Question about Rapid 5080 Electric Stapler
Rapid 5080 doesn't work - Rapid 5080 Electric Stapler
What kind of memory card does it take
The PDC 5080 uses SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Apr 07, 2011 | Polaroid PDC 5080 Digital Camera
I haven't used my DS-5080 for about a year, and now when i plug it in to charge it (USB or Power Supply), it gets stuck on the intro (startup) screen. And will not continue from displaying "DIGITAL...
I think there is a problem with your memory card. Remove the card and then check weather the camera is working fine or not. If it works, then format the memory card in a computer or laptop(not in your camera). The problem should be solved.
Please rate the answer. Thanks for using FixYa.
Jan 11, 2011 | Optimus DS-5080 Digital Camera
Hi there, i have a premier digital camera ds-5057, how do i turn on the flash light?
hi i have a camera premier ds 5080 the flash dont work how do i put it on?please help.
Apr 17, 2010 | Optimus DS-5080 Digital Camera
Not working
This camera is probably a 5.0 megapixel camera and is a few years old. The cost to repair may be more than what you want to spend on it.
Make sure that the battery (batteries) is or are charged or good. If you cannot get the camera to turn on, then some problem exists which needs repair.
Dec 19, 2009 | Optimus DS-5080 Digital Camera
Optimus Premier DS-5080 Picture over exposure
i need a charger for premier ds-5080 camera any ideas please
Jun 20, 2008 | Optimus DS-5080 Digital Camera
Polaroid pdc 5080
 pls download the manual, memory card , compatability is a problem . panasonic,scandisk,toshiba only  will work. if you put other m cards , the picture will be very bright-negative effect
Mar 09, 2008 | Polaroid PDC 5080 Digital Camera
Rapid 5080 Electric Stapler Logo
Top Rapid Office Equipment & Supplies Experts
Bill Boyd
Are you a Rapid Office Equipment and Supply Expert? Answer questions, earn points and help others
