I have a carrier weathermaker model 58 dxc. The heat function is on and air is blowing, but the air is not being heated. Suggestions?
hotuna
  • 288 Answers
SOURCE: Honeywell thermostat....Home cooling/heating system....Chromotherm III
On heat pumps, the normal setting is simply an air conditioner working in reverse. The EMT or AUX heat is a supplemental heating system using electric heating elements instead of the hermetic (compressor) system. As far as why the regular heat does not work it can be one of many things. low freon charge. reversing valve not functioning. The defrost cycle not working. Take your pick. you may want to call a service man to repair it as the electric (EMT) is not as efficient.
Posted on Nov 04, 2007
yalmer
  • 552 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
SOURCE: Carrier Weathermaker 8000 - furnace does not ignite
having a problem with a weather maker 8000. It will not come on at all unless I shut down the switch on the side of the furnace. filters is clean. it will start to light then stop
Posted on Dec 20, 2008
benmartinez
SOURCE: Heat pump that just blows cool air
I have a Honeywell heater i'll set my thermostat to 76 and ill turn on the heater and it would turn on... but when it get to 76 it turns off so when the temperature drops down and the heater clicks back on all i get is cold air .. it only works on the 1st time what to do ?
Posted on Dec 24, 2008
tborn6
  • 700 Answers
SOURCE: Carrier Furnace is not blowing Heat
heres the manual for the unit, look at pages 46-47 and theres a trouble shooting ladder schematic that asks what the systums are then gives the solutions for the fix. if you are still having problems you can request to talk to me and I'll be more than happy to help.
http://www.docs.hvacpartners.com/idc/groups/public/documents/techlit/58st-13si.pdf
Posted on Jan 11, 2009
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
My heating unit is coming on and just running not blowing heat at all. what could be wrong?
my first impression is that the filters are too dirty and they caused the high limit to trip. needs serviced.
Jan 31, 2015 | Carrier WEATHERMAKER 48TCEA 4.0 ton Gas...
Carrier weathermaker I have model #48dp016520 I don't hear any blower heat coming in. What would be the problem
The thermostat may not be sending the heater control relays power. The heating element or the gas valve may not be functioning.
Jan 07, 2014 | Air Tools & Compressors
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
I'm in urgent need of a fan motor for a carrier weathermaker 8000. Any suggestions where I may find one in the Atlanta (ne) area?
do you have a johnstone supply they are the only company I know of that sells to public you could also bribe a heat and air guy
Sep 20, 2010 | Heating & Cooling
My Carrier Weathermaker 8000 a few days ago the air began to blow non stop and the burners are not igniting. I am getting Code 33. I did all the resets, unplug control board, switch to air condition...
You need to look at the wiring diagram pasted on the door panel to get a starting point where to look. I suspect a bad pressure switch, jump it out and see if it starts.
Mar 09, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Weathermaker SX Carrier 58SX060-cc-1
Your blower motor may have failed. Check the blower motor for the air circulation and you may find it is hot but not running. Have the motor replaced if this is the case.
Jun 11, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker SX
If you are running it in the cooling function, your drain maybe backed up. Find your drain outside if you can and suck it with a shop vac.
Nov 25, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
