Question about Mind Alive DAVID Session Editor CD Version 2.0
Is Peter Robinson ( nauthor ) of Brighton Vic alive or dead ?
If this is the Peter Robinson you're asking about, he's alive. Peter Robinson novelist
Feb 02, 2015 | Miscellaneous
Tip
Recognize that your cd is a burner
To resolve this issue, edit the Microsoft Windows registry to identify the CD-R drive or CD-RW drive as a recordable drive. To do this, follow these steps.WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
1. Click Start, and then click Run. 2. In the Open box, type regedit, and then click OK. 3. Expand the following registry subkey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\Drives 4. On the File menu, click Export. 5. In the File name box, type backup of drives key, and then click Save.
Note You can restore this registry subkey by double-clicking the backup of drives key.reg file that you saved. 6. In the left pane of the Registry Editor window, click the Volume{GUID} folder under Drives, where GUID is a 32-character hexadecimal globally unique identifier.
Note If you have more than one CD-ROM drive in the computer, an additional Volume{GUID} folder is listed for each drive. 7. In the right pane of the Registry Editor window, double-click Drive Type. 8. In the Value data box, type 1 or 2, depending on the drive type, and then click OK.
The drive type should be 1 if it is a CD-R and 2 if it is a CD-RW. 9. Quit Registry Editor. 10. Click Start, and then click My Computer. 11. Under Devices with Removable Storage, right-click the CD-R drive or CD-RW drive, and then click Properties on the shortcut menu. 12. If the Recording tab is displayed, Windows recognizes the drive as a recordable device. 13. Click Cancel.
Note If you have more than one CD-ROM drive, DVD-ROM drive, or CD-RW drive in the computer and the Recording tab is not displayed, an incorrect drive may have been configured as "recordable" in the Windows registry. To troubleshoot this issue, follow these steps: a. Follow steps 1 through 9 to edit the Drive Type value of the Volume{GUID} folder whose value you previously changed. b. In the Value data box, type 3, and then click OK.
The drive type value of 3 indicates that the drive is a standard CD-ROM and is not writable. c. In the left pane of the Registry Editor window, click the next Volume{GUID} folder. d. Follow steps 7 and 8 to change the Value data entry to 1 or 2, depending on the drive type. e. Quit Registry Editor, and then follow steps 10 through 12 to confirm that the Recording tab is displayed in the properties dialog box of the CD-R drive or CD-RW drive.
on Jan 05, 2010 | Computers & Internet
Tip
Start Your Computer Within Seconds Does Your comp take a hell lot of time...
Start Your Computer Within Seconds Does Your comp take a hell lot of time to start??Well, if the Answer is Yes then this is gonna really help you.Here I Will Tell You How To Speed Up Your Boot Process of Windows Xp.
1.Open Notepad and then copy/paste the following code in it :
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\PrefetchParameters]
?EnablePrefetcher?=dword:00000003
2.Then save the notepad file with any name but make sure to rename its extension .REG , Finally double click on the file and then click Yes .
on Dec 14, 2009 | Computers & Internet
Spl-c error- Incomplete session by time out Position : 0xf807 (63495) System : src/os_hook Line : 1646 Version : SPL-C 5.35 11-20-2007
Hi
you need to replace motherboard
the cost of it is to high
you better replace your printer
Pls vote us to keep us alive
Nov 25, 2010 | Samsung SCX-4720FN All-In-One Laser...
Cdwr code 41
To resolve this issue, edit the Windows registry to identify the CD-R drive or CD-RW drive as a recordable drive. To do this, follow these steps.
NOTE: You can restore this registry subkey by double-clicking the backup of drives key.reg file that you saved.
NOTE: If you have more than one CD-ROM drive in the computer, an additional Volume{GUID} folder is listed for each drive.
click Properties on the shortcut menu that appears.
12. If the Recording tab is displayed, the drive is successfully recognized by Windows as a recordable
device.
13. Click Cancel.
NOTE: If you have more than one CD-ROM drive, DVD-ROM drive, or CD-RW drive in the computer and the Recording tab is not displayed, an incorrect drive may have been configured as "recordable" in the Windows registry. To troubleshoot this issue, follow these steps:
1. Follow steps 1 through 9 to edit the Drive Type value of the Volume{GUID} folder whose
2. In the Value data box, type 3, and then click OK.
3. In the left pane of the Registry Editor window, click the next Volume{GUID} folder.
4. Follow steps 7 through 8 to change the Value data entry to 1 or 2, depending on the drive type.
5. Quit Registry Editor, and then follow steps 10 through 12 to confirm that the Recording tab is
XXXXXXXXXXXXXXXXXXXXXXXXXXXXX
SYMPTOMS
After you install Microsoft Windows XP, the CD-ROM drive, the DVD-ROM drive, or CD-ROM R/W drive may not be visible in the My Computer window. Additionally, there may be question marks on the devices that are listed under CD-ROM drives in Device Manager.
CAUSE
An incorrect device driver was installed for the CD-ROM device.
RESOLUTION
To resolve this behaviour, use the following methods in the order in which they are presented.
Method 1: Remove Registry Entry
3. Locate the following registry subkey:
HKEY_LOCAL_MACHINE/System/Curretcontrolset/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
5. In the File name box, type savedkey, and then click Save.
6. Click the REG_MULTI_SZ data type UpperFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes. NOTE: If this data type is missing, continue to the next method.
7. Click the REG_MULTI_SZ data type LowerFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
8. Quit the Registry Editor, and then restart the computer.
Method 2: Replace Existing Driver
1. Click Start, and then click Control Panel.
2. If Control Panel is in Category view, click Performance and Maintenance, and then click System.
-or-
If Control Panel is in Classic view, double-click System.
3. On the Hardware tab, click Device Manager.
4. Click the drive with the question mark next to it.
5. On the Action menu, click Uninstall. When you are prompted to confirm the removal, click OK.
6. Repeat steps 4 through 5 for any other drives with question marks.
7. On the Action menu, click Scan for hardware changes.
NOTE: If Windows XP cannot locate the driver for your device, the device may not be supported by Windows XP. To see the list of supported devices, see the most recent Windows Hardware Compatibility List (HCL) at the following Microsoft Web site:
SYMPTOMS
After you remove either compact disc (CD) recording software or other software from your computer, your computer may exhibit the following behaviour:
• In My Computer, there is no access to your CD-ROMs.
• In Device Manager, the following error message appears in connection with any CD-ROM device that is part of your computer system:
The device is not working properly because Windows cannot load the drivers required for this device
(Code 31).
• Device Manager displays the following error message:
A driver for this device was not required, and has been disabled (Code 32 or Code 31).
You may also receive an error Code 39 message that indicates that the driver is corrupted.
• Device Manager displays the following error Code 19 message, which means that the registry returned some unknown result:
Your registry might be corrupted. (Code 19)
• You may also receive the following error message:
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
RESOLUTION
To resolve this behaviour, follow these steps:
1. Start Registry Editor (Regedt32.exe).
2. Locate the UpperFilters value under the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
3. On the Edit menu, click Delete, and then click OK.
4. Locate the LowerFilters value under the same key in the registry:
5. On the Edit menu, click Delete, and then click OK.
6. Quit Registry Editor. NOTE: After you remove the Upperfilters value and the Lowerfilters value, if you notice lost functionality in a particular program, such as CD recording software, you may need to reinstall that software. If the problem recurs, consult with the software vendor for assistance.
7. Restart your computer.
STATUS
This is a known issue that can occur when you remove Easy CD Creator version 5.01 or earlier or DirectCD version 3.01c or earlier. This issue may also occur with Easy CD Creator version 5.01 and with DirectCD 3.01d or later.
MORE INFORMATION
There may be other third-party CD-writing software products that exhibit similar behaviour. Some or all of the troubleshooting steps in this article might apply if such a product also adds entries under the UpperFilters or LowerFilters value in the registry, either by adding its own filter drivers or by removing the registry keys and values outlined in this article that begin with:
Oct 08, 2009 | Acer Computers & Internet
My lenovo Y300 DVD rom can't read anything When i insert a disk.
Step 1: Start Registry Editor: Start->Run->type regedit and click OK.
Step 2: Delete the UpperFilters registry entry:
  1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
  2. Expand SYSTEM, and then expand CurrentControlSet.
  3. Expand Control, and then expand Class.
  4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
  5. In the details pane of Registry Editor, on the right side, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only.
    • If you see the UpperFilters registry entry in the details pane of Registry Editor, go to step 6.
    • If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to "Step 3: Delete the LowerFilters registry entry."
  6. On the Edit menu, click Delete.
  7. Click Yes when you receive the following message: Are you sure you want to delete this value?
The UpperFilters registry entry is removed. Step 3: Delete the LowerFilters registry entry:
  1. In the details pane of Registry Editor, on the right side, click LowerFilters.
    Note You might see a LowerFilters.bak registry entry. You do not have to remove that entry. Click LowerFilters only.
    If you do not see the LowerFilters registry entry, unfortunately this content is unable to help you any more.
  2. On the Edit menu, click Delete.
  3. Click Yes when you receive the following message: Are you sure you want to delete this value?The LowerFilters registry entry is removed.
  4. Exit Registry Editor.
Step 4: Restart your computer. After you have done this, try to access the CD or DVD drive. If you can access the CD or DVD drive, and if you do not receive an error message, the problem is resolved. You can reinstall your CD or DVD writing or recording software.
Mar 17, 2009 | Toshiba Satellite A205-S4607 Notebook PC
MATSHITA UJ-840D, has disappeared and I can't play cd's/dvd's.
Before you do this though export your current registry to the desktop by selecting export from the file menu. If this doesn’t work just double click on the exported on to restore it.
1. Start Registry Editor by typing regedit into the start search box in the bottom left hand corner of the start menu.
2. In Registry Editor, expand Computer, and then expand HKEY_LOCAL_MACHINE.
3. Expand SYSTEM, and then expand CurrentControlSet.
4. Expand Control, and then expand Class.
5. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
6. In the details pane of Registry Editor, on the right side, click UpperFilters.
7. Right click and select delete
8. Click Yes when you receive the following message: Are you sure you want to delete this value?
9. Now look for LowerFilters in the right hand panel.
10. Right click and select delete
11. Click Yes when you receive the following message: Are you sure you want to delete this value?
12. Exit Registry Editor
13. Restart the machine
It wit worked for me on Acer with UJ845D XP Good luck
Feb 09, 2009 | Panasonic Matshita- | UJ-845-B | USB 2.0 |...
Can't find DVD drive under My Computer and regedit fix doesn't work for it
you may have to check the registry manually and if this will not work, you may have to reinstall windows.
1. click start > run > regedit > ok.
2. In Registry Editor, expand the following registry path:
3. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
4. Delete Upper and Lower Filters. (If only one is availabel, that's fine).
5. Restart system and check your drive again.
NOTE: Make sure to do this correctly or else, system will not load to windows.
If manually deleting upper and lower filters will not work then you may have to backup your files and reinstall windows.
Aug 26, 2008 | Toshiba Satellite A70 Notebook
Cd drive drivers
Step 1: Start Registry Editor loadTOCNode(3, 'resolution');Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor. Step 4: Restart the computer loadTOCNode(3, 'resolution');If a CD recording program no longer works after you restart the computer, you must reinstall the CD recording program.
Aug 12, 2008 | MSI (X52) CD-RW/DVD-ROM (Combo) Burner
Problem when windows XP is starting up. Isass.exe - System Error
To work around this issue, restart your computer in Safe Mode. To restart your computer in Safe Mode, press F8 when the computer starts. Then, when the computer is in Safe Mode, add the System Pages entry to the following registry subkey: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Session Manager\Memory ManagementTo add this registry entry, follow these steps: 1. Log on by using an account that has administrative credentials. 2. Click Start, click Run, type regedit, and then click OK. 3. In Registry Editor, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management 4. On the Edit menu, point to New, and then click DWORD value. 5. Type SystemPages, and then press ENTER. 6. On the Edit menu, click Modify. 7. Click Decimal, type 31000, and then click OK. 8. Quit Registry Editor.
Jun 17, 2008 | Dell OptiPlex GX280 PC Desktop
Mind Alive DAVID Session Editor CD Version 2.0 Logo
53 people viewed this question
Top Mind Alive Computers & Internet Experts
David Payne
David Payne
Are you a Mind Alive Computer and Internet Expert? Answer questions, earn points and help others
