Question about Hitachi GF 2000 DVD-RAM Burner
Hardware i have 256 mb RAM. Can i add 1 GB parallel to it?
    President:
  • 2,961 Answers
If your motherboard can take 2GB, then yes, but you need to go to www.crucial.com and run a system test and it will tell you what your board supports.
Posted on Oct 09, 2007
SOURCE:
Is there a way the memory in a toshiba satellite 1005-s157 be increased to more than 512MB?
Yes you can, at least to 1 Gb maybe possibly to 2 Gb.
There will be two memory slots in your laptop. To increase the RAM to 1 Gb install another 512 Mb RAM module in the empty 2nd memory slot. Make sure you use the same make and speed RAM as the one that is installed.
If you have two 256 Mb RAM modules installed in your laptop then you need to replace the two 256 Mb RAM modules with two 512 Mb RAM modules to get a total of 1 Gb RAM.
Aug 04, 2012 | Toshiba Computers & Internet
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Computer beeps six times after installing new game. Precision workstation 670. Ram sticks are a 1GB each. My old ram works fine with the computer.
You need the EXACT speed rated RAM.
Your support page states it needs.....
400-MHz DDR2 SDRAM
NOTE: Your computer supports only registered memory
Memory capacities
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC modules to a max of 16GB
more info here
http://support.dell.com/support/edocs/systems/ws470/en/ug_en/about.htm
Jul 26, 2010 | Dell Precision Workstation 670 PC Desktop
T2742 Desktop eMacine I want to upgrade the RAM from 256 MB to 1 GB. Can I replace the single 256 MB memory board with a single 1 GB memory board? Or, should I use two 512 MB memory boards?
Maximum Total Amount is 1GB.
EACH ram slot's Maximum Amount is 512MB.
Note* If you only install one ram memory module, make sure it goes into Slot 1.
(On the motherboard it may have DIMM 1, printed next to the slot)
Slot one is closest to the Processor. The processor reads ram memory that is in Slot 1, first.
Apr 16, 2010 | E-Machines T2742 PC Desktop
I want to increase th DDR in my emachines T2682. how much can i increase it and do i have to make any changes.?
Go to this trusted site I use all the time. http://www.crucial.com/store/drammemory.aspx Click "Scan My System" accept the download of the scanner. When it finishes it will tell you what you have and what you can add, with the cost of all options. They have good prices and are very safe & reliable. From your model # unless changes have been made you have 256MB of Ram which is far to little for XP to run like it should. This is the bare minimum for XP. Buy and install at least 1 GB of RAM. It is a simple process and you will have to make no changes to the system. Once you install the new RAM and turn the computer back on it will recognize the new memory. Follow the directions for installing the Ram and make sure to wear a ground strap or ground yourself to the exterior of the case before touching anything inside. Crucial has a section on installing RAM which you should look at if you have never done it before. Your XP will fly with 1 GB of ram and this is the best money you can spend to make it faster. I checked their site using the model # your listed and you are in luck. You can purchase 1 GB of RAM, which they have on sale, for $38.99. You have 2 slots in your computer and you will be able to leave the 256 MB intact and add the 1 GB giving you 5 times the Ram you now have. You can see the results here. http://www.crucial.com/store/listparts.aspx?model=T2682&pl=eMachines&cat=RAM
Feb 12, 2010 | E-Machines T2682 (000002965) PC Desktop
Inspiron 6400 notebook
There are two slots for memory on that laptop and it will take a maximum of 2GB of RAM. The memory type is 1.8-V SODIMM DDR-2.
The cover ont he bottom if the laptop is easy to access and add more memory.
Dec 31, 2008 | Dell Inspiron 6400 Notebook
Ram Sharing
there is a hardware compatibility list for all pc, chances are your pc have exceeded its maximum allowance for any upgrade, even though you have installed a higher value or capacity of RAM.
try reinstaaling once again and make sure you have the right speed allocation on your RAM , make sure that the ols RAM and the new one has the same PC___
Aug 08, 2008 | Lenovo 256MB ATI X1600 Pro VGA DVI-I...
RAM Memory upgrade: 1gb modeles recognized as 512mb
You may have incompatible memory. double check your order and use only recomended name brand memory such as Kingston, you can look up the correct memory on their website, or on newegg.com
Apr 23, 2008 | Dell OptiPlex GX270 PC Desktop
P4vmm2 motherboard
you can add up to 2 gb RAM using either 2 x 184 Pin DIMMs or 2 x 168 Pin SDRAM DIMMs. However that MB does support pc400. The supported RAM speeds are 100, 133, 200, and 266 MHz
You can buy a pair of Kingston 256 MB DDR SDRAM PC2100 (266 MHz) from the kingston website for under $50
part no: KVR266X64C25/256
Kingston is a well known and respected manufacturer of memory.
Dec 15, 2007 | EliteGroup P4VMM2 Motherboard
Open Questions:
See all Hitachi GF 2000 DVD-RAM Burner Questions
Hitachi GF 2000 DVD-RAM Burner Logo
46 people viewed this question
Top Hitachi Computers & Internet Experts
Ekse
Alun Cox
Marvin
Marvin
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
