Question about Mitel Computers & Internet
Can't make outgoing calls mitel - Mitel Computers & Internet
Outgoing caller id
Must be done in the controller. 3300 is CPN substitution. 5000 is Calling party number. Telco must except the service. Not sure of what I said? Contact your dealer. This is not something you set up from your phone.
Mar 17, 2014 | Mitel 5330 IP Phone
Can't transfer calls
Call Transfer is a Class Of Service controlled function. If you can't transfer it's because your phone is in a class of service (or possibly Class Of Restriction) that disallows it. Note that transferring an incoming call to an outgoing line is frequently barred on some corporate phone systems to prevent toll fraud or abuse. Check with your phone system support person.
Dec 31, 2013 | Mitel Superset 4025 Corded Phone...
We have a Mitel Superset 4025 corded phone. We have moved offices and cannot locate the manual. We are trying to change the outgoing message on the mainline and need to know what steps to take to do so.
The recording would be in your auto attendant system which would be with the phone system and not a single phone. More detail is needed to answer your question. A call to your phone vendor would be in order to gain access to the recordings. The vendor should have helped if a system move was also involved in the office move.
Aug 19, 2013 | Mitel Superset 4025 Corded Phone...
Is there a way to block a specific phone number on Mitel Superset 4025?
Normally no. Your phone is part of a business telephone system. The system allows the sharing of incoming/outgoing telephone lines. If you need a specific phone number blocked, it will have to be blocked on these in/out lines. Unfortunately such lines are considered business class lines and you normally cannot block a specific number from calling you.
If you have trouble with a specific number, I believe you will have to contact the police before your carrier will be able to provide a block.
Apr 12, 2011 | Mitel Superset 4025 Corded Phone...
Need to re-set my 'outgoing' answerphone message i have a mitel 5212 phone help
Log into your mailbox. Press U(8) for User Options, press G (4) for Greeting. Listen to the prompts to change the greeting.
Nov 05, 2010 | Mitel 5330 IP Phone
Mitel 5212 no dial tone and goes straight to voicemail
Not too sure about the no dial tone issue, but you can check to see if the DND is turned on...
Press the Blue Superkey and scroll thru till you see DND (Do Not Disturb) is on and shut it off.
Jul 20, 2009 | Mitel 5212 IP Phone
I want to block outgoing external calls
Need to program class of Restriction in the phone system. And give COR to that phone.
Apr 16, 2009 | Mitel Superset 4025 Corded Phone...
Mitel 5220 IP phone won't ring when the main line is ringing
WOW
Ok this post is OLD, but for anyone else having this issue, this is the solution...
There is a programming feature that states: DELAYED RING on certain lines, meaning you can physically see a call coming in to the system (via line flashing), but it will not ring at your desk till something like the 4th ring(hence the name DELAYED ring).
If your set does not ring, and you pick up the heandset, the phone system doesn't know if you want to answer the call -or- you just want to make an outgoing call...
Therefore the Mitel system picks up internal dialtone and waits for you to make the initial reaction (hit 9 for a line out or hit a line that is flashing on the set).
Too change this option, a Mitel Tech is required...
Jan 23, 2007 | Mitel 5220 IP Phone
Computers & Internet Logo
50 people viewed this question
Top Mitel Computers & Internet Experts
rey francis basa
rey francis basa
danoyachtcap
danoyachtcap
Jay Plesset
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
