Question about Goodman GMS90703BXA Heater
I have a lennox merit series gas furnace and it's blowing out cold air.Also it keeps coming on then shutting off
hotuna
  • 288 Answers
SOURCE: Coleman Furnace
Based on the info you have given here, I am going to make some assumptions. In "cleaning out all the components" you cleaned the air filter or changed it, cleaned the duct-work, and the intake combustion chamber? When the "furnace stays lite" the pilot and the main burner stays on? Lastly, when it "continues to blow cold air" is this when the main burner is on after long periods of time? If the answers are all yes, then maybe some of the ducts have come off, or the burners aren't working correctly.
Posted on Nov 10, 2007
aries_67
SOURCE: 1993 goodman status light 4 times blinking
I have a goodman GMP075-3 that won't turn on. I think it is the pressure switch since I do not have a vent blockage. What is a venter and where can I find it??
Posted on Dec 30, 2008
carldc3
  • 82 Answers
SOURCE: Furnace blower never blows.
it sounds more like the flame sensor ( a metal rod that is by the burners with a wire going to it and it has a ceramic base). you can try cleaning the rod and if that doesnt work they are not to expensive.
Posted on Jan 13, 2009
  • 252 Answers
SOURCE: my fridgidaire gas furnace is blowing cold air
Today’s furnaces are controlled by a computer which constantly monitors for problems. When it detects a problem it will shut off the burners. Depending on the problem and the specific furnace it will either “lock out” the furnace or cycle it through a purge (to rid it of un-burned gas and excess heat) and then attempt to re-start it. If the problem continues to occur then it will “lock out”. Depending on the problem and the furnace it may again attempt a re-start after several hours. In any case if the problem was not detected/caused by a sensor which requires a manual re-set, when the power to the computer is interrupted or the call for heat is interrupted the computer is reset and it will again attempt to re-start the furnace. The most common problems are:
· Low or lack of flame sense. Different furnaces use different methods to detect a flame – often these “flame sensors” become dirty and have to be cleaned (usually with sandpaper or steel wool).
· Bad igniter. (Doesn’t light at all).
· Clogged combustion air intake or exhaust.
· Clogged condensate drain. (90+% efficient furnaces).
This is not a complete list, only the most common!
Depending on where you live your HVAC system runs more than anything else you own (including your car). All furnace manufacturers “recommend” “regular maintenance” of your furnace. In fact, all that I am aware of state in their warranty that the warranty may be voided due to lack of “regular maintenance.” The industry has defined “regular maintenance” as yearly (in fact, some manufacturer’s warranties state yearly). Due to safety, liability, and the need for many other things to be checked, cleaned, and/or adjusted (2-page checklist where I work) to ensure safety and efficiency. Due to the large number of furnaces and the differences between them. Moreover, due to the terms of this site, I WILL NOT AND CAN NOT give you specific instructions on how to perform repairs on your furnace. I suggest that you contact a local, reputable, HVAC service company for (a tune up, preventive maintenance, general maintenance, yearly service call, general service, or whatever they call it).
While I may not have told you how to fix your furnace yourself, I have told you how to fix it. Please rate my answer.
Posted on Mar 14, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: my burner goes on but shuts off early
First when it goes out again, locate the furnace and look thru a small viewing port to see if there is a light blinking, count the number of blinks. Then look at the wiring diagram for a diagnostic code chart. This will give you a strart of where to look.
Posted on Oct 17, 2009
Lennox lb50527cc
high limit switch, no proof of flame.
Oct 27, 2013 | Goodman Heating & Cooling
I have a lennox merit series heater with a honeywell VR8200series gas control valve. The main fan comes on and I can hear a clicking sound but it does not ignite the burners.
HI see if the hotsurface ignitor is glowing by the burner , check the pressure switch also chech air filter is not blocked
Feb 09, 2010 | Heating & Cooling
Lennox merit series furnace is not kicking on until house is 8 to 10 degrees colder then set thermostat
I have the same issue with a G21Q4-5-100-1 model lennox. House drops 8 - 10 degrees. I have 3 thermostats and all react the same way. I was told by service tech that the Ignition Coontrol Module is bad and acting intermittanely. ???
Jan 31, 2010 | Dayton Gas Furnace Heater
Lennox G40UH(x) series - Air not coming on
electrical connections @ the furnace may the thermostat .Tom
Jun 18, 2009 | Heating & Cooling
Furnace starting
Hint number 1, get HVAC license. One mistake or misunderstanding and you could blow your house up.
Feb 21, 2009 | Heating & Cooling
Electric furnace blows cold air before and after warm air.
It is normal. Your house has to go down a couple more degrees because the heat pump is not working. You can solve this by rewirng you thermostat. Take off the wire that goes to Y and tape off. Then take the wires that are marked w and e or w1 and put the wires to yellow. Do not run ac with it wired like this. If you need more information please post me back
Nov 29, 2008 | Heating & Cooling
Gas furnace wont stay lite
I'm a little confused by your terminology. You are saying you have a pilot lite and electric heat strips? Are you possibly meaning burners? Is the heater running for 2 hours straight without shutting off? how cold is it there? Lastly what temperature do you have the thermostat set at and how close does it get to the temp. before it shuts off?
Dec 16, 2007 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
27 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
