Question about Miele W864 Front Load Washer
Miele w864 lost power - Miele W864 Front Load Washer
  • 13 Answers
SOURCE: Miele W864 Fault
I have a W844 and the exact same fault occured. I traced it to badly worn brushes on the motor.
Posted on Sep 21, 2008
  • 14 Answers
SOURCE: rinses light flashes miele w864
this usualy indicates a problem with the motor not turning, it can have many causes
Posted on Aug 26, 2009
  • 1525 Answers
SOURCE: how do i replace the drive belt on miele w864...
hello at the back of the washer you should see panel with 4 or 5 screws.once this is off you should see the belt attach the motor at the bottom get a felt tip pen mark the nuts where the motor is bolted to loose them off the belt should drop off put new belt and tighten the nuts back up do quick test on the washer if ok your done
regards
shaun
Posted on Mar 13, 2010
Testimonial: "Thanks I could not see how I was going to get the tension back once blots loose. Instead, I used 2 nylon ties, then rolled belt around fly wheel"
beltronic205
  • 1461 Answers
SOURCE: miele novotronic w864 The motor is
Providing the motor is okay then yes could be the belt...if so you will find that the drum turns by hand no problem with ease........In which case order new belt....
Posted on Mar 03, 2011
ribbonsrabbi
SOURCE: spin light flashhes spin does not work
The Miele W864 model will flash a warning light and will refuse to spin when it considers its load to be unstable....What I mean is... if you put a blanket in it and the blanket is on one side of the drum, the computer decides that if the machine spins, the centre fugal force or whatever they call it, the weight of the thing inside, will make the machine move about dangerously and will therefore not spin... its a safety feature. My spelling is shocking... I will look at the manual. Which says the load is unstable... more or less... waterlogged garments, like blankets can do this.... I normally just fill it with towels, and wash twice or three times because I wont get a good wash when overloaded.xx
Posted on Feb 21, 2012
I have a miele w864 washing machine that will not fill with water
Does the light "Check Inlet" stay on? If it does, it is likely the water inlet valve solenoids that are inoperative. How old is the washing machine?
Aug 30, 2014 | Miele Washing Machines
Spin light flashhes spin does not work
Nov 12, 2011 | Miele W864 Front Load Washer
How do you open front panel on miele w864 to clean out drain pipe to uper right hand side of drum i belive this has a sensor that detects when blocked and once clear machine will work ok , drain pump is...
Hi - in most cases there are three screws behind the door, 2 screws for the door lock, some models will require the removal of soap dish and screws.
Should not be the case here, 2 screws on the lower part of the front panel, open the small trap door bottom RH corner unscrew cap to remove the rubbish from the drain pump as this shuts off the machine too.
Be careful to have a contaner to catch H2O as the cap unscrews.
May 28, 2011 | Miele W864 Front Load Washer
Miele novotronic w864 The motor is still working but the drum is not going round. Could it be the drum belt?
Mar 03, 2011 | Miele W864 Front Load Washer
How do i replace the drive belt on miele w864... which panel do I need to take off to gain access
regards
shaun
Mar 13, 2010 | Miele W864 Front Load Washer
Miele novotronic W864 rince light flashing. Machine not working
dear sir we have a problem in washing machine meile novatronec w864 the controller is not working please reply urgent
Aug 01, 2009 | Washing Machines
Rinses light flashes miele w864
Jun 28, 2009 | Miele W864 Front Load Washer
Miele novatronic w864 washing machine
Miele novatronic w864 washing machine.This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 28, 2008 | Miele W864 Front Load Washer
Miele W864 Fault
Mar 11, 2008 | Miele W864 Front Load Washer
Miele W864 Front Load Washer Logo
18 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
