Question about Garden
Great lakes hot tub
I've got the correct power to the tub, program for heat, and the red light is on. But, the water is not heating up. What could be the problem. I have model #GVS500SZ
  • 17 Answers
SOURCE: Red light's on... but no hot water!
OK, inside the unit there are three items, the heating element, thermostat, and thermal fuse.What has happened is the element got too hot and the thermal fuse opened.There is no reset button.In some cases you may run across a defective heating element or thermostat but its not common.The fix would probably be replacement of the thermostat and thermal fuse.For this, you would have to contact a small appliance repair center in your area.
Posted on Nov 07, 2007
  • 3 Answers
SOURCE: Water heats but stops perculating
Check the spring under the grounds basket on the pump tube. This is supposed to hold the end of the tube down in the heater well. It should compress when the lid is pushed down on the basket and twisted to lock in under the handles.  I have found a good source of parts for Faberware urns and percolators at goodmans.net. The thermostats and heating elements can be easily replaced and the urn returned to original condition. Rich of Colorado
Posted on May 24, 2008
barkencoa
  • 3463 Answers
SOURCE: Creda Simplicity 1000 Washing Machine not heating water
Make sure that you have not got the energy save button in operation, as this by-passes the heater, and will wash at the incoming water temp. It should not be showing green
If this is not the case, then the heater has probably failed.
To access the heater, you need to remove the top cover, remove the soap dispenser drawer, and undo the 4 screws securing the console panel to the top of the washer.
Pull off the timer knob, noting the position of it, and slide the console panel to the right, support it with something.
Remove wire cllip holding door seal to front of panel, and pull off the seal at the front.
Undo the screws securing the front panel at the top.
Undo 3 screws at bottom of front panel.
Lift front panel clear,and stand it at the right of washer, be careful of the wires still attached to the door lock.
At the bottom, in the center, you should find a black cover, remove that, and you will see the heater element.
You eally need a meter to test it for continuity, and or an earth fault.
Replace if faulty.
Please leave a fixya rating for my suggeted solution.
Thankyou.
Posted on Feb 10, 2009
  • 22 Answers
SOURCE: Krups model KM7005 water wont heat
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbench, I've mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Posted on Oct 19, 2009
  • 366 Answers
SOURCE: I have a 2004 great lakes hot tub with a balboa
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
Posted on Feb 09, 2010
Great lakes maniste hot tub comes on click like breaker tripping in tub, could it have bad fuse in tub itself?
Does the breaker trip instantly or does it take a minute? If there is a delay i would start with checking heating element. Instant is a direct short, try unplugging all components and if still trips then check wiring and breakers. If power stays on with components unplugged, plug them back in one at a time to see which one causes failure.
Feb 22, 2017 | Pool & Spa
My Great Lakes sunlighter tub will not heat - need a part number to order
check temp sensor if calling for heat check heater element
Nov 12, 2015 | Pool & Spa
Great lakes hottub wont heat up
is the heat indicator light showing on the topside panel? If the pump is running and there is not enough water flow to activate the pressure switch then the heater will not come on.
If the filters are too dirty there may not be enough water flow to activate the pressure switch which sends the power to the heating element.
You just may have a bad heating element.
Jan 24, 2013 | Cars & Trucks
Drained my 2000 Great Lakes Spa now OH is displayed when I turn up the heat it kicks out the breaker..
OH is overheat due to insufficient water flow through the heater.
Common Causes:
  • Gate valves not opened/partially closed.
  • Air trapped in suction lines or pump
  • Blocked suction fitting
  • Dirty filter
  • Restricted water discharge lines
Try remove filter cartridge and run spa.
Check pressure switch for continuity.
Unplug & plug hi limit sensor.
Oct 14, 2012 | Qca Spas Majestic Series Aruba Xl Hot Tub
Spa thermal overheating
Turn off all power to the hot tub as soon as you realize it is overheating. The spa should have an automatic shut off when the water temperature reaches about 112 degrees fahrenheit. Call your hot tub dealer or manufacturer for service options. There are a variety of conditions that could lead to the overheating of your hot tub, but may differ in various hot tub models and brands. Check the water level of the hot tub. Low water levels could be the culprit for the over heating, so you may just need to add more water to the hot tub.
Check the shut-off valves in the hot tub. If they are closed while the hot tub heater is on, it could cause the water to reach unsafe temperatures.
Clean the hot tub filter. A dirty filter could be blocking the flow of water, causing the water to sit in the hot tub and overheat.
Turn the power back on after finding the problem and talking to the hot tub dealer. The hot tub will probably not start back up until the water reaches a safe temperature
Jan 06, 2012 | Endless Summer Pool & Spa
Hi...I have a Whirlpool water heater and the water only stays hot for a few minutes. How do I adjust the temperature or settings so that I can have hot water all the way through the shower instead of...
I am guessing this is an ele water heater and the temp setting are not the problem.
Problem: Not enough hot water or water temperature too low. When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, replace it. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
The dip tub is located under the fitting where the hot water comes out.
Feb 03, 2011 | Whirlpool Water Heaters
I have a 2004 great lakes hot tub with a balboa controler. My hot tub heats up fine when the pump runs on high but the temp light never comes on when the pump runs in low.
Feb 04, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Water not heating
It sounds like your inline heater has stopped working. The only way to test it is to drain the water back out, remove the inline heater, and hook power to it to see if it heats up.
If it doesn't you can get one at a discount supply house (like Home Depot or Lowes) for less than $150.
May 28, 2009 | Home
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
