Question about Samsung " 30"" Self-Cleaning Freestanding Electric Convection Range - Stainless-Steel/Black FTQ353IWUX/XAA"
Error code E-08 when heating oven
I have already restarted and disconnected power and then restarted. Error code remains. How can I fix it?
What does error code E28 mean?
an F error code.
You have a function error code.
CODECAUSE
-SE-Shorted key
E-27Oven sensor opened
E-28Oven sensor shorted
E-08Oven heating error
E-0AOven heating over
E-0EDoor locking error
• Press the CLEAR/OFF pad and restart
the oven. If the problem persists,
disconnect all power to the range for at
least 30 seconds and then reconnect the
power. If this does not solve the problem,
call for service.
The surface units
will not maintain
a rolling boil or
will not cook fast
enough.
Improper cookware is being
Mar 26, 2015 | Samsung Kitchen Ranges
Error Code E-08 on Samsung Gas Range. Oven will not heat but range top works.
Is there a gas pilot light that stays lit all the time or does it have an electric pilot light that glows red to start the oven.Either way if it's a gas pilot the thermocouple is bad, if electric the igniter is bad.
Jan 03, 2014 | Samsung Kitchen Ranges
I have a Toshiba 350 copier ans it has a error code c440
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
When this code not cleat 08-400 then check these all thengs..
1.Check the thermistors
(1) Check if the connectors are disconnected.
(2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly?
(3) Check if the harnesses of the main and edge thermistors are open circuited.
2. Check the IH board and IH coil
(1) Check if the IH coil is broken.
(2) Check if the connector of the IH coil is disconnected.
(3) Check if the thermostat is blown.
(4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector
CN455/456).
(5) Check if the IH board or the switching power supply unit are abnormal.
• Replace the IH control board.
3. Check the LGC board
(1) Check if the connectors CN316 are disconnected.
(2) Check if the conductor pattern on the LGC board is short circuited or open circuited.
(3) Replace the LGC board.
please vote me.
Thanks
Best Regards
Mar 07, 2012 | Toshiba e-Studio 350 Copier
What does F13 Error mean?
Here is what the F-13 error code means and the fix for it.
F13 Internal CPU checksum errors 1. Disconnect power for 1 minute.
2. Reconnect power.
3. If failure remains, replace the touch control module
So it says the main computer control had detected a error in the touchpad control
I hope this helps,
Gene
Aug 01, 2011 | Kitchen Ranges
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Error code F1 E1 Oven will not heat
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 19, 2010 | Whirlpool RBS275PD Electric Single Oven
Toshiba 160 error code
For error code C44, it indicates Heater abnormality.
If happen again, then u need to check the thermistor. Replace it if necessary. If themistor replaced but still happen again, then u need to proceed to check themostat--> heater-->Mainboard-->Switching regulator.
Mar 09, 2009 | Toshiba E-Studio167 Copier
Error F1E2 Whirlpool Super Cap Gas Range 465, oven crazy!
F1 E2
1. Verify failure if not displayed, using CANCEL/OFF key. Press key for 5 seconds until last
error code is displayed.
2. Disconnect power longer than 30 seconds.
3. Re-apply power and observe for longer than 1 minute.
4. If failure remains, disconnect power, replace control.
Nov 22, 2008 | Whirlpool GS460 Gas Kitchen Range
Error message on Whirlpool Gold gastop range: E0 -F2-
It means "shorted keypad".
1. Disconnect power from oven for longer than 30 seconds.
2. Re-apply power and observe for longer than 5 minutes.
3. If failure remains, disconnect power, replace control, then
go back to step 2.
4. Unplug and replug membrane connector.
Dec 29, 2007 | Whirlpool SB160PEE Gas Single Oven
Oven won't stay on and give an F error message
Disconnect the power. Disconnect the sensor harness from the control. Measure the sensor resistance (white leads). The resistance should be 1080 ohms at room temp. If the sensor is open the resistance is usually over 2900 and you get an F3 message. If the sensor is shorted the resistance is usually less than 950 ohms and you get an F4 error message. Also look for damaged harness terminals if not a bad sensor.
Aug 31, 2007 | Ovens
Samsung " 30"" Self-Cleaning Freestanding Electric Convection Range - Stainless-Steel/Black FTQ353IWUX/XAA" Logo
42 people viewed this question
Top Samsung Kitchen Ranges Experts
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
