Question about Konica Minolta PagePro 1300W Printer
Replace fuser unit
Piece of paper stuck in fuser unit, cannot shift it. Cannot get access to rollers to try and roll it out. Possibly fuser unit faulty, but cannot see how to remove it to check. Any suggestions? User guide is no help.
  • Konica Minolta Master
  • 6,161 Answers
Have konicaminolta service tech come and look at it.
Posted on May 21, 2015
4 Suggested Answers
  • 214 Answers
SOURCE: Minolta 2350 DL laser printer stuck paper in rear user roller
sry, dont understand, where is the paper jam, in the end at the fuser ? or some where else?
Posted on Feb 09, 2008
  • 1218 Answers
SOURCE: My Konica Minolta 2530DL printer has paper jam ,as
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Posted on Nov 12, 2010
ashcreekllc
  • 794 Answers
SOURCE: Paper stuck in fuser unit
1) Grab the front cover grip and
open the front cover
2) Pull the handle of the imaging
cartridge toward you, and then
pull out the imaging cartridge.
Note
Do not expose the imaging
cartridge to light for a long period
of time, otherwise decreased
image quality may result.
3) Pull out the jammed media along
the feeding direction.
Note
If media is jammed in the fusing unit,
pull the media downward to remove
it.
CAUTION:
The fusing unit is extremely hot.
Touching any part near the fusing
unit may result in burns.
Do not touch the image transfer
roller inside the printer, otherwise
decreased image quality may
result.
4) Align the imaging cartridge with
the guides in the printer, and
then insert the cartridge.
Note
Do not insert the imaging
cartridge at an angle or with
extreme force, otherwise the
printer may be damaged.
5) Press on the front cover grip and
close the front cover.
Posted on Nov 22, 2013
Service call 984: fatal error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Mar 20, 2013 | Oki Brand Oki C610n Laser Printer...
Paper is getting stuck in the fuser rollers
remove the fixing unit and clean the charge roller (aluminume roller) in case you are cleaned for long time this coudbe in black color clean well and refix it, the machine will be alright.
Jan 28, 2013 | Canon imageRUNNER C3200 Copier
Just copy file..always jam..messagge"papper jam
Causes for paper jams in Printers are given below:
* Dust or debris
* Rotating drum problem
* Toner or fuser complaint
Dust or debris
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.
If there is no direct symptom of paper jam and still you cannot do printing properly, find whether it is because of drum problem. If the paper gets into the end gear of the rotating drum and gets stuck there, you cannot access the printing function. Switch off your printer and check the plastic arms of the printer drum. If there is any paper piece jammed in any of the arms, you can't continue printing. Here also cleaning is the best method to solve the problem. While cleaning, check the arms of the rotating drum.
Toner complaint may also cause paper jams. It can be solved only by replacing it. When you switch on the loop back plug in, two flash lights appear; then it indicates paper jam. The oil spillage in toner can cause this problem. If the toner cartridge is not functioning properly, the same problem would be the result. The diodes or transistors in the fuser unit of the printer may get damaged and this can lead to fuser complaints. To solve this problem, you should replace it.
Feb 22, 2011 | Office Equipment & Supplies
Some of the springs came off the rollers and a small broken piece of support for roller-do i need to get a whole new fuser assembly?
if you found a spring from the fuser and a flat blade like piece of black plastic this would be a detach finger and tension spring all fusers have the they help prevent the paper from rolling up on the fuser roller. fusers have either 5 or 6 depending on the model.they will funtion muinus one of these. if you get regular paper jams in the fuser of if they start replace fuser
Oct 03, 2010 | Canon ImageClass D880 Copier
Paper will stuck at the heater
HI i think you have a bad upper fuser roller thats why the paper rolled up with it or maybe there are finge clow are not good first of all just remove paper and just clean the upper fuser roller with fuser oil if yours fuser roller and finger clow are not damaged it will work fine enjoy
thanks
May 14, 2010 | Konica Minolta DiALTA Di200 Copier
When printing paper gets stuck. Not rolling thourh
LANIER COPIER PROBLEM SIMILAR TO RICOH COPIER PROBLEM AND IF THE PAPER GOT STUCK ,FIRST YOU MUST SEE AT WHICH
LEVEL/IS IT CRUMBLEB OR JUST MESHED THROUGH OR JUST UNABLE TO PASSED OUT FROM TRAY.
IF PASSED OUT FROM TRAY BUT STUCK AT DUPLEX AREA ,THAT MEANS YOUR FINGER AND MYLAR/RUBBER ROLLER MUST BENDED OR NO GRIP SO YOU HAVE TO REPLACED IT.
IF STUCK FROM THE TRAY, EITHER YOU DID NOT NOT " FAN" THE PAPER BEFORE USE AS NO AIR BETWEEN THE PAPAERSOR HAVE TO REPLACE THE PAD AND UPLIFT ROLLER RUBBER[1 PIECE ONLY PER TRAY]
IF STUCK AT FUSER AREA,JUST CHECK THE UPPER & LOWER ROLLER, THERE SHOULD BE THE ROLLERS NOT MEET TOGETHER. NEE MORE CLARIFICATION
Mar 31, 2010 | Lanier Office Equipment & Supplies
Double printing
HP do not use fuser oil. The upper roller is made of a non stick coating. When this begins to waer the toner sticks to the roller along with excess paper dust off the paper.This is what will cause a repeat image on a page. You need to swop the fuser unit to cure this fault
Oct 01, 2009 | HP LaserJet 4250n Printer
How to remove covers and fuser unit?
Ive got the same problem :( and because i used compatible cartridges, it apparantly voides the warrantly, so staples will not fix it :( so im now stuck with a £260 uselss printer :( good luck getting it fixed.
Sep 28, 2009 | Samsung CLX-3175FN Printer
I have labels stuck and now paper stuck to the label and I figure out how to get to them. It on the black roll thing
The black roll thing is the fuser roller. If you have a label stuck to this unit them it will need to be replaced. The fuser roller that you see has a coating of teflon and if a label is stuck to it, the coating will be damaged when you try to pull off the label. The HP part number you need is RG9-1493. Check with your local printer repair shop for pricing, If they can't get you what you need check Ebay.com We have service manuals for his unit available for $6.95 for a download if you need one. The manual is at www.ccl-la.com/hplj3330.htm The service manuals have disassembly instructions, parts lists and troubleshooting tips.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jun 23, 2009 | HP LaserJet 3330 All-In-One Printer
Nec 860 laser printer fuser unit
remove cartridge and leave top door open, then remove two screws in back ; open front sheet panel to find two screws to remove then remove outer case carefully AND PLACE ON LEFT SIDE BECAUSE THERE'S A RIBBON WIRE ATTACHED.
there are 4 screws holding the fuser unit in place, remove AND LIFT OUT BY ROLLING TOWARD YOU to reveal 2 screws to access the red roller assembly!
In my case there was a very tightly wound piece of paper stuck in there not visable without removing the screws on the fuser unit!
Dec 18, 2008 | NEC SuperScript 860 Laser Printer
Konica Minolta PagePro 1300W Printer Logo
54 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
