Harwi piranha 1550
Wood working machinery
Stanley wood chipper CH5, electric starter not working. Has power to starter when I push starter button nothing happens. Any suggestions?
solenoid has power in/out with heavy gauges wire?
starter button is supplied with power and/or continuity between ground and button and button and solenoid?
Dec 08, 2016 | Stanley Heavy Machinery
Can I still get saw blades for this scoll saw if so need to know where and part number
most scroll saws use a standard length blade with standard end fittings
try a good tool shop or wood working tools supplies for blades for your machine or any shop that sells wood working machinery
Jan 06, 2016 | Saws
I need all manuals for my SAC RS 63-S Surface Planer
Planers - Single - West Coast Machinery
www.wcmachinery.com/WCMACHINERY/myinventory.asp?...S...
Delta/Invicta RC-63-D 24" Planer in excellent condition. ... Table jack screw sprocketshave been replaced ... 16" single surface planer, - 5HP 208-230 volt single phase belt drive motor, - push ... with operation manual, - excellent condition but offered "as taken from service". ... 2240/440V, three phase S/N 203851 1974 year.Missing: my
Wood working machinery > Planers > Thickness planer (used)
www.machineseeker.com/2-106-65.html
Used Dickte SAC, further information will follow shortly... 2.500 EUR ... Thickness Planer, Thicknesser Huefner & Soehne 63 ... Thicknessing machine Sicar S 500... Working width: 500 mm Working height: 200 mm 2 speeds 2 Table rollers manualtable lift 4 knives - Safety shaft. ... Thicknesser mitTersawelle SAC RS 53Missing: my
Woodworking Planers - Southwest Machinery & Equipment
Dec 14, 2015 | Masonry Tools
Instructions
THE INSTRUCTIONS Are first you get either double A or triple A batteries and put them into the bottom of the game ,NEXT you put the piranhas into the base.last use the piranhas to try to get to the top of the game with running into obstacles in the way.
-ANNA LEIGH MASON
Jul 14, 2013 | Mattel Piranha Panic
What should I feed my piranha?
Piranhas are omnivorous, so they will need a well-balanced diet. I recommend buying frozen foods or freeze dried foods from your local pet store. To add variety to the proteins you will be feeding them, you can also feed your piranha some fresh vegetables such as some raw potato/spinach.
Aug 29, 2012 | ANIMATE Fish
I need the instructions of piranha panic board game please
How to Play:
When your turn starts you roll the die
» If you roll a number (1 or 2) you can move one of your 3 fish-marbles the number of spaces rolled. You can "swim" forward, left, or right, but not diagonally. Fish also cannot jump over other fish (so it is possible to box some players in so that they cannot move at all)
» If you roll a blue fish, then that's the same as "lose a turn"
» If you roll a piranha, it's time for a piranha attack! You must roll the die again to determine how they will attack. If you roll the blue fish then the attack has been averted. If you roll a number, that's how many piranhas will attack. If you roll a piranha, then all 4 piranhas will attack (that's the "piranha panic!") You place the appropriate number of piranha marbles up on the top, "piranha zone" row, then pull the release lever to drop the marbles down and trigger the feeding frenzy.
The object is to have your fish "race upstream" and make it to the safe area. The first player who gets all 3 of their fish into the safe area wins!
Mar 21, 2011 | Computers & Internet
I own a 16" wood planer and I cranked the wheel down a little to much and it seems like I have broke the shaft on the blade. The name on the planer is central machinery but i cannot seem to find that...
Harbor Freight is the dealer for Central Machinery tools. Take your model number, and look it up on their website. They have all the parts available by mailorder. I have a electric jack hammer and have ordered parts for it, as well as a wet tile saw. Hope this helps.
Nov 02, 2009 | Jet 16" Wood Planer - 708531
19 people viewed this question
jasbo
jasbo
