Question about Electrolux Dishwashers
Electrolux WT150 EL
I have a problem in an electrolux dishwasher WT150 EL, which is the water doesn't get into the cabinet automatically, i've changed the solinoid valve but the solinoid doesn't get the signal to open and let the water pass through,,i guess there is a problem in the pressostate,so i changed it with a new one and nothing fixed,i can't get the water automatically and the boiler and also the other heating elements don't work then !!
  • 1314 Answers
SOURCE: Electrolux ESL 6225
before you operate the dishwasher get your water as hot at the sink as you can this will prevent filling the dish washer with cold water and i would use powder or liquid now if you not sure of your heating element turn your washer to dry close the door for about 2-3 minutes get a glass of cold water open the door and pour water on the element if it sizzles its working
Posted on Feb 12, 2008
  • 54 Answers
SOURCE: Electrolux esl624 heater element replacement
open the door remove the plinth (2 screws) then there is 2 screws higher up remove these (some people remove outer door panel to get easy access) then leaver the front plate up. then you can see the wires on the heater and the bolts are between them. hope this helps
SOURCE: electrolux de 6850 dishwasher
I followed some of the good instructions already on Fixya. I had checked the heater and it was o.k. I then took the front door of the washer apart to get at the control box. Sure enough, I also had the common design fault. One leg of the rely had scorch marks and was now disconnected from the circuit board. I will solder tonight and test. I include a photo of the burned board. TNoel P8017c86.jpg
Posted on May 08, 2009
  • 103 Answers
SOURCE: I have a Zanussi Electrolux ZSF6126 and the
Check to see if the heat element in the bottom inside is all crusty or cracked, if so replace, if not, unplug unit from house current, pull bottom toe panel off, you should see where heat element comes thru cabinet and has two wires attached, remove wires, take ohm meter and check for reading, if reading is ok then you either have bad control timer circuit (main board) or blown thermal fuse. Call tech to check further if you do not have original tech sheet or electrical background. My bet is that you have a bad heat element.
Posted on Nov 12, 2009
Testimonial: "Great advice-I am not very confident electrically so looks like I need to get the bobs together and pay technican. Now I can tell him what problem is"
tattootech2
  • 72 Answers
SOURCE: All the light on my new, Electrolux dishwasher are
Remove the kickplate at the bottom of your dishwasher and see what error you are getting. Likely a leak error.Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Posted on Apr 07, 2010
Dishlex 302 leaks from underneath
Good Morning Friend,
This appears to be a UK Electrolux dishwasher; however, if you have a US Electrolux model, here are a few tips you can attempt to troubleshoot the issue: First, Use only fresh detergent designed for automatic dishwashers. Measure detergent carefully. Possibly try a different brand of detergent. Secondly, spilled rinse aid can cause foam and lead to overflowing. Wipe up any spills with a damp cloth. Lastly, check to see if your dishwasher is level. If your dishwasher is still leaking, after trying the above solutions, I suggest contacting the manufacturer for further assistance. Hope this is helpful.
-Best regards-
WP
May 19, 2014 | Electrolux 18 in. ESL4114 Slim-Line...
Electrolux dishwasher leak detector light
This was a good answer. It reset the error. But once we started the washer up again it threw the same error. Next step, remove it from the cabinet and check for leaks.
Apr 10, 2014 | Electrolux 24 in. EDW5500DSS Stainless...
Electrolux ex302
Please check the following:
1) Your water in the house is hot enough. You may have to check you water tank.
2) You are using the correct settings for washing.
3) Your element is working correctly.
Mar 12, 2014 | Electrolux Dishwashers
What does L1 error code mean on an Electrolux dishwasher
The only solution I can come up with for this one is that L1 is a Leak Detector problem-When water is detected under the tub. I spent an hour researching this issue. I've never come across this one before.
May 11, 2012 | Electrolux Dishwashers
I've got an electrolux dishwasher and the heating element appears to have failed. Can I get a spare part and install it myself?
You do not have to be suspecting unless it is taken out and tested using a multimeter. If there is not continuity of the coils or if there is a short in the coil to the body then the heating element is faulty. If not the switch on relay is faulty.
The same type element must be bought from your Electrolux dealer. Please check if there is any help from the link below for spares; Get elements from :
http://www.espares.co.uk/search/dishwashers/electrolux/p/1083/15
Aug 30, 2011 | Electrolux Dishwashers
Electrolux error code 1, how to reset.
Also got error code 01. Unplugged dishwasher, turned off water supply, disconnected water supply line at sink so it had slack to pull dishwasher out of built-in space, removed two wood screws holding dishwasher to counter, pulled it out onto floor, put it on blocks as reader suggested, tilted to side 45 degrees, water drained out onto rags. Then restored to upright, restored supply line and opened valve at sink, plugged back in, unit automatically reset, returned to built-in, reinstalled screws to counter. Worked like a charm. Took more time to read everyone's advice than to do the job (about 30 min.). Thanks.
May 20, 2010 | Dishwashers
Ewdw6505gso electrolux. error 1. have turned off
the water will have leaked into the drip pan underneath, which is installed to protect your floors. Unfortunately, only way to get at it is to pull out dishwasher and remove 3 phillips screws that hold it on. In order to repair leaks, Electrolux came out with a "leak kit", which is part number 154769101. Comes with all parts that they had leak issues with
Mar 14, 2010 | Electrolux EWDW6505GS Fully Integrated...
Dishwashers Logo
76 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
