Question about Troy-Bilt 32cc 4Cycle Backpack Blower
Will not Run
This is my second Troy Bilt first one just stopped running in the middle of the job then was stolen still broken... was replaced by the same model... after a short time it did the samething just stopped dead in the middle of the job... got good gas... pulls easy engine spins but will not start
  • 77 Answers
SOURCE: I have a Troy-Bilt 31cc 2-Cycle Gas Powered that doesn't start
Coil bad or wire to coil bad. I tell everyone what Ill tell you,when it comes to small engines,troy bilt,poulan,weedeater brand all JUNK,JUNK JUNK! Theyre made cheap,not built to last,theyre throwaways. Carbs are made in china. If youre ever in walmart next time go back to the garden section and pick up a weedeater or poulan brand chainsaw or trimmer. Look at the package good and look at the factory life expactancy. Its not in months,not even days,but in hours. If I was you I would tell myself NO MORE! I would buy a dolmar or stihl,pay the extray,cause you wont be aggrevated in the long run. P.S. Dolmar offers a 100% coverage for ONE YEAR on all equipement.
Posted on Aug 11, 2009
  • 110 Answers
SOURCE: must run choke on all the time with troy bilt gas
First I would check your fuel filter in the tank. They use a sintered type that clogs easily then allows dirt to get into the internal screen in the Zama carb, if the filter is clean and whole I suggest to take the carb out and clean it. Remenber to only use starting fluid to clean the internal parts, as carb cleaner will melt the internal check valves and ruine the carb. Dont be afraid to take the carb apart, its not brain surgery, just start with a nice clean shop cloth and lay it out as you take it apart. The screen I am referring to is on the metering diaphragm side, thats the side with one screw on it
Posted on Nov 01, 2009
  • 736 Answers
SOURCE: troy bilt tb320bv 31cc gas blower starts and runs
inside the fuel tank you will see a flexible fuel line with a filter attached to the end ... that filter acts as a weight to position the fuel line in the lowest part of the tank no matter what postion the blower is in ... make sure the fuel line isnt broken .. also make sure the filter is still attached .. you can replace the fuel line and filter but both have to be able to handle achohol (in the gas) .. most of the older fuel lines cant and they go bad in a short time .. its actually hard to find the correct fuel line ... the size is not usually a problem but the material its made of has to say its suitable for modern gas .. most i found at local shops are the old type and wont work ..
Posted on Nov 05, 2009
kel1guy2002
  • 3740 Answers
SOURCE: lost my manual,what engine oil to use for my troy
You can find your manual here:
http://manuals.mtdproducts.com/mtd/Safety.do?BrandCode=10001&pid=235248&model_num=TB4BP&serial_num=100063&filename=769-03148c.pdf
You must choose accept to open or download the manual.
769-03148c.pdf is the file name.
Or go to this page and click View manual after entering your model and serial number:
If you do not know your serial number enter 100679 and you will still see your manual.
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
7.9 Mb download! The informatiion you seek is in the manual on page 8.
SAE 30 SF or SH or SG (3.04 fl oz total capacity to be changed every 25 hours)
Thanks for choosing FixYa,
Kelly
Posted on Aug 29, 2011
vincob
  • 718 Answers
SOURCE: what engine oil is used
The generator engine is shipped from the factory filled with
oil (API SJ or higher 10W-30). This allows for generator
operation in the widest range of temperature and climate
conditions. Before starting the engine, check oil level and
ensure that engine is serviced as described in Maintenance.
This is from toy bilt manual >Good Luck...
Posted on Aug 31, 2011
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
After running for a while my Troy Bilt RZT tractor Colt ZT42 PTO stops working
pto going out or stater going out run till it does then replace i the red neck saya it the pto replace if you cant live with it till burns out
Aug 31, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt pull cord wont retract
Recoil spring is broken or slipped out of retention slot. Coil needs to be retentioned or replaced. Unless you have done this before I recommend taking to pro. This is easy job if you have the jig but almost impossible if you don't.
Jun 29, 2014 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Have a Troy Bilt chipper/shreader model 47285. I
Taked the broken belt to the auto parts store for a replacement.
Jun 06, 2010 | Troy-Bilt ChipperShredder
Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Oct 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
How to replace air filter on Troy-bilt TB20CS?
May be air filter but sounds more like your muffler is stopped up. First take the muffler off and see if it runs better without it. If so, burn the carbon out of the muffler and clean the muffler port on the engine. If not, then remove the four screw at the very end and disassemble. The ait filter is in that area. Diagram is located at
www.stollerlawnandgarden.com/.
Click on parts lookup in left hand column.
Jun 24, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Its starts but will cut off
The problem you are having is due to dirt and gunk in the carbeurator. Spray a carbeurator cleaner into the air chamber [remove the air filter] and run it a couple of times then let it sit for two hours while the carbeurator cleaner does its job of dissolving any debris. Then start it up. IF this does it, great, if not repeat the cleaning technique.
If all of this doesn't do it, then the carbeurator will have to be removed and either replaced or rebuilt.
May 06, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy-Bilt Chipper Shredder won't start
It takes good gas, good spark, and good air for a gasoline engine to run well. The next thing I would do is put a new air filter in it.
Apr 23, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Troy-Bilt 32cc 4Cycle Backpack Blower Logo
32 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
