Question about Ruud UAMB Air Conditioner
What does zr34k3-pfv-230 mean
Have to replace compressor but can't find compressor zr34k3-pfv-230. need cross reference to zr34k3-pfv-230, what does this number mean?
What size condensing unit lennox #ca5536vkd2
Your unit uses a LENNOX 11C32 COMPRESSOR COPELAND ZR38K5-PFV-130 3TON 208/230 1PH
Jan 03, 2016 | Heating & Cooling
I have a goodman unit with a copeland compressor Its in Montana and I only ran it three time since the install. Some times it starts right away and sometimes it try's three or four time before...
When you say Montana the first thing I thought was, does it have a crank case heater? Is it actually working? May need a start cap installed, need to check amps at start up, possibly nearing locked rotor. Fan works every time?
Dec 04, 2017 | Goodman Heating & Cooling
What capacitors do i need to get to replace the ones on a 6 hp motor
Due to the nature of power factor correction and other sizing criteria it is best to open the can on the motor that protects the capacitor and order a comparable unit for capacitance, number of sections (- ie, start/run versus Start or Run) plus capacity and working volts AC. Unless ordering from the original compressor supply company, most parts houses will not have a cross reference with that data.
Jan 31, 2012 | AO Smith 6 Hp 3450rpm R56Y Frame 230 Volts...
I have a copeland compressor model number cre4-0225-pfv. first what tonnage is it? and second i cant find a replacement number for it?
That is a 2.5 to 3 ton compressor and you can get one in many places. Try this one:
http://www.hvacplus.com/product/cre4-0225-pfv/127422/
Jun 29, 2011 | Heating & Cooling
What year is my Goodman Copeland Model # CR28K7-PFV-230 Serial # 07H93251H
The year of this Copeland scroll compressor is a 1993 model. 208-230 volt single phase.
Shastalaker7
A/C, & Heating Contractor
Feb 18, 2011 | Goodman Heating & Cooling
Ruud UAMB Air Conditioner Logo
82 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
