To change from the offline mode, simply select the general profile on your phone, That is, Go to menu>settings>profiles>choose General and click on activate and your phone is back online.
if you hold finger on the volume up button dial a box comes up on the bottom of the screen says do you want to stay offline you press no and the phone will reboots itself into normal mode
Your phone might have switched to offline mode accidentally if your keypad is not locked and you have the phone in your pocket/bag.
Press the power button momentarily to bring out a list of profile options, and select "General";
or you can go to Menu -> Settings -> Profiles and choose Normal Mode;
or you can turn the phone completely off and then turn it back on; while the phone boots up you will be asked if you want to exit offline mode -> answer yes
In order to prevent the phone from switching modes, or making inadvertent calls, remember to lock the keypad when the phone is not in use:
Left selection key + functions key http://europe.nokia.com/support/product-support/e63/nokia-e63-how-to/get-started/get-started-shortcuts
offline
may mean that the Sim Card was not correctly placed or a fall or shock on the
phone has requested you to switch to offline mode and thus you are on that mode.
This can be cured by turning off the phone and removing and putting back the Sim
Card. You can also just change the settings to General if you had earlier
inadvetently chosed the offline mode. just
try this one!!! first you do is to click the power switch for 1 sec. then it appears: switch off,lock key pad,general,silent,etc.you will see a offline
word in the screen.... just choose general profile.... and this words will
appear "phone is currently in offline mode. change profile to access network?" just choose yes.. i hope it will help your
problem....
please rate :)
I couldn't find the above menu items however i found an alternative: press the on/off button on your E71 and select General. The phone will then ask if you want to change from offline mode and allow network access.
