Question about HP Compaq Presario V2000 Notebook
System fan 908b
Need to find out how to do a hard system restore
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 265 Answers
This varies by make and model so you would need to provide this information for a correct answer.
Posted on Nov 21, 2013
Dell inspiron problems
you should open the desktop and clean it all the fans the graphic card etc i am sure it will help you out .
Feb 16, 2014 | Computers & Internet
How do i restore my acer aspire M3710 back to its factory settings without a disk?
The Windows (or other OS) settings would not prevent it from turning on. Based on your info:
Power supply - could be intermittent or overheating. Check that the fan spins. If the power supply fan has a squealing or grinding sound, then the fan is going out and could be stopping some of the time causing overheating. Also check the heat output by holding your hand by the fan exhaust and see if its overly hot. That could also shut it down intermittently.
CPU - overheating is possible. Many systems have shutdown temperatures to protect from overheating. Check that the fan spins up and is not plugged up with dust. If it squeals or grinds or makes abnormal noise, replace it because it will freeze in the near future. If you've separated the CPU from the fan recently, maybe the thermal paste wasn't applied fresh or properly. If you go into the BIOS, many computers allow you to view the temperature, voltages, etc., so you can check if its a CPU temperature problem. There are also many free programs that will monitor your computer temperatures and display them in the system tray. I can also suggest a program that will tell you everything about your computer (temps are under sensors):
www.gtopala.com
However, if you want to restore your computer, many have a restore option on the bootup splash screen. To save on the cost of DVD's, they create a "restore" partition on the hard drive. Sometimes the restore function will save existing data by restoring Windows only, without erasing the hard drive first. You will get ample warning if it will erase your data. If you don't have a restore function, then you'd have to buy restore disks from the computer manufacturer. The usually run less than $30.
Jan 23, 2013 | Acer Aspire M3710
Emachines E527 wont boot up
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell
you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs
accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
if the system restore fails
test your PSU or replace it if your power supply units fan is not working your PSU is faulty
one bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
test all power and data leads that attach to your hard drive IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty
computers need data and power to travel through every working device and to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty power connection or faulty fan lead can cause you problems
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer ram modules make sure they are securely seated
on some motherboards cmos batteries are soldered in
hope this helps
Jul 26, 2012 | E-Machines emachines (emachinees) CD-ROM...
Hard disk is corrupt will restore
Hi.
That happens because the hardware is defective. The restore will reinstall the system on the defective hard drive. After restoring the system the console will not start because the hard drive where the system has just been restored is broken.
You can attempt to recover the hard drive connecting to a computer, rebuilding partition and doing a complete formatting. Most of the times you need to replace the disk.
Regards.
Ginko
Dec 15, 2011 | Sony Playstation 3 (PS3) Console
Hello the fan of the northbridge of my MS 7125 does not rotate, and when i boot up it lock down on Loading screen
HI. This issue with the NB fan will be a direct result of fan failure. The actual fan motor assembly may be shorted or disabled. This fan should be replaced asap(make sure to check the fan connector for proper connection before replacing the NB fan). Now, concerning your halted boot screen; This will be a direct result of a failed or corrupted OS(Operating System). I would recommend to initiate a system restore by inserting the restoration CD/DVDROM that came with the CPU system, when purchased or delivered. This will totally reinstall the OS and correct all corrupted files that have been affected by this unfortunate virus/worm attack.
Due to the fact that your system will not boot up, you will need to insert the restoration CD/DVDROM into its respective ROM device and shutdown the unit for five minutes. Once the shutdown has occurred, simply, restart your unit and follow the restoration instructions on screen during the hard boot. It may be necessary to self initiate the restoration by booting from the actual ROM device, via f11 or f9 command upon boot screen.
Sep 04, 2011 | MSI K8N Neo4-F Motherboard
Not detecting the Hard Disk....
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work but if it is you should
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or faulty fan lead can cause this problem
a computer needs all of the data and electrical power to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also check the Cmos battery and computer ram make sure they are securely seated
another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory
hope this helps you
Aug 25, 2011 | Hitachi HTS542512K9SA00 120 GB SATA Hard...
Attempted to power up my laptop as i normal did and it said windows boot error i think. I tried restoring it to a earlier date. I tried recovering/restoring it to the entire Hard Drive w/ 2 partitions. The...
I am thinking you may have overheating problems.
Look around on the base of the machine for access panels, remove these and look for your cooling fan. Clean this fan to the best of your ability and also, try to remove the fan as you can get quite a build up of dust between the fan and the heatsink. After you have cleaned these areas, try your machine again. You may well have to restore the hard drive from scratch again. (as you have started this operation, it is unlikely that you have been left with a working operating system at this point)
Hope this helps.
May 12, 2011 | ASUS Computers & Internet
Compaq Presario C-500 powers up but can not get past the Compaq LOGO Screen. Tried removing battery, Control/Alt /Delete Suggestions?
This sounds like a hard drive issue. Let the computer run for about five minutes and touch the bottom to see if the laptop is getting hot. If it is extremely hot, then a fan will need to be replaced. Overheating of laptops is the number one cause for hard drive failure. If the fan is replaced, then the hard drive might still be good.
Also, you may have had a virus, which is what is keeping you from booting into the Windows environment. You will need to reformat the computer but will loose all information if you do this yourself. If you are running Windows XP, you will need to purchase a restore disk from the manufacturer. If you are running Windows Vista or 7, boot the computer on and immediately (before the Compaq logo comes on) tap F8. Choose advanced options and choose to factory restore the computer. As mentioned, this will completely erase the hard drive and everything in it.
Sep 17, 2010 | HP Compaq Presario C500t Notebook
Hard disk file system corrupt
Bad sector or MBR on Hard drive needs replacing
Mar 21, 2010 | Sony Playstation 3 (PS3) Console
My Sony Vaio PCG-K25 wont gp pass the black screen. I hear the fan and the power is on but the screen remains black. I took the battery out and had it powered through the chord. Still now working. Please...
Hello.
Either you have a memory issue or operating system problem.
First, try reseating (removing and reinserting) your memory (try one module at a time to test).
If still a problem, boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
If still a problem, the last choices are Factory Restore and reinstall. Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Follow the prompts.
If still not resolved, you'll probably need to reinstall your operating system.
Hope this helps.
Dec 08, 2009 | Sony VAIO PCG-K25 Notebook
HP Compaq Presario V2000 Notebook Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
