Question about Ryobi 10 In Miter Saw With Laser
Craftsman miter saw 900233550 blade not cutting properly & keeps spinning but is tight. Is it stripped?
Older saw, worked well for sometime. Then noticed not cutting precise. When I stopped the cutting blade continued to spin, its tight. Do I need a new blade or is screws stripped?
5 Suggested Answers
  • 11 Answers
SOURCE: loose replacement blade
I completely removed the blade and put it back on, tightening the locknut, and now it works perfectly. The blade has not come loose and have used the machine for the last 3 months. The only thing I can think of is that somehow I didn't have the blade correctly installed in the first place, although it didn't wobble or anything.
Posted on Jun 05, 2009
Dolfoff
  • 148 Answers
SOURCE: I am looking for a repair manual for my 10" ryobi
Takes a bit of navigating to reach it, but I'll try to help you get there.
Start at this page HERE.
Click "Repair Parts Catalogue"
Click "I HAVE READ THIS PAGE & AGREE TO THE TERMS PROVIDED".
Click the "Model" tab located at top left of page.
In the box labeled "Model Name/Number" type in the following without the brackets [TS1342] and click the "Search" button to the right.
One (1) Result should be found. To the right is a list of two available drawings.
The one you seek is "General Assembly"
Hope this helps,
Dolf-
Posted on Oct 15, 2009
puertobori
  • 7733 Answers
SOURCE: electric brake on miter saw worked intermittently
The motor is burn.
Posted on Nov 09, 2010
  • 41 Answers
SOURCE: I bought the 10" compound
I have been in the same situation in the past, with a mastercraft miter saw to a point of using playing cards to get that nice tight miter joint. placing the cards between the fence and the piece i was trying to miter.Rioby makes mastercraft all thought they are a good saw they have their limits to the precisions of their cuts. good for fences,decks, stuctural framing ect, were a degree two is not a big thing,but when making furniture or interior trim work or picture frames or hobby craft you need to buy a good pro saw like a dewalt or bosh sliding compoud miter saw they may cost more **** their worth the money they are very precise and will last a life time if taken care of .It will be worth the money when you get that perfect cut every time you use it,it will put the JOY and fun back in your projects and not to mention qualaty in your master pieces.
Posted on Apr 01, 2011
The blade brake is not working on my miter saw.
Clean your saw ! Use your air compressor with an attachment to get back in the nooks & crannies, blowing all the caked up sawdust out.
Oct 09, 2014 | Skil 10-in 15-Amp Compound Miter Saw...
Craftsman miter saw motor runs blade does not rotate.
YOU PROBLEPLY WORE OUT THE WORM GEAR.ALWAYS KEEP YOUR BLADES SHARP. I HAVE THE SAME SAW AND THE ONLY PROBLEM I HAD WAS I BROKE THE DUST BAG OFF, MY FAULT.
Jan 31, 2013 | Craftsman 12 In Miter Saw With Laser Trac...
When turning off saw, blade continues spinning for 90 seconds or more.
Unfortunately, this is common on older model table saws. They do not have a blade brake and as far as I am aware it is nearly impossible to retrofit them.
If this is a newer model saw it's likely that the blade brake is malfunctioning and I have no experience with them.
Hope this helps and am very sorry if it doesn't.
Ken
Apr 13, 2011 | Craftsman Saws
Apr 01, 2011 | Ryobi 10 In Miter Saw With Laser
Saw is not cutting straight
Make sure the miter is lined up at 90 degrees to the blade. The fence has to be parallel to the blade and the blade tight. Cuts should be straight if the piece is held firmly and you move at the proper speed. Good luck!
Mar 05, 2011 | Dewalt D24000S Wet Saw With Stand
Have an older Sears Craftsman 10" Table Saw, model
you should be able to order one from sears. another place to look is ebay. the round plastic thing is to mark with pencil the cut of the blade. put in your sliding miter Gage set at 90 deg. put a piece of wood on it, push forward and cut the wood then slide back and mark the wood position on the plastic. that's the point where your blade cuts
Dec 30, 2010 | Craftsman Saws
Saw blade loosens no matter how much or often I
put a little bit off LOC-TITE on screw, worked for me
Apr 08, 2010 | Craftsman 8.0 amp Reciprocating Saw
I have a Craftsman 10" table saw model number: 137.248830. The saw doesn't make square cuts, it is more of a problem when using the miter. I have followed the alignment procedure so that the right...
I assume that your alignment procedure is about adjusting your miter gage. But you should first verify if the blade is parallel to the miter slot (the slot the miter gage slides in). This is adjustable underneath the saw, and sometimes comes crooked from the factory or comes loose later on. To check if the blade is parallel to the miter slot you can do this.....1. unplug the saw. 2. Raise the blade as far as it will go. 3. Clamp a piece of wood to your miter gage so that it just touches the blade as close to the front of the saw as possible. 4. Use a marker and mark that spot on the blade. 5. Now slide the miter toward the back of the saw, and rotate the blade by hand so that your piece of wood hits the same spot as where you checked in the front. You can see a large misalignment by eye. But you can get a little precise by using a piece of paper between the wood and the blade as a feeler gage. Or better yet, use a drop indicator instead of the piece of wood and you can measure the difference. If this isn't as close to parallel as you are able to measure it, you need to turn the saw over and find the bolts that attach the whole assembly under there to the table top. Once you have this in alignment, you should be able to set your miter to be square against any good square. If you don't have a high quality square, you can go to a tool store (Sears or whoever) with your miter gage in hand, and set it to be square against their most expensive square. If the square is square, and the blade is parallel to the slot and it still won't cut square you either have a bad blade or there is too much play in the saw's arbor. Try to wiggle the blade side-to-side - any wiggle at all is too much.
Jan 20, 2010 | Craftsman 10" Table Saw
Loose replacement blade
Jan 25, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Ryobi 10 In Miter Saw With Laser Logo
55 people viewed this question
Top Ryobi Saws Experts
JOHN LAPIER
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
