Question about Fellowes Intellishred SB-89Ci Shredder
Fellowes S8-89CI does not turn on
Power cord is plugged in but the switch on top does not turn the unit on. Help?
3 Suggested Answers
t_vinson57
  • 58 Answers
SOURCE: Fellowes S701CM Shredder.
You can check the switch out by spraying some WD-40 in it, that clean the contact in side the switch
Posted on Mar 29, 2009
  • 32 Answers
SOURCE: Fellowes PowerShred PS 40 with defective switch
Its just seated together with the gear/blades housing ,
make sure you didnt miss one screw, then pry and pull upward its just stuck as the gear housing and blades are pressed in and seat firmly making it seem like its stuck , over time all that paper goo is also binding it up .
Heres a few sites that have gears another that has manuals you may have to call or email as not all parts are listed on website
http://www.compax.com/shredders/parts.html
http://wheelermachines.com/manufacturer.html
http://www.manualsonline.com/ex/thread/view/idThread/1735067
Posted on Sep 01, 2009
Why do my fellow ds-3 shredder not turn on?
http://assets.fellowes.com/manuals/DS-3%20Manual_1L_2010.pdf
Check and make sure the receptacle where it is plugged in has current. Unplug the cable and then plug it back in. You have an Over-ride switch on your unit, try it. If it still does not work you will have a power supply problem.
Aug 18, 2014 | Fellowes 3231001 8-Sheet Ds-3 Deskside...
There seems to be a power ise when switch ingages breaker shuts off
I own a Fellowes PS 60 shredder.
I DO NOT THINK THE LINK WILL HELP YOU, BUT AT LEAST YOU WILL HAVE IT.
I advise you NOT to use your shredder if it is causing the cicuit to shut off_it may start a fire!
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Jan 11, 2014 | Fellowes Powershred PS-60 Shredder
Fellowes 58-99C - unit is on, power is on, the on/off button will not turn on.
This unit has a bin power actuator switch, if the bin is not in correctly or the post that turns on the switch is broken the unit will not turn on.
Aug 29, 2011 | Fellowes SB-99Ci Shredder
Our P58Cs is no longer turning on - no lights come up. We swapped the fuse in the plug with a plug that is working but this didn't help. Does anyone have any idea why
"" Unplug the unit first! "" The shredder head "top" has a small silver safety switch on the underside, this has to engage with a TAB on the side of the basket for the unit to power up, carefully look on the underside for it. put it back on the basket, once engaged it should work.
BE CAREFUL.
Jan 19, 2011 | Fellowes P58CS Cross Cut Shredder
OD700C Fellowes Shredder blades don't turn
There is a screw hidden under one of the stick on labels. Remove that and the top comes just fine. I got it torn apart, completely cleaned of debris but the rollers still don't turn. I noticed an electrical arc when the switch is pressed so the unit is toast.
Feb 22, 2010 | Fellowes OD700C Shredder
Had overheated. Now after several hours the green light and red light go on. No motor sound??
hi,
Turn it off and let it sit idle for about an hour. This should cure an overheating problem
For no power and green light and red light go on, the problem is with power switch- top of unit.
After remove all screws, you need LONG-LONG screwdriver and one short screwdriver with out handler, because few screws almost imposable to remove. you make few holes on bottom of unit to remove 4 screws.
you have two ways to fix switch problem-
1. replace it, if you can find new switch.
2. solder two wire to switch and make a hole on top of unit. when you need to power unit, turn back switch on and touch two wire as switch.
Jun 08, 2009 | Fellowes DM8C Cross-Cut Shredder
Unit has power from Plug to unit. Current flows all the way to switch and switch seems to be ok but unit will not turn on. Wife says it was cutting on and off when moving it around. Checked conntec
you either have a bad switch oir you have a short in the cord.plug it in and turn it on then move the cord around from top to bottom and see if it acts up..if not tap on the switch afew times and if it cuts out then the switch is bad.try to plug it in in a couple of different outlets and see if it does the same thing.it could be a bad outlet.plug it in one thats pretty tight to push in and pull out.
Apr 29, 2009 | Vacuums
Mar 09, 2009 | Fellowes S701CM Shredder
Fellowes 425AP wont power up
When moving UPS batteries you need to unplug them from the unit internally to keep them from discharging completely. If the battery is beyond 2 y/o it is probably shot.
I would NOT replace the battery however in a "possibly-bad" unit. The cost of purchasing an entirely new unit (locally, without shipping cost) is just too inexpensive.
Jan 31, 2009 | Fellowes 99052 UPS 425VA Battery Backup...
Have power to board, but light, no motor operation
I don't think this model has a fuse on the PC Board but if it does, unplug the power cord.
Remove the top cover (2 screw front and 2 screw back). Check board and check all connections.
It's probably just a defective switch. The only other thing that would cause this problem would be a defective Main PC board.
Dec 08, 2008 | Fellowes Powershred 480 Shredder
Fellowes Intellishred SB-89Ci Shredder Logo
188 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
