Question about Fossil Metal Dress Jatelyn ES1356 Watch for Women
How to replace battery in a Metal Dress Jatelyn ES1356 Watch for Women
2 Suggested Answers
mcdevito75
  • 1970 Answers
SOURCE: how to adjust a metal watch band
mcdevito75 here, Best bet since you would need a couple of tools to adjust the band size is to look for a small watch repair shop in your area to save on the cost, the cost of a shop to adjust the band is about the same as the tools needed, since these adjustments are in frequent let the watch repiar shop do the job.
Posted on Jun 18, 2010
Battery number for fossil es1741T9
Take your watch to a jeweler for battery identification and perhaps replacement.
Jun 26, 2014 | Fossil Metal Glitz Glitz White Dial ES1741...
I have a fossil watch which does not fit, i need another clamp
Fossil Links & Bands
Go to "fossil.com", go to the bottom of the page and you will see a
menu, click on "customer care", and then look under "Product Info" on
the left and you will see "0rdering links and bands"
Mar 31, 2011 | Fossil F2 Dress watch #ES1149 Watch for...
I wanted to replace battery in my wife's Relic watch and a little metal part dropped on the table. I don't know where should it be put back. Do you have a manual for watch ZR33471. I would like to fix...
Thank you for contacting FixYa.
First of all, the manual would not help you with the battery. They usually dont have this info in manual. Your best bet is to take your watch to a local jeweler who does watch batteries. I imagine its just the battery strap but they can help you. You may get lucky and they dont charge you if you have the battery.
Best regards. Jewel
Sep 21, 2010 | Relic Calendar Date with Round Silver Dial...
How do I open the battery cover to insert the batteries
Locate a very small tab (or recessed area) on the edge of the back cover. This is the access point for removal. You can find this sometimes by running your fingernail around the back rim, as this tab or indentation can be hard to see.
  • 2Pull out the stem, which releases the back on some watches.
  • 3Get a small flathead screwdriver it needs to be a thin inflexible tip. Use a kitchen knife as a last resort. Wrap the hand you are holding the watch with in a towel or protect your hand in some manner so you don't injure yourself if the screwdriver/knife slips.
  • 4Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). Do not attempt to insert the point of the knife. Use the length of the blade.
  • 5Get under the tab or recessed area and gently but firmly turn the blade upward, popping the cover off.
  • 6When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch.
  • Aug 23, 2010 | Fossil Metal Dress Silver Dial ES1053...
    Change battery
    Take your watch to your nearest watch shop and ask them to do it for you.
    You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yourself.
    Apr 27, 2010 | Fossil Dress Collection watch #ES2154...
    Which battery for my Fossil ES1112?
    I believe the battery is a type 364. Here's a link to an article on changing the battery. Good luck!
    Mar 04, 2010 | Fossil F2 Dress watch #ES1112 Watch for...
    WHAT TOOL DO I NEED TO REMOVE THE BACK OF FOSSIL BLUE #BQ-9232 AND HOW AVAILABLE ARE THE BATTERIES FOR REPLACEMENT?
    Most watch backs either screw off with a special case opener that every wachmaker uses or pried off with a knife like case opener or sometimes a knife. Take this to your local watchmaker for battery replacement. Batteries are readily available but are a bit tricky to install properly and are best installed by a qualified watchmaker.
    Nov 29, 2009 | Fossil Metal Chronograph White Dial ES1793...
    How do I remove the back off a fossill watch to replace the batteries
    If it doesn't have the indentations for a tool used to screw off the case back then its a pry off type and you need to use a sharp tool and pry off under the case against the band post
    Nov 06, 2009 | Fossil Metal Chronograph White Dial ES1793...
    Diamonds are falling out
    If this is a Fossil then you need to make sure that the watch is not exposed to a lot of moisture or extreme temperatures or gets banged around too much. Fossil doesnt cover cosmetic damage under their warranty but you can send this to them for repair. If you still have the stones that have fallen out you can have them put back on by a repair shop or you can use a 2 part epoxy and attach them yourself.
    Metro Service Center
    ATTN: REPAIRS
    10615 Sanden Drive
    Dallas, TX 75238
    Note: This address is for mail-in only.
    Sep 19, 2009 | Fossil Metal Dress Zsa Zsa AM4020 Watch...
    One jewel fell out can i get a replacement
    The short answer is no.
    You might find a specialty shop that would have a replacement but my experience has been that you will need to get a replacement band or case from Fossil . You will end up paying for this because Fossil's warranty doesnt cover cosmetic damage.
    Sep 15, 2009 | Fossil Metal Dress Marissa ES1512 Watch...
    Fossil Metal Dress Jatelyn ES1356 Watch for Women Logo
    32 people viewed this question
    Top Fossil Watches Experts
    Ansel Alberto
    Ansel Alberto
    Lyle Siemens
    Lyle Siemens
    Are you a Fossil Watch Expert? Answer questions, earn points and help others
