Question about Sammons Preston Talking Timer and Clock
Instruction for samons preston talking timer
Re-set voice choice
Reset fossil mens es3380
Google (fossil)(ES3380)(manual) without parens for instructions.
Feb 16, 2014 | Fossil ES Watches
I've had the Avalon EXC talking watch for just a little over a year. A month ago, the battery quit, so I went to a store that had a jewelry counter and they replaced the battery. After just a month, it...
Some of these talking watches have 2 batteries, one for the voice and one for the hands, the one for hands is underneath the talking part. A lot of people don't know this and,just change the top battery. All watch batteries are the same voltage but the better brands tend to last longer, a good Swiss battery is the way to go. The more you use the talking function the more power you,will use
Sep 11, 2013 | Avalon Ezc Voice Series Low Vision Talking...
Watch stopped talking, shows correct time.need to resume talking function
Mar 26, 2012 | Avalon Ezc Voice Series Low Vision Talking...
Need to set the time on Avalon EZC Talking Watch
Here is a link to the instructions on how to set the time on your talking watch. It says that it is a one button operation and easy to do. Good luck! http://www.assistech.com/tw-avalon1-usermanual.pdf
Jun 09, 2011 | Avalon Ezc Voice Series Low Vision Talking...
A friend has a talking watch & has lost
Unfortunately there are no available instruction downloads for Marcel Drucker talking watches. Use this link to get in touch with them and request instruction manual: http://www.marcelwatch.com/category_s/23.htm Rate me, plz.
Feb 26, 2010 | Watches
I need to set the talking part of a gts avalon ezc voice 3 button 1push 1 pull out to set anol 1 flush with case to push
Enter "www.pocketwatchsite.com/opencase_singer.txt" in your search engine and you should arrive at a site headed "opening pocket watch cases" .
This would seem to be what you need!
Feb 25, 2010 | Avalon Ezc Voice Series Low Vision Talking...
On time atomic watch wrong time zone EXSV10+Talking+Watch I DON'T HAVE+instructions+owner+manual I need to set correct time?
The EXSV10 Atomic Talking Watch by On-Time sets itself to the official time standard of the United States government, maintaining split second accuracy. It can also literally "tell" you the time. It talks! The On-Time talking atomic watch also has daily alarm capability, and can be set to announce the time every hour.
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Feb 24, 2010 | Watches
Help Me set the watch please
Hope this tip helps.
R/
David
Dec 21, 2009 | Casio Pathfinder Watch with Hunting Timer
I need to find someplace to download the instructions, since mine didn't come with any
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
Apr 17, 2009 | Watches
Sammons Preston Talking Timer and Clock Logo
22 people viewed this question
Top Sammons Preston Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Sammons Preston Watch Expert? Answer questions, earn points and help others
