Question about everbuying Cheap Cell Phone 4 inch WALSUN S2 Android 4.1 3G Smart Phone MSM8625Q SKUD Quad Core 1.2GHz IPS Screen 4GB Bluetooth GPS WiFi 5MP Camera 4GB Blue
Walsun s2 not opening 3g - everbuying Cheap Cell Phone 4 inch WALSUN S2 Android 4.1 3G Smart Phone MSM8625Q SKUD Quad Core 1.2GHz IPS Screen 4GB Bluetooth GPS WiFi 5MP Camera 4GB Blue
How to unlock a samsung galaxy s2 net work with imei number null
You have managed to corrupt your EFS folder where your IMEI is stored.
Usual reason is that you have installed a non network firmware on a network locked phone.
Reinstall the network firmware to resolve IMEI NULL issue.
Once the issue is resolved, Get the IMEI number by typing *#06# on your mobile phone and get the IMEI number. Then visit
OnlineGSMunlock.Com to get the unlock code for your Samsung Galaxy S2 at affordable cost. with easy unlocking guide. Good luck.
Apr 23, 2014 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
I forgot security password
Hi if anyone uses the V900 B2 camera in the UK on the Vodafone Network then input the following to get it to work. #145#vodafone# if you want the mms capture to your phone #145#vodafone#http# if you want the mms cature to your email address. I have tested this on a pay monthly Vodafone sim.
Feb 11, 2014 | POWERGEN Pgmpp5200 5200mah External...
My Samsung Galaxy S2's 3g stoped working for no apparent reason. I have tried everything, has anybody got a solution for this problem?
Contact your service provider and ask them to restart your phones connection. This should make your connection better.
Oct 26, 2013 | Google Gmail
Open unlock s2
You can unlock your Samsung Galaxy S2 using unlock codes. Contact your service provider and get the unlock code from them, if not, you can get it from online sites. Try Superunlockcodes.com , they provide codes at affordable price, along with simple unlocking instructions.
Aug 24, 2012 | Samsung Galaxy S Ii S2 I9100 16gb Unlocked...
How to turn on 3G network on Samsung galaxy s2?
Settings > More Setting > Network Settings > Mobile Networks > Network Mode > WCDMA Only or WCDMA/GSM (auto connect)
WCDMA Only is is you only want to use 3G.
If you want that your phone should switch between 2G and 3G mode automatically, use auto connect option.
For this, your SIM Must support 3G services.
Jul 18, 2012 | Samsung Galaxy S2 GT-I9100 Unlocked GSM...
Is there an online user manual for HDC A9100 Galaxy S2 Android 2.3 Capacitive Smartphone Dual Core Dual SIM 3G 4.3 Inch GPS 8GB
HDC A9100 MANUAL PDF -
http://ebookbrowse.com/gdoc.php?id=365650386&url=1bc596eddad383bcb86d16af5c98d1cf
May 29, 2012 | Cell Phones
Hi.. please help me.. my minolta dialta 183 is not working.. there's a code CO5 in the screen.. please help me to fix it.. thanks
C0500: Warm-up failure
Step 1
Check:
Fusing Heater Lamp (H1) turns
ON.
Step 2
Check:
Fusing Heater Lamp (H1) is open-circuited.
<Check Procedure>
Check the resistance across both
ends of the Fusing Heater Lamp
(H1).
The Fusing Heater Lamp is open-circuited
if the resistance is infinity.
Result: YES
Action: Change Fusing Heater Lamp (H1).
Step 3
Check: Thermoswitch 1 (TS1) is operational.
<Check Procedure>
ends of the Thermoswitch 1 (TS1).
The Thermoswitch 1 is open-circuited
Result: NO
Action: Change Thermoswitch 1 (TS1).
Step 4
Check: Fusing Unit Interlock Switch (S2) is
operational.
<Check Procedure>
Check continuity across terminals
when the Fusing Unit Interlock
Switch (S2) is turned ON.
• Across S2-1A and S2-1B
• Across S2-2A and S2-2B
Result: NO
Action: Change Fusing Unit Interlock
Switch (S2).
Result : YES
Action: Change DC Power Supply (PU1).
Step 5
Check: Thermistor (TH1) is open-circuited.
<Check Procedure>
Check the resistance across CN15-2
and CN15-3 on the Fusing Unit side
with CN15 disconnected.
The Thermistor is open-circuited if
Result: YES
Action: Change Thermistor (TH1).
Step 6
Check: The following voltages are supplied
from the Master Board (copier: PWBA).
<Check Procedure>
Check voltage across a Master Board
(copier: PWB-A) pin and GND when
the Power Switch is turned ON.
• Voltage across PJ10A-7 and GND
DC24 V when Fusing Heater Lamp
(H1) is OFF
DC0 V when Fusing Heater Lamp
(H1) is ON
• Voltage across PJ10A-10 and
GND
(H1) is OFF
(H1) is ON
Result: NO
Action: Change Master Board (copier:
PWB-A).
Oct 05, 2011 | Konica Minolta DiALTA Di200 Copier
Minolta dialta 183 help me... theres a code in the screen CO5 .. and automatically turn off.
Step 1
Check:
ON.
Step 2
Check:
<Check Procedure>
(H1).
Result: YES
Step 3
<Check Procedure>
Result: NO
Step 4
operational.
<Check Procedure>
Result: NO
Switch (S2).
Result : YES
Step 5
<Check Procedure>
Result: YES
Step 6
<Check Procedure>
(H1) is OFF
(H1) is ON
GND
(H1) is OFF
(H1) is ON
Result: NO
PWB-A).
Oct 05, 2011 | Minolta DiALTA Di183 Copier
Need to reset samsung galaxy s2 phone. Can't
If you want to try a simple solution, Go to Settings, Wireless and Networks, then Turn on "Airplane Mode" wait until you see an airplane on the top status bar of your phone... then Turn OFF "Airplane mode"
If that doesn't work, and you want to reset your phone, take it to the place you bought it or any place that is on your carrier.
May 18, 2011 | Samsung Galaxy S GTI9000 Smartphone
everbuying Cheap Cell Phone 4 inch WALSUN S2 Android 4.1 3G Smart Phone MSM8625Q SKUD Quad Core 1.2GHz IPS Screen 4GB Bluetooth GPS WiFi 5MP Camera 4GB Blue Logo
Top everbuying Video Game Consoles & Games Experts
James Wishart
Are you an everbuying Video Game Console and Game Expert? Answer questions, earn points and help others
