Question about Graco DuoGlider 7444 Twin Seat Stroller
Broken When pulling the canopy back up I vroke the assembly that allows it to move back and forth. Can I get a new one somewhere?
    Novelist:
  • 126 Answers
Replacement parts
LINK: http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11
Telephone
Graco Customer Service is available Monday through Friday, 8am to 5pm Eastern Time.
1-800-345-4109 (US)
Postal Address
Graco Children's Products Inc.
Attn: Graco Store Consumer Services
150 Oaklands Boulevard
Exton, PA 19341
Posted on Apr 25, 2008
How do I remove fan mounted close to ceiling?
There should be side mounting screws in the canopy which attach it to the mounting bracket. The screws are removed to allow the canopy and motor assembly to drop down free of the mounting bracket. A convenient hook is provided to allow wires to be disconnected.
Oct 23, 2015 | Hunter 20461 Brushed Nickel Ceiling Fan
Tip
HOW TO FIX BUGABOO CAMELEON CANOPY
The Bugaboo canopy uses a clever two stage hub. A spring keeps the sections together in a twin set of wavy indents. As you pull the canopy out the first arch moves to the next indentation (60 degrees) than the second arch moves it's next indentation (90 degrees). If you have the fabric set to far back over the back of the frame and a arch can't reach it's next indentation it will jump back to it's first position. Check the arches can reach the indentations. If a spring breaks inside a hub it is not repairable but is available as a part for around 25 Euro for a pair.www.babycare.nl/bugaboo-canopy-clamp-cameleon-2pc-p-2467.html Ships Worldwide or Check out www.bugaboo.com
on Feb 08, 2011 | Bugaboo Cameleon Jogger
Oven Door Latch Won't Stop Cycling
Contact your power company and request they repair the appliance that was damage due to the surge, it is likely burned out the control panel
Jul 08, 2017 | Kitchen Ranges
The hood release cable on my 2003 Yukon SLT will not allow the hood to latch, is it broken?
The lever on the latch assembly (the one that gets pulled by the cable) is stuck. Happens all the time.....All you have to do is lube the hood latch assembly with some WD-40 or Sea Foam or a similar lubricant. Sometimes you can see the lever and move it back and forth a few times by reaching in with a screwdriver. Then close and open the hood a few times just to make sure everything is loosened up.
Feb 04, 2012 | 2003 GMC Yukon
Our Bugaboo Cameleon's canopy hood won't extend so thtat it is closed per the design of the pram. To better explain, the design of the pram is that when the hood is lifted upwards, it is lifted to 90...
The Bugaboo canopy uses a clever two stage hub. A spring keeps the sections together in a twin set of wavy indents. As you pull the canopy out the first arch move to the next indentation 60 degrees than the second arch moves it's next indentation. If you have the fabric set to far back over the back and a arch can't reach it's next indentation it will jump back to it's first position. Check the arches can reach the indentations. If the spring breaks inside a hub is not repairable but is available as a part.www.babycare.nl/bugaboo-canopy-clamp-cameleon-2pc-p-2467.html
Feb 06, 2011 | Bugaboo 'Cameleon' Stroller
I'm trying to convert this brand new stroller to have the carry cot on it. one of the buttons to release the hood off the regular stroller is stuck. what do i do?
since it's new, you'll probably have to rock the canopy side back and forth while you are pushing the button. once you detach the the canopy a few times that will get easier it's just stiff.
at 3:10 she removes the handle bar. (don't mind the cheesy music). It also shows you how to get the bassinet on as well.
Nov 08, 2010 | Micralite Toro Red Stroller Frame
My passenger seat won't lock into position. It slides back and forth as I drive and the bar that you pull on to move it back and forth is stuck in the up position.
There is a spring that pull's the handle back to lock position that might be broke or the locking mechanism might be gummed up.the spring can't be bought seperatly so check a hardware store or replace the seat track assembly.
Aug 11, 2009 | 2000 Chevrolet S-10
CHANGING A BELT ON AMANA MODEL # ALW990EAW/PALW990EAW
To replace a washer belt, remove power, remove back panel. On the left side is the motor, clutch, pump and belt. The pump is driven by a coupler clamped to the pump and clutch assembly. Loosen one of these clamps enough to move the coupler away so the old belt can be slipped past the coupler and also to facilitate the new belt to be installed. The belt runs in a pulley built into the top of the clutch assembly and can be "run" onto the transmission pulley very easily. To adjust the belt tension, pull out the washer, tilt it back against the wall......there are 3 nuts and bolts holding the motor assembly to the bottom frame, loosen these nuts off, the holes on the motor bracket are oval shaped so the motor assembly can be moved back and forth. You can move motor to tighten or loosen the belt, just make the belt fairly snug and don't over tighten it.
May 03, 2009 | Amana LWA90A
How to fold a beby trend expedition single
TO FOLD STROLLER
• Close the canopy as described in the canopy section. Recline seat by releasing buckle as described in seatback positioning section.
• The stroller is folded by simultaneously pulling each trigger fold. . When the fold latches are released, the handle will begin to fall toward the floor. Release the fold buttons and press downward on the stroller handle until the stroller is completely folded. Secure the stroller in the folded position by hooking the fold latch, located on the right side of the stroller, over the rivet that protrudes from the frame.
CANOPY
* The canopy features a ratchet system that allows the canopy to be moved forward to block the sun or wind. To adjust the canopy’s position, push forward or backward on the canopy until the canopy is in the desired position. See figure 23.
SEATBACK POSITIONING
* The seat has a multiple position recline that is controlled by a strap and buckle assembly behind the seat. . To recline the seat, loosen the strap through the buckle and adjust to the required recline position. To place the seat back in the upright position, press upward on the seat back with one hand while pulling the strap through the buckle with the other. The strap will lock automatically.
http://www.babytrend.com/download/2007061021349109CT_instructions.pdf
Apr 28, 2009 | Baby Trend Expedition LE Jogger
Dismantleing canopy
If this is for the Graco Snugride (I have the Windsor model from the Quattro Travel System), this will work:
1. Push the Graco canopy to one side, exposing the plastic support bars that hold the canopy in place.
2. The center of the support is where the canopy comes apart. Using both hands, pull the canopy support
bar apart (as if you were playing tug-of-war). It's best to grab the curved ends and pull HARD (and point it away to the side so that you don't hit your face).
3. Once the support bars are apart, remove the old Graco canopy and slip on the new/freshly washed canopy.
4. Secure the support bars by snapping them shut, and then slide the canopy into place.
Aug 26, 2008 | Graco SnugRide - Clover
Graco DuoGlider 7444 Twin Seat Stroller Logo
157 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
