Question about Pool & Spa
Remove impeller on TX hurlcon pool pump - Pool & Spa
dragonsthatk
  • 547 Answers
SOURCE: water leaking
some times you need two people one to hold the shaft the other to turn impeller on you need to put in a vice wraped in a towel and not to tight or break it off and replace it to
Posted on Feb 11, 2009
PartsCenter
  • 125 Answers
SOURCE: Jacuzzi magnum pool pump impeller broke
The impeller on the Magnum pump unthreads counter clockwise as do other impellers. There is a shaft of the motor that runs the length of the motor, on the back of the motor when you take the bell housing off you will see a small silver spot with a **** in it for a standard screwdriver. Put the biggest one in there you can and then grab the impeller and turn it counter clock wise and it should unthread. Sometimes they won't if it has been on there a number of years. You will need to break it off if it doesn't unthread. Then just purchase a new Impeller for the Jacuzzi Magnum Pump.
Rod
US Parts Center
Posted on Feb 24, 2009
  • 3 Answers
SOURCE: tring to take the pump face off the motor
You have to remove the back cover from the motor. Next loosen the capacitor. Put a 7/16" wrench on the shaft and the pump impeller will screw off by hand.
Posted on Jun 04, 2009
tinkerbill
  • 12 Answers
SOURCE: Need Intex Pump model #635 impeller
You know, I have made some amazing repairs on plastic items using nothing more than a soldiering iron! If you have the piece that broke off, you can carefully melt it back together. You can add more to the weld if you match the type of plastic but not too much or you imbalance it. In this case it looks like PVC. To repair it without the missing piece, form it out of epoxy putty, roughly shape it just before it sets up solid, & sand to finish.
Posted on Jan 02, 2010
  • 106 Answers
SOURCE: How to remove impeller on pool pump to replace seal?
First, separate motor and pump. Remove back cover of motor. Drive shaft of motor either has a slot on end for a large screwdriver or a flat on it for a wrench.(usually 7/16) Hold shaft and unscrew impeller.
Posted on Feb 21, 2010
My hurlcon CX 240 pool pump has good return pressure but very low suction from the pool and wont opperate the kreepy krawly, Do I need a new pump? Thanks. Richard
no
what you may have is a blocked outlet--filter --tap incorrectly set
good pressure but no suction indicates that the pump is pumping but the pumped water has nowhere to go
Jan 05, 2017 | Pool & Spa
We have a hurlcon GX 600 cartridge filter that has suddenly stopped working and there is no flow...
have you cleaned filters lately? if not take out and clean filters soak in bucket with 4 parts water to 1 part muriatic acid if you have take filters out of canister put back together without filters try them to see if you have flow if not sounds like pump plugged something might be caught in impeller
Jan 26, 2014 | Pool & Spa
Remove impeller pool pump
look to make sure there is no ***** in the center of the impeller, if so, it loosens to the right. the impeller will come off by turning it to the left (facing the impeller) if you still have trouble with the impeller, search your area for your ''local pool pump motor repair guy'' with free testing.
he should be able to save the impeller and install a new seal for around $20.
remember to prime the pump with water after any repair !
Jan 03, 2014 | A O Smith Motors Pool & Spa
Need to remove the impeller
Turn off the system at the breaker,
Undo bolts for housing and separate the motor from the pump to access the impeller. Some styles of motors have a screw that is reverse threaded holding the impeller in place, if it has one , remove the screw. Once you have access to the impeller you can use a big pair of channel locks to turn the impeller. Take off the back cover of the motor or remove the plastic or metal cap that is covering the shaft. Use a wrench to hold the back end of the shaft as you unscrew the impeller.
Aug 29, 2013 | AO Smith Pool Pump Motor Hayward Swimming...
Hurlcon cx240
bad sensor and cell calsified need to super shock poool
Mar 19, 2017 | Pool & Spa
Hurlcon pool pump reset switch where is it??
If there is a reset it will be locater near the power inputs, could be beneath a cover. Try looking here:http://www.hayward-pool.com/pdf/manuals/NorthStar.pdf
Nov 04, 2012 | Hayward 2HP Pool Pump Motor A O Smith...
How to remove impeller case from century centurion pump
take out screw to impeller backwards thread impeller unscrews normally
Sep 16, 2012 | AO Smith Pool Pump Motor Hayward Swimming...
i think they screw on and the screw only locks it in place
Mar 22, 2012 | AO Smith SQ1152 Pool Pump Motor
Trying to replace motor cant figure out how to remove impeller,
Might be a screw in middle of impeller with reverse thread. If so, remove. Remove back cover of motor, hold center shaft with wrench and unscrew impeller from shaft.
May 05, 2010 | Hayward 1.5hp Pool Pump Motor Motor A O...
May 01, 2009 | Pool & Spa
Pool & Spa Logo
82 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
