23, 2010 | Home
My bread does not rise properly. Is it possible\r...
If the machine is heating the element is working.
If it looks like bread dough then the paddle is mixing.
It's more than likely your ingredients. Old flour, old yeast, not enough flour, not enough yeast, water too hot or cold.
Check each ingredient to the recip as you put it in. Put them in in the order suggested by the recipe. The yeast should go in last and shouldn't have contact with the water until mixing starts.
May 17, 2010 | Kitchen Appliances - Others
Jan 20, 2010 | Maytag PAV2300 Top Load Washer
The cold water comes out slow . I have already taken the hose off of the back of the washer and the water flows good there. When cold/cold is used the water comes out very slow. When cold/hot is used the...
Jan 07, 2010 | Kenmore Washing Machines
Washer wont allow cold water
Mixing valve should lock out the hot water when on the cold water setting. Either your hoses are crossed, or the mixing valve is flipped. To see if one of these is true, try it on a hot water setting to see if cold water comes in, or try just swapping the water hoses.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
Hot water first from faucet, two minutes later cold???
you could be having a problem elsewhere in house system! do you have a garden hose hooked up with a "Y" hose? or something in system were hot and cold connect...then a valve after? what happens is the hot water can back siphon through cold lines..its rare, but this happens, and is dangerous! water from hot water tank is full of bacteria, and if you drink it , well thats not good!
Mar 26, 2009 | Chicago Faucets CHICAGO FAUCET Mixing...
Science & Laboratory Logo
101 people viewed this question
Top Science & Laboratory Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
