Question about Frigidaire FEQ1442ES Electric Dryer
Feq1442es1 My dyer has a loud squeaking noise!
Dryer has a very loud squeaking sound as drum turns, The squeak not there all the time but most of the time it squeaks as the drum turns.
  • 333 Answers
SOURCE: There is a squeaking sound when running the dryer
Follow this link and click on pruduct manuals or search this page. If you can not find it contact customer service. I hope this helps you.
Posted on Nov 28, 2008
  • 221 Answers
SOURCE: Dryer making loud squeaking sound
Try checking the glide wheels under the barrel they may need to be cleaned and lubed.
Posted on Mar 11, 2009
iwillfixforu
  • 619 Answers
SOURCE: squeaking when dryer runs
Yes. Replace the rear bearing cup that the drum sits down into. Do not oil. This cup takes a special grease that you can get with the cup. Also don't let anyone try to sell you the whole bearing kit. All you need is the cup and the grease.
Posted on Feb 01, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Our dryer has a terrible squeak. We replaced the
The terrible squeak is probably the idler pulley shaft spalling in the idle pulley mount. When the idler pulley siezes to to pulley shaft it spins in the mount and makes a horrible racket.
It can be the motor bearings also but I doubt it at this time. With the belt off you can spin the motor and listen for any odd sound. If you hear nothing then the problem is definately the idler pulley assy.
It is normal for the drum to float in place. When there is a problem with the drum or drum felts, you usually hear a cyclic scrape or grinding sound that is concurrent with each rotation of the drum.
Thanks for using FixYa.
Kelly
Posted on Mar 05, 2010
  • 5 Answers
SOURCE: My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Posted on Apr 01, 2010
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
I HAVE A GE GAS DRYER MODEL DDG5980VALWH SER. 3F302890G. WHEN THE DRUM TURNS IT MAKE A THUMPING SOUND,,NOT REAL LOUD. MORE OF A THUMP THEN A SQUEAK.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 12, 2010 | GE Dryers
Very loud squeaking noise - like a noisy loose fan belt on a car.
The dryer needs to be rebuilt, new drum belt and drum rollers to cure this problem.
Mar 24, 2017 | Frigidaire FDE336RE Dryer
Whirlpool LEW0050PQ electric dryer makes a noise.
heatman101
sdfhywt4
May 22, 2010 | Whirlpool LEW0050P Electric Dryer
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Sep 20, 2009 | Kenmore Dryers
Squeaking dryer drum when operating
sounds like you need to adjust the motor that turns the drum to tighten the drive belt..... you do this from the back or bottom...
May 24, 2009 | Fisher and Paykel DG05 Gas Dryer
Dryer drum squeaking when operating
heatman101
fggf
May 24, 2009 | Fisher and Paykel DE60FA-US Dryer
Squeaking noise
Noise from dryers can be eliminated through the following checks
* Level the dryer
* Check the drum belt
* Check the drum support rollers
* Check the idler pulley
* Check the glides
* Check drum bearings
* Check the blower
* Check the baffles
Apr 10, 2009 | Maytag Dryers
Frigidaire FEQ1442ES Electric Dryer Logo
26 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
