Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
Cannot unscrew the ge smart water filter GX1S15CBL rev 2 cannot replace filter
I know how to replace the filter. I just can't unscrew the housing to get to the filter
5 Suggested Answers
SOURCE: Slow water flow from GE SmartWater under sink water filter.
I solved the problem! The system's manifold (the plastic base you put the filter in) has small black conical shape button. When you tight the filter in, one of the two small triangle-shaped cams (located close to the filter's central hole) pushes the manifold's button, and this opens the water flow. The problem is that the cams are too low and do not push the button all the way in. Take a pliers and squeeze (not too much!) the cams, so they will raise a little: it will be enough to push the button to open the flow completely.
Posted on Mar 22, 2009
KMusselmann
  • 247 Answers
SOURCE: instruction manual for ge smart water filter
Here is the website that you can get your users manual. You will need the model #. Pls rate ny answer
Kurt
http://www.geappliances.com/service_and_support/literature/
Posted on Apr 20, 2009
SOURCE: how do you change the GE smart water filters?
This page might help with changing it, as different models vary.
Posted on Feb 20, 2010
wentlanv
  • 710 Answers
SOURCE: GE Smart Water under sink
Hi jbboggeri,
Welcome to fixya!
I would go ahead and open the new set and install them. If you get pressure, you know the others were bad and can send them back for a refund.
If there is no change, you can always put them away and use them again later.
Please reply back and let me know how it went. Thanks,
Handie Andie
Posted on Jun 16, 2011
Ge smart water heater model SE80T1ZTAH
Try this:
1. Turn off the power to the water heater.
2. Press the reset button.
3. Replace the insulation and jacket access panel(s) before turning on the power to the water heater.
Please let us know if this works!
Nov 04, 2013 | Water Heaters
GE Smart Water under sink dual water filters replaced. Very little water pressure. I have reinstalled them, no improvement. I have been replacing these filters for 5 years and have not encounerted this...
Hi jbboggeri,
Welcome to fixya!
Handie Andie
Jun 16, 2011 | General Electric GE SmartWater Household...
Ge smartwater wholehouse waterfilter main housing failed flooded house
Why did it fail? How did it fail? Was it the plumbing that failed? Replace it with a Pentair filter housing, 10" housing, 20" housing or Big Blue housing and make sure it is plumbed in properly. It is very unusual for a filter housing to fail unless it freezes up.
RJ
Apr 18, 2011 | General Electric GE SmartWater Household...
I need a handle for the Smart Water System
Here is the web page for GE. You will probably have to replace the whole faucet. When you call have the model # available for your system so they can supply the appropriate faucet. You may as well order more filters as they will be less expensive ordering on-line. These filters should really be changed every 6 months.
http://products.geappliances.com/ApplProducts/html/GEAResults.htm#Category=Dual_and_Single_Stage_Water_Filtration
These faucets are relatively easy to replace for the do it yourselfer.
RJ
Feb 24, 2011 | General Electric GE SmartWater Household...
Canisters on my ge smart water filtration system gxsv10c model are stuck tight. How do i get them open
Make sure the water is turned off to system. Open the faucet to system to drain any water and keep the faucet turned on to keep pressure off filter housings.
1.Use the wrench to take housings off.
2. If they still won't budge take a small 2x4 block of wood and hammer, set the block of wood on the RIB for the housing and tap with hammer.
3. Change the o-rings in both housings, lubricate with silicone lube and lubricate the threads on housings with silicone also.
3. Rinse housings with small amount of bleach and clean thoroughly.
4. Replace filters and housings.
5. IMPORTANT: Only tighten housings by hand. NEVER tighten housings with wrench.
RJ
Nov 10, 2010 | General Electric GE SmartWater Household...
We have a leaking water heater.
As far as a shut off valve on to the water heater, if there is one you should be able to see it on the water line going to the heater. This is not common in mobile homes. If there is not one I would strongly recomend you install one when you replace the heater. If it is going to be a while before you replace the heater you might consider draining it and cutting into the inlet line and installing a shut off valve, so you can turn the house water back on. I hope this helps.
May 12, 2010 | General Electric GE SmartWater Household...
Hot water does not last long. Hot water heater is a 50 gal ge smart water heater. It takes a long time to heat and is not very hot when it reaches shower in the back part of house. Where are the coils or...
probably has a bad heating element. May be a little limed up also. Drain the heater and replace the elements. Take a special tool to remove and replace the elements. ( fairly cheap) You can probably get the elements and parts at a good hardware store. The people at the store probably will explain to you how to replace them. Feedback please if this was of help
Feb 20, 2010 | General Electric GE SmartWater Household...
The red pressure relief button on my GE Smartwater GXWH35F whole house water filter system doesn't seem to be relieving pressure. As a result I cannot turn the filter cartridge in order to replace the...
To replace the filter cartridge. Do the following;
1. Assuming that you have a pump in your water filter
system, shut it off.
2 Close the intake valve before your filter system.
3.To relieve the pressure, open the faucet after your
filter system. Any of your faucet for that matter.
4.Once the pressure is relieved, you can of course
replace the the filter cartridge.
Nov 26, 2009 | General Electric GE SmartWater Household...
I was changing my filter in the ge filtration system, and it says to turn off the water and press the red button. Then it says to unscrew the filter take the old one out and clean the filtrstion system...
The red button is a pressure relieve valve. If the system is leaking from the valve, try pushing the valve up from the underside of the cap where the valve is located. If this does not work the housing needs to be replaced. You do not have to replace this with a name brand like GE. All you need to do is make sure the housing that you are purchasing is the same size.
Example of Replacement Filter Housing: http://www.freshwatersystems.com/c-107-filter-housings.aspx
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Apr 27, 2009 | General Electric GE SmartWater Household...
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
53 people viewed this question
Top General Electric Water Heaters Experts
paulcarew
Donni Steen
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
